Date/Time: Fri, 10 Jan 2025 15:33:47 +0000
Last candle is underneth Custom Study and is not visible
View Count: 698
[2016-09-22 05:30:30] |
User550516 - Posts: 9 |
I am using a custom study and my last candle is underneath study and is not visible. I have checked the box that says for study to paint underneath main price graph. Any other ideals.
[2016-09-22 06:05:36] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
