Date/Time: Fri, 10 Jan 2025 13:49:34 +0000
Remove a study from the STUDIES menu
View Count: 815
[2016-09-15 21:21:08]
bala - Posts: 74
How can I remove a study from the STUDIES menu. Please see the scenario
1. I have a study defined Mytest1.dll
2. It shows in the STUDIES menu so I can 'Add custom study' Mytest1.
3. I cannot make any change to the source code and recompile because the DLL is used by sierra even if not added to a chart study. I will have to close the chart and manually remove the DLL in order to compile again
Since a compile adds the study is there a drop study ( that will remove the DLL)
Many Thanks
[2016-09-16 05:54:25]
Refer to the instructions here:
https://www.sierrachart.com/index.php?page=doc/AdvancedCustomStudyInterfaceAndLanguage.php#ModifyingACSC
