Date/Time: Fri, 10 Jan 2025 13:11:28 +0000
cancel all order when flat
View Count: 1787
[2016-09-15 07:15:40]
JingIt - Posts: 44
I don't use OCO order, I put order manually, is there anyway Sierrachart cancel all other order when my position flat.
[2016-09-15 17:57:48]
Yes. Refer to the documentation here for this:
http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#CancelingAnOrder
Date Time Of Last Edit: 2016-09-15 17:59:05
[2016-09-15 23:28:15]
JingIt - Posts: 44
Sorry, I meant all orders are cancelled automatically when position is flat (for example, target filled or stop out), no OCO
[2016-09-16 00:44:50]
We do not understand your question.
[2016-09-16 00:48:09]
JingIt - Posts: 44
Example: I have long position, i put stop and target order, when one of those order get filled, my position will be flat, but one of those order is still there as they are not OCO. In this situation, I want the dom cancel automatically all the order I put when my position is flat.
Hopefully you get my question now.
[2016-09-16 05:45:35]
You need to use the Attached Orders feature:
Attached Orders
Also refer to:
Order Types: Send Attached Orders - Position/Price
