Date/Time: Thu, 03 Apr 2025 10:28:51 +0000
ZenFire Connection.
View Count: 2373
[2013-03-20 15:48:11] |
ElmStreetTrader - Posts: 48 |
Hi there, I haven't used SC for quite some time, but have decided to start using it again and having trouble logging in to ZenFire. Software version: 955 | 2013-03-20 11:41:41 Current Service Package: 3 | 2013-03-20 11:41:41 Usage end date: 2013-04-20 | 2013-03-20 11:41:41 Sierra Chart Historical Data Service is included. | 2013-03-20 11:41:41 Active service: Zen-Fire | 2013-03-20 11:41:41 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-03-20 11:41:41 2013-03-20 11:41:41 Local computer clock time | 2013-03-20 11:41:41 2013-03-20 15:41:41 GMT time | 2013-03-20 11:41:41 2013-03-20 11:41:41 Time zone adjusted time | 2013-03-20 11:41:41 Time difference to server time: 2 seconds. | 2013-03-20 11:41:41 Program path: C:\SierraChart\ | 2013-03-20 11:41:41 Data Files path: C:\SierraChart\Data\ | 2013-03-20 11:41:41 OS Version Number: 6.1 | 2013-03-20 11:41:41 Your current service package does not support this function. Select Help >> Purchase to upgrade your package. | 2013-03-20 11:41:47 Your current service package does not support this function. Select Help >> Purchase to upgrade your package. | 2013-03-20 11:43:58 |
[2013-03-20 16:35:35] |
This has now been resolved. Please restart Sierra Chart.
[2013-03-20 16:37:48] |
Thank you.
