Date/Time: Fri, 10 Jan 2025 13:19:59 +0000
question on scaling the price axis on chart
View Count: 703
[2016-09-16 01:44:47] |
User900117 - Posts: 1 |
How do i keep the price increments consistent as the chart is moving forward through out the day? i find the increments change for example when markets are volatile. I trade the NQ and would like to just see it display as a consistent 1 full point increment.
[2016-09-16 05:46:12] |
You can set the Scale Increment through the Scale Settings for the chart: Chart Scale and Scale Adjusting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-16 05:46:22
