Date/Time: Fri, 10 Jan 2025 14:08:32 +0000
Data feed
View Count: 768
[2016-09-19 11:23:26] |
User127554 - Posts: 2 |
Hi, I have recently purchased the service package 5 after expiring of my trial. Upon restart, I noticed that the I'm receiving real-time data for only some instruments. For example receiving the data for gold but not crude oil. I dont have a trading account that you support(like interactive brokers etc.)While looking at the exchange data feed page, I'm a little bit confused. To get the CFD and Forex real-time data will it be enough to activate the Real-time data connections which is 35 USD/month or do I have to also activate the "exchage" package as well? Thanks in advance Regards Fatih |
[2016-09-19 17:00:43] |
Real-time Forex and CFD data is provided. For futures data, refer to: http://www.sierrachart.com/index.php?page=doc/FuturesData.php And for real-time futures data, you do have to activate the exchanges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-20 12:03:55] |
Thanks. One more question; to get the market depth data for Crudeoil and Natural gas (Nymex exchange), I first need to activate a 1 real time data connection for 35usd/month and than activate "NYMEX, For professionals and users without a trading account" for 94.5usd/month.In this case I will get the market depth data for the Nymex, right? Thanks in advance Fatih |
[2016-09-20 17:58:03] |
This is correct.
