Date/Time: Fri, 10 Jan 2025 13:36:46 +0000
can't show 4 hour chart fully
View Count: 1903
[2016-09-15 06:52:50]
JingIt - Posts: 44
I set the number of day to 99 days, I can set the chart to any time-frame, however, if I set to 4 hour chart, I can only see a few days left.
I'm using 1461 version, mini Nikkie 225 and CQG data feed. Thanks
You can see I can't scroll the horizontal bar to look back further.
Date Time Of Last Edit: 2016-09-15 06:53:57
imagedaily.png / V - Attached On 2016-09-15 06:52:29 UTC - Size: 58.43 KB - 267 views
image4hour_chart.png / V - Attached On 2016-09-15 06:52:33 UTC - Size: 38.21 KB - 243 views
[2016-09-15 17:12:02]
Your Sierra Chart account is expired. You need to log into this Support Board with Help >> Support Board so we can provide proper support to you.
In the 4 hour per bar chart you posted, we see a lot more than a few days there. What we see is about the history that is available for that symbol. There is not further history available.
[2016-09-15 23:36:23]
JingIt - Posts: 44
I'm using Sierra chart with AMP account. You can see that I can scroll back to see many days in daily but not many in intraday chart.
[2016-09-16 00:44:21]
Once again you need to use Help >> Support Board to log into the support board.
There is no further data available for that particular symbol in an Intraday chart.
Date Time Of Last Edit: 2016-09-16 00:45:09
