Date/Time: Fri, 10 Jan 2025 13:30:22 +0000
Can Sierrachart supports back-testing and auto trading?
View Count: 611
[2016-09-17 04:32:19] |
benyeh1225 - Posts: 28 |
Hi Sir, Could you advise if Sierrachart supports back-testing and auto trading? I did not find the menu on Sierrachart platform for these two functions. Thank you CHI CHIN YEH |
[2016-09-17 10:50:08] |
Yes. This is fully supported. Refer to: Automated Trading Management Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
