Date/Time: Fri, 10 Jan 2025 16:29:34 +0000
Chart Issues
View Count: 803
[2016-09-24 10:02:39] |
User223734 - Posts: 103 |
1)Can I view 2 or 3 products chart (eg. ES, YM and NQ) together on the same screen? 2)How many computer for one user can log on sierra chart at the same time? |
[2016-09-25 20:42:51] |
1. Yes. Follow the instructions here to open additional charts: Getting Started, Opening Charts and Basic Trading: Open A Chart 2. Refer to: Sierra Chart Purchase and License Information: Licensing / Number of Systems In your case you can use Sierra Chart on three different systems at the same time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
