Date/Time: Fri, 25 Sep 2026 03:10:43 +0000
Get day session start time in ASCIL
View Count: 4216
| [2016-09-22 04:55:52] |
| User763472 - Posts: 22 |
Dear Sir or Madam, How can I get the day session start time directly from ASCIL code? I tried the following but none work properly. Thanks! 1) SCDateTime StartingTime; StartingTime.SetTime(sc.StartTimeOfDay); int CurrentBarDate = DATE_PART(sc.BaseDateTimeIn[sc.Index]); SCDateTime StartingDateTime = COMBINE_DATE_TIME(CurrentBarDate, StartingTime); (Only work for Index future but not for currencies) 2) SCDateTime StartingDateTime = sc.GetTradingDayStartDateTimeOfBar(sc.BaseDateTimeIn[sc.Index]); 3) int StartingTime = sc.SessionStartTime(); int CurrentBarDate = DATE_PART(sc.BaseDateTimeIn[sc.Index]); SCDateTime StartingDateTime = COMBINE_DATE_TIME(CurrentBarDate, StartingTime); |
| [2016-09-22 06:01:36] |
You need to use this ACSIL member: ACSIL Interface Members - Variables and Arrays: sc.StartTime1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-09-22 07:30:52] |
I replaced it with sc.StartTime1 and the result is the same as using sc.StartTimeofDay: SCDateTime StartingTime; StartingTime.SetTime(sc.StartTime1); int CurrentBarDate = DATE_PART(sc.BaseDateTimeIn[sc.Index]); SCDateTime StartingDateTime = COMBINE_DATE_TIME(CurrentBarDate, StartingTime); It only works for Index futures but not for currencies. |
| [2016-09-22 16:50:15] |
Why do you say that it only works for index futures and not currencies? sc.StartTime1 is from the Session Times settings in Chart >> Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-09-23 01:58:10] |
Problem is solved. Need to add: SCDateTime StartingTime1; StartingTime1.SetTime(sc.StartTime1); int StartingTime = StartingTime1.GetTime(); |
