Date/Time: Fri, 10 Jan 2025 14:12:41 +0000
CANNOT CONNECT - PLEASE HELP
View Count: 790
[2016-09-18 23:06:10]
User299392 - Posts: 216
LOG READS BELOW -
CQG FIX: Connecting to demo.cqgtrader.com. Port: 6925. | 2016-09-18 19:05:29
socket (0) | Resolved address demo.cqgtrader.com to IP 208.48.16.202. | 2016-09-18 19:05:29
socket (48) | Connected. | 2016-09-18 19:05:29
socket (48) | Starting TLS 1.2 connection. | 2016-09-18 19:05:29
socket (48) | SSL connection established. | 2016-09-18 19:05:29
CQG FIX: Sending the Logon message. | 2016-09-18 19:05:29
CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-09-18 19:05:29
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-18 19:05:29
socket (48) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-18 19:05:29
socket (48) | SSL has been shut down. | 2016-09-18 19:05:29
socket (48) | SSL object has been freed. SSL state is now disconnected. | 2016-09-18 19:05:29
socket (48) | Shutdown and closed. | 2016-09-18 19:05:29
CQG FIX: Disconnected. | 2016-09-18 19:05:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-18 19:05:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-18 19:05:29
CQG FIX Trading | Disconnected. | 2016-09-18 19:05:29
[2016-09-18 23:31:56]
Update Sierra Chart again with Help >> Download Prerelease.
After the new version is installed, make sure that Global Settings >> Data/Trade Service Settings >>Server is set the Live and not Demo.
Date Time Of Last Edit: 2016-09-18 23:32:58
[2016-09-18 23:40:47]
Got it.
Thank you!
PS: Looks like this was in the pre-release and I had not done it coz I did not know about it to be a part of the pre-release. This is where I always called for pre-release descriptions and I never find it.
[2016-09-18 23:48:58]
We will be updating the version notes for the latest prerelease, tomorrow.
[2016-09-18 23:52:22]
Ok; no problem.
Then obviously I would not have known about it.
Thanks again.
