Date/Time: Fri, 10 Jan 2025 16:32:15 +0000
SCDateTimeMS can not be used with SCDateTime& sc.GetPersistentSCDateTime
View Count: 796
[2016-09-22 15:00:38] |
marcovth - Posts: 61 |
Hello ... I would like to keep a SCDateTimeMS in memory, but I can't use SCDateTimeMS with SCDateTime& X= sc.GetPersistentSCDateTime(1); And sc.GetPersistentSCDateTimeMS doesn't seem to exist. Are there any alternatives? Thanks. |
[2016-09-22 17:05:44] |
We have explained this here: http://www.sierrachart.com/index.php?page=doc/SCDateTime.html#SCDateTimeMillisecondVariables Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-23 15:15:20] |
Thanks for the info. Can a SCFloatArrayRef Time = Arrays1.Arrays[1] field store a double, or only a float? Edit: I guess I figured it out ... SCDateTimeArrayRef this should then be an array of doubles? Date Time Of Last Edit: 2016-09-23 15:18:41
[2016-09-23 16:51:09] |
Only a float. SCDateTimeArrayRef this should then be an array of doubles? Yes, but this is not available for a study. Only for the main price graph and it is being used by the chart. You cannot change it.
