Date/Time: Fri, 10 Jan 2025 16:44:18 +0000
Market Profile Not Showing Recent Data
View Count: 758
[2016-09-24 02:17:50] |
User341752 - Posts: 26 |
Hello, I've been using the MP and rcently it stopped updating the most recent days, it seems as if the data didnt convert to MP but all other charting forms. The regular candlestick data downloads fine but when I change it to MP the most recent days are missing. Anything you can do to help Thanks |
Candlestick.png / V - Attached On 2016-09-24 02:16:02 UTC - Size: 43.85 KB - 228 views Attachment Deleted. |
[2016-09-24 02:21:55] |
Select Chart >> Reset TPO Chart. If that does not help, do you see the data when you remove the TPO Profile Chart study from the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-24 08:05:14] |
Thanks for the quick response I found the problem and it was my mistake. The currency market has a different open session than futures which lead to the confusion. Thats why it shows going into Friday's close. Apologize for the mistake |
