Date/Time: Fri, 10 Jan 2025 16:03:38 +0000
Historical data for F.US.X30?##
View Count: 1201
[2016-09-20 17:46:16] |
User60579 - Posts: 41 |
Hi there I have now been able to connect to CQG and download data for F.US.X30V16 OMXS30 Stockholm futures I tried to downlaod older contracts but couldnt find any historical data? In symbols settings I wasnt sure what Rollover rule to use... This symbol X30 has rollover every month and on the third friday. (number of days before rollover are not allways the same) Is it possibel to build a continious contract with this symbol? Cheers |
[2016-09-20 18:02:47] |
There is no further historical data available because CQG does not provide it.
[2016-09-20 18:39:12] |
Okej, there is no smart way I can import data from another source? If I use it and save my data, will I be able to slowly build a continious contract? Can I use the Automatically Rollover Futures Symbol option? Cheers |
[2016-09-20 18:46:58] |
All data that Sierra Chart downloads and receives in real-time is saved. So gradually more data will accumulate. You can import data: http://www.sierrachart.com/index.php?page=doc/ImportExport.html The Automatically Rollover Futures Symbol option does work with any futures symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
