Date/Time: Fri, 10 Jan 2025 16:02:19 +0000
period ohlc ?
View Count: 764
[2016-09-18 23:03:48] |
zippyzip - Posts: 293 |
i am getting a log message every sec , im not sure what its from can u maybe help me out , i have them only set to prev day - thanks
Private File |
[2016-09-18 23:34:50] |
Go to the Study Settings window for that Period OHLC-Variable Period study. Set the input for displaying debugging information to No.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-19 01:07:34
[2016-09-19 00:43:55] |
thank u , that was the issue appreciate the fast response
[2016-09-19 23:08:38] |
once more question on this indicator , is there a way to fix sunday nights data plots as on the daily , if set to use current period is set to NO to plot yest levels , it reverts back to sundays levels . even with autoskip period of no trading set to YES or if there is something in settings i can do please let me know , thanks |
[2016-09-20 18:00:41] |
You need to set the chart Session times so the Monday's trading session begins in Sunday by reversing the session times. Refer to: http://www.sierrachart.com/index.php?page=doc/SessionTimes.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
