Date/Time: Fri, 10 Jan 2025 15:45:05 +0000
New symbol in CQG
View Count: 878
[2016-09-19 14:51:22] |
User60579 - Posts: 41 |
I now have the "NASDAQ OMX Nordic Derivatives Non-Professional" feed via CQG/AMP connected to Sierra chart and I want to use this symbol: X30 OMX Stockholm 30 Index Futures NASDAQ OMX Do you need to add this to Sierra chart before I use it, I couldnt find it...? |
[2016-09-19 18:05:54] |
Yes we will need to add this. We will have this done before morning.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-19 18:06:06
[2016-09-20 16:35:16] |
I still couldnt find the symbol X30?(OMX Stockholm 30 Index Futures NASDAQ OMX? Have you added it? Cheers |
[2016-09-20 16:50:24] |
I found it, sorry for the extra post! Thanks guys! |
[2016-09-20 17:38:49] |
We apologize for the delay. We had not yet actually add this yet, but it sounds like it is already there. We will verify.
[2016-09-20 19:23:18] |
This symbol has now been added.
