Date/Time: Fri, 10 Jan 2025 13:48:08 +0000
Linking to Broker (UK) - What Brokers Recommeded
View Count: 1639
[2016-09-16 07:41:59] |
User186889 - Posts: 53 |
Hello Sierra I am a UK based person wishing to link to a reputable (Ideally UK) Forex Broker. I have contacted OANDA UK but they say that they do not have a connection with you. Therefore: - Q1. Is it correct that you do not connect with OANDA? Q2. If you do not connect with OANDA then what REPUTABLE and RELIABLE FX brokers do you have connections with for Sierra Charts (The DOM etc) Thanks Mark Date Time Of Last Edit: 2016-09-16 08:16:47
[2016-09-16 08:16:31] |
1. Yes this is correct. 2. Use LMAX: http://www.sierrachart.com/index.php?page=doc/LMAX.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
