Date/Time: Fri, 10 Jan 2025 13:21:50 +0000
Connection constantly closing and reestablishing
View Count: 709
[2016-09-14 21:05:00] |
User472677 - Posts: 356 |
Hello, I have separately sent you the message log with a comment. Please take a look at the log. I will appreciate your help in fixing this problem. thx |
[2016-09-15 06:06:19] |
The only help that we can offer is recommend using the Sierra Chart Exchange Data Feed for data: Sierra Chart Exchange Data Feed These are the relevant messages: HTTPS connection to ameritrade02.streamer.com:443 (568) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-14 16:53:14 HTTPS connection to ameritrade02.streamer.com:443 (571) | SSL connection closed by remote side. | 2016-09-14 16:55:13 We have no ability to resolve this. The TD Ameritrade data feed is not regarded as a reliable and dependable data feed by us. If it works, that is good if it is not working, and you depend upon it, then use another one. Although we are critical of Interactive Brokers, we have higher regard for Interactive Brokers in combination with the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-15 06:07:10
