Date/Time: Fri, 10 Jan 2025 13:30:22 +0000
zig-zag drawing tool
View Count: 1267
[2016-09-16 11:58:33] |
hursthead - Posts: 28 |
hi, i drew zig-zag lines on the chart - not zig-zag study - and was wondering how i can get it to display the values? basically i am trying to draw a measured move on the price and cant seem to find one on the study unless its called something else? thanks. |
[2016-09-16 17:10:11] |
The only thing you can do is to use the Chart Calculator tool: http://www.sierrachart.com/index.php?page=doc/Tools.html#ChartCalculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
