Date/Time: Sat, 26 Apr 2025 09:48:28 +0000
Chart Graphic Settings Reset
View Count: 837
[2016-09-18 21:19:40]
6c7574686572 - Posts: 20
Is there a way to "reset" each chart's individual graphic settings to the current global graphic settings?
For example, most of my charts are using the global graphic setting, but individually they have very different graphic settings because of duplication, testing etc. Un-checking the "use global settings" and then trying to manually recreate the global settings for each chart will be very time consuming.
I want to be able to reset each chart to the global settings, with the intention of then using the individual settings to make a small change here and there.
Thank you.
[2016-09-18 21:47:43]
No, there is not other than to open a new chart.
