Date/Time: Fri, 10 Jan 2025 16:39:57 +0000
DIFFERENCE IN VOLUME
View Count: 663
[2016-09-23 03:59:04] |
User692217 - Posts: 5 |
Hello Is there a reason my volume profile total volume differs from NYMEX totals? For example, my profile will show 5000 traded volume but NYMEX will be 500,000 for the day. I'm trading crude futures. I use DTN IQFEED. Thanks. Date Time Of Last Edit: 2016-09-23 04:00:18
[2016-09-23 04:27:55] |
Refer to help topic 43.7: https://www.sierrachart.com/index.php?page=doc/helpdetails43.html#h43.7 You will also want to make sure the Session Times are correct for the chart and include the full 24 hours: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
