Date/Time: Fri, 10 Jan 2025 14:24:41 +0000
drawings won't erase
View Count: 628
[2016-09-17 20:24:09] |
User39850 - Posts: 20 |
I built a new chartbook and my initial chart was a range bar chart. I duplicated that chart multiple times and then changed the time frames in each chart. The original chart had some drawings on it and now they won't erase from any of the charts. I've tried erasing from the original manually and also with the EAL tool but nothing takes them off. Any suggestions?
[2016-09-18 01:19:40] |
Go to the chart and select Window >> Manage Chart Drawings. Do you see them listed there? If not, then they were copied from another chart. In this case refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
