Date/Time: Fri, 10 Jan 2025 16:43:34 +0000
GetStudyArraysFromChartUsingID
View Count: 962
[2016-09-23 19:15:57] |
Sean Beebe - Posts: 10 |
I want to use the function GetStudyArraysFromChartUsingID. Is there any way to iterate through the available chart numbers and study IDs so that we can attempt to select the correct chart and study for the user? This might be preferred to having them input the correct chart and study reference for themselves.
[2016-09-24 01:20:21] |
There are some functions which could help with this. For example, there is sc.GetHighestChartNumberUsedInChartBook(). Have a look at the functions here: https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html Longer-term, this capability will come but it is not expected to be ready until at the earliest the first quarter of 2017. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
