Date/Time: Wed, 14 Oct 2026 15:51:37 +0000
Error compiling
View Count: 2266
| [2016-09-21 04:56:52] |
| User15952 - Posts: 137 |
C:\SierraChart\ACS_Source\Levels.cpp(7): fatal error C1083: Cannot open include file: 'unistd.h': No such file or directory I have never had this before |
| [2016-09-21 05:12:46] |
Is that header file being used in the source code file?
| [2016-09-21 05:58:07] |
All I did was recompile a previous cpp which was working. I changed the sc.FreeDLL = 1 And now I get that error. If I comment it out I get the error below; C:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" Levels.cpp C:\SierraChart\ACS_Source\Levels.cpp(165): warning C4244: '=': conversion from 'double' to 'float', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(183): warning C4244: '=': conversion from 'double' to 'int', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(196): warning C4244: '=': conversion from 'double' to 'int', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(209): warning C4244: '=': conversion from 'double' to 'int', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(254): warning C4244: '=': conversion from 'double' to 'int', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(354): warning C4244: '=': conversion from 'double' to 'int', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(391): warning C4244: '=': conversion from 'double' to 'float', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(406): warning C4244: '=': conversion from 'double' to 'float', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(433): warning C4244: '=': conversion from 'double' to 'int', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(446): warning C4244: '=': conversion from 'double' to 'int', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(459): warning C4244: '=': conversion from 'double' to 'int', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(475): warning C4244: '=': conversion from 'double' to 'int', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(595): warning C4244: '=': conversion from 'double' to 'int', possible loss of data C:\SierraChart\ACS_Source\Levels.cpp(659): error C3861: 'getline': identifier not found C:\SierraChart\ACS_Source\Levels.cpp(687): error C2039: 'getline': is not a member of 'std' C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE\algorithm(14): note: see declaration of 'std' C:\SierraChart\ACS_Source\Levels.cpp(687): error C3861: 'getline': identifier not found C:\SierraChart\ACS_Source\Levels.cpp(790): error C3861: 'getline': identifier not found C:\SierraChart\ACS_Source\Levels.cpp(824): error C2039: 'getline': is not a member of 'std' C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE\algorithm(14): note: see declaration of 'std' C:\SierraChart\ACS_Source\Levels.cpp(824): error C3861: 'getline': identifier not found -- End of Build -- 15:56:23 |
| [2016-09-21 06:01:54] |
Whether sc.FreeDLL = 1 is commented out or not, we do not see how that has any effect on the warnings or errors. It does not make any sense to us. You need to solve all of these. We do not provide programming help unless you are willing to pay for that time and we can allocate the time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-21 06:02:09
| [2016-09-21 06:29:24] |
You guys have obviously changed something, since I already have a complied dll from that exact code.
| [2016-09-21 06:36:32] |
You are the one who wrote the source code. We also do not develop the compilers that Sierra Chart uses. These compiler warnings and errors relate to your source code and the particular compiler being used. The only thing changed is that Sierra Chart now is using the Microsoft Visual C++ compiler. What the problem is, is not obvious to us for various reasons. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-21 06:37:21
| [2016-09-26 07:26:45] |
FYI - I just tried it on VERSION 1406 and IT WORKED!!! So it is something you guys have done in the updates. Seriously a lot of crap you guys talk about source code http://i.imgur.com/HIEtweL.png Date Time Of Last Edit: 2016-09-26 07:29:36
| [2016-09-26 07:41:06] |
No not at all: Seriously a lot of crap you guys talk about source code
There is nothing we possibly could have done ourselves. As we said, the latest versions of Sierra Chart are now using the Microsoft Visual C++ compiler. So you need to look at your source code and what it is doing, and resolve the problem. You need to change the source code. There is nothing we need to do. That should be obvious to you. Do you really think that we do not know what we are talking about? We thought you should be able to figure it out. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-26 07:42:42
| [2016-09-26 07:44:36] |
This is the error message you are getting: C:\SierraChart\ACS_Source\Levels.cpp(659): error C3861: 'getline': identifier not found So you need to ask yourself, what is the purpose of using this function and where does it exist? Is it a function that you defined? Is it a function in the standard C++ library? Therefore, are you including the correct header file? You need to check the reference material for it make sure you are using it properly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-26 07:45:00
| [2016-09-26 07:48:51] |
This keeps popping up as an issue with 1460 Cannot open include file: 'unistd.h No such problem exists with 1406, it compiles perfectly with no errors. I am happy to post youtube videos showing the different version and the way they compile, with errors and without. It is not just one cpp doing it |
| [2016-09-26 07:55:11] |
If you show us the headers that you are including at the top of your source code file and the one line of code that is causing this error: C:\SierraChart\ACS_Source\Levels.cpp(659): error C3861: 'getline': identifier not found We should then be able to tell you what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-09-26 07:55:48] |
This is not helpful for us: I am happy to post youtube videos showing the different version and the way they compile, with errors and without. It is not just one cpp doing it Refer to the prior post #11. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-26 08:00:03
