Date/Time: Thu, 26 Sep 2024 23:25:04 +0000
TPO Value Area Lines problem when first period is diffrent
View Count: 2086
[2013-07-23 22:13:25] |
wwwingman - Posts: 185 |
Hi, I use the TPO chart and set the first period to 40 mn (using 40 and 30 mn sub periods). Profile looks as expected, so is POC and Value. However, when I use the TPO Value Area Lines (on another chart), Value is not the same. This is normal, because in the TPO Value Area Lines uses periods of 30 minutes, and is therefor slightly different. Is it possible to add the sub periods to the TPO Value ? Or another type of solution ? Am I doing something wrong ? W. |
[2013-07-25 01:23:16] |
We needed some time to review this. We understand what the requirements are and this will be resolved in the next release. This will be automatically handled.
[2013-07-27 20:09:15] |
This is now solved in version 1000. Make sure when using the TPO Value Area Lines study the chart bars are set to 1 minute, 5 minutes or 10 minutes if you are using an odd session Start Time and 30 minute subperiod. This is essential for accuracy.
