Date/Time: Fri, 10 Jan 2025 16:32:14 +0000
renk bars aligned to globex open
View Count: 1129
[2016-09-22 14:25:10] |
User175327 - Posts: 36 |
Hi, Is there a way to change the renko bars to print on globex open instead of the pre-set even numbers. For instance: a 5 tick renko in /cl prints at .05 and .10 increments on the round number such as 40.00, 40.05, 40.10...etc. Lets say globex opens at 40.02, is there a way to get them to print at 40.02, 40.07, 40.12...etc? Thanks, Joel |
[2016-09-22 17:09:27] |
This is not supported unless we were to add a new Bar Period Type. We will see about that.
[2016-09-22 17:38:22] |
Thanks. I know other charting platforms have that feature and it would be swell if Sierra did as well. Cheers, |
[2016-09-22 23:47:49] |
We will try to work this into the next release.
[2016-09-23 01:34:41] |
Super- Thanks again! |
[2016-09-26 17:12:39] |
Hey engineer team, Just wanted to say I have been using the new "unaligned renko" bars today on /CL. They are doing exactly what I asked for, filling according to the globex open!! Thanks so much! Great work, Joel |
