Date/Time: Fri, 10 Jan 2025 15:48:21 +0000
Wave File set up for alert not playing right
View Count: 1309
[2016-09-18 23:51:43]
User299392 - Posts: 216
So, I tried adding my personal wave (.WAV) file to an alert and I see another sound playing instead.
I also have attributed the right file in the Alerts tab inside Color bar based on ALert condition.
Any reason why?
[2016-09-19 16:21:57]
PLEASE HELP!
[2016-09-19 16:57:33]
Follow through the instructions here:
http://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertSoundSettings
Also use the "Test Sound" button to actually test the sound file.
Date Time Of Last Edit: 2016-09-19 16:58:40
[2016-09-19 18:32:42]
I followed it but my wav file plays in windows right but when tested within Sierra it plays a generic sound and not what is recorded in it.
Please help!
[2016-09-19 21:07:49]
Therefore it sounds as though there is some incompatibility. We do not know how to help with this.
Are you recording voice or some other sound?
[2016-09-20 11:57:44]
Yes, I am recording voice but it plays just well in the Windows PC but just not in Sierra.
Why doing think is this happening?
[2016-09-20 17:43:59]
The file must be incompatible.
Use the Text to Speech feature:
http://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#TextToSpeechAlerts
[2016-09-20 18:33:13]
Instead; can you not tell me how to make a .Wav file compatible?
[2016-09-21 13:08:43]
Any comment here without resorting to a chargeable solution of text to speech?
[2016-09-21 17:22:52]
No further comment.
[2016-09-21 17:42:17]
Which is to pay - Sierra.
I will coz the user provided wave file will not play. Sure, that helps!
[2016-09-21 18:34:35]
Sawtooth - Posts: 4147
-Is your .wav file located in your Sierra \AlertSounds folder?
-Have you assigned your .wav file to an Alert# at Global Settings >> General Settings >> Alerts/General3 tab?
-Have you selected the Alert Sound where the alert originates?
[2016-09-21 18:37:51]
1. Yes
2. Yes
3. Yes
[2016-09-21 18:45:35]
Try one of these:
http://download.cnet.com/s/text-to-wav/
[2016-09-21 20:30:42]
User297539 - Posts: 55
I create my .WAV here
http://www.fromtexttospeech.com/
And it works just fine
[2016-09-21 23:47:07]
Thanks a ton for this one -
In that may I ask if you have a way to convert this mp3 into a wav?
[2016-09-22 00:09:09]
Found a number of those online.
Thank you!
