Date/Time: Fri, 10 Jan 2025 16:52:56 +0000
Display of Date in The Region Data Line
View Count: 992
[2016-09-23 08:42:33] |
crossiman - Posts: 29 |
In my charts the region data line consists of all my indicator settings in the displayed chart, so e.g. a Moving Average of 40 will be displayed as "Moving Average Simple (Last, 40)". But now in this line the date of this intraday chart is missing and not shown. How can I make the date of the displayed intraday chart to be shown in the region data line ? Regards Crossi |
[2016-09-23 09:01:13] |
Refer to: Working With Charts: Region Data Line / Chart Header Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-23 11:15:13] |
But I don't want to have the date in the Chart Header. In the link I can only see the description how to add the date in the chart header and not how to set it in the region data line. Any advice on this ?
[2016-09-23 16:49:22] |
The Chart Header is a Region Data Line. It is the first line at the top of the chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-23 16:49:43
