Date/Time: Fri, 10 Jan 2025 15:50:43 +0000
help daily chart long term
View Count: 706
[2016-09-21 14:23:55] |
User774114 - Posts: 18 |
Thanks for you time. I like to have a ES chart daily for the last year. But I dont had this, because maybe the change in futures contracts. How can I setup my charts ? thanks in advance. |
[2016-09-21 17:31:47] |
You need to use the Continuous Futures Contract feature: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
