Date/Time: Fri, 10 Jan 2025 13:12:48 +0000
crosshair not bidirectional on one specific chart
View Count: 789
[2016-09-16 02:45:47]
Willson - Posts: 176
When crosshair moves on chart "A", it should follow on all other charts, which it does except for chart "B" where no crosshair appears.
But if chart "B" is selected and the crosshair is moved within it, the cursor will follow in chart "A". It is thus not bi-directional.
Where can I look to correct this. So strange since it is bidirectional on all other chart combinations.
Regards,
Date Time Of Last Edit: 2016-09-16 02:48:57
[2016-09-16 05:47:32]
Possibly there is out of order timestamps in chart B:
Out of Order Timestamps Detected
Or the chart is not scrolled to the corresponding Date-Time range.
You may want to enable Tools >> Synchronize Charts.
