Date/Time: Fri, 10 Jan 2025 13:28:32 +0000
Need some help with an indicator I am building
View Count: 764
[2016-09-15 21:03:58] |
User469312 - Posts: 97 |
Been having issues with an indicator I am building. I am using 2 normal indicators currently and when both are straddling close to plus or minus zero the bar changes color on the security. This I have down. what I am looking for help is I want to be able to scale the amount of bars it looks at: so an example is IF the 2 indicator's have been trading at +/- a few bps around zero for 3 (will want to either shorten to 2 or expand to more) Then the bar turns a different color. I know it's remedial, but I just keep getting errors. any help would be greatly appreciated. THIS is not in spread sheet mode.
[2016-09-16 05:56:18] |
Refer to this section about referring to Subgraph values at prior chart columns: Study/Chart Alerts And Scanning: Referencing Data Other Than on the Last Bar/Column In the Chart If you are getting a formula error, we need to know the specific formula and error you are getting. Or it could be that you are trying to do something that is just simply not supported and you need to use the Spreadsheet study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-16 05:56:38
