Date/Time: Fri, 10 Jan 2025 13:46:52 +0000
[User Discussion] - Color Bar based on Alert
View Count: 839
[2016-09-16 17:45:33] |
Crtfyd - Posts: 281 |
vs 1455 I have a study on Main graph "Color Bar based on Alert Condition" with "Value on High" as the Draw Style(ID32.SG1). I have another study on Main graph "Color Bar based on Alert Condition" with "Value on Low" as Draw Style(ID17.SG!). I wanted to have a 3rd study to Alert when these two studies values match. So I did a third study on Main graph "Color Bar based on Alert Condition" with an "ARROW" as Draw study where they were equal(ID17.SG1 = ID32.SG1). This doesn't work. Is there something in the study coding recognizing the actual "value" where it only recognizes a "symbol" (in this case a value symbol)so this would not work? _______________________ In other words. My first alert has a value noted on my Main graph of say (2115.75)on a High bar. A little later my 2nd study notes on my Main graph (2115.75) on the Low of bar. So the 3rd alert that references these two alerts "should" post an ARROW at the 2nd alert. =AND (ID17.SG1 = ID32.SG1) Correct? |
[2016-09-16 18:03:18] |
This is outside the scope of our support but we hope to offer service in the future to help with this for an extra cost.
[2016-09-16 18:11:20] |
One potential problem with comparisons is what is documented here: http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#ValueFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
