Date/Time: Fri, 10 Jan 2025 16:53:22 +0000
FIBONACCI
View Count: 1101
[2016-09-23 18:29:01] |
User82615 - Posts: 106 |
HELLO IS THERE ANY WAY TO CALCULATE THE FIBONACCI SEQUENCE IN A CHART? BECAUSE I'M LOOKING FOR IT AND I DON'T FIND IT. PLEASE DON'T TELL ME THAT IT'S THE FIBONACCI FAN IN THE TOOLS. THANK YOU VERY MUCH |
[2016-09-24 01:31:39] |
This does not sound like something that Sierra Chart has.
