Date/Time: Fri, 10 Jan 2025 16:43:25 +0000
Offline Installer?
View Count: 1126
[2016-09-24 19:04:02]
esMike - Posts: 71
How do I install the newer versions with a offline installer to update my other computers?
Can I copy the folder off my laptop and overwrite the one on my PC's? They run off 56k and slow mobile connections, so they cannot be updated without an offline installer.
[2016-09-24 20:42:04]
Yes you can just simply copy the Sierra Chart folder itself. It is completely independent and portable.
More information can be found here:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
