Date/Time: Fri, 10 Jan 2025 13:14:25 +0000
aos backtesting
View Count: 828
[2016-09-14 17:41:12] |
User222821 - Posts: 21 |
Hi i have started accurate back test for my strategy dos, it seems to me that it takes a very very long time to proceed example 5000 days i have started 10hours ago and the progress show only 40%, is there any problem in setting or in system?¨thanks for help
[2016-09-14 18:28:15] |
Refer to: http://www.sierrachart.com/index.php?page=doc/Backtesting.php#ImprovingPerformanceOverall Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-15 05:17:48] |
thanks works fine now but if i make acurate replay it does not calculate all 300 days which I have set but it ends in march 2016 instead of september2016 |
[2016-09-15 05:41:54] |
We do not know how you come to that conclusion so it is impossible for us to comment on this. This sounds like a problem with your trading system itself. As long as you let a replay continue through to the end, all data is going to get replayed and the trading system will be evaluated across all the data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-15 13:22:30] |
ok I wil test it again if i want to replay it again the log appear Caught an unhandled exception in c_Chart::WindowProc. Message: 32769, wParam: 33811, lParam: 0 | 2016-09-15 15:19:30 * then i have to shut the sierra down and start again |
[2016-09-15 14:34:45] |
so I have tested again and it is stopping all the time in the same date 22:59:00 2016-03-10
[2016-09-15 14:49:03] |
i think i found it two month are missing in continuos graph march and april
[2016-09-15 17:15:36] |
Regarding this: Caught an unhandled exception in c_Chart::WindowProc. Message: 32769, wParam: 33811, lParam: 0 | 2016-09-15 15:19:30 * Refer to help topic 17: http://www.sierrachart.com/index.php?page=doc/helpdetails17.html Most likely this is caused by a custom study with a bug in it. If that is not the problem, how many chart windows do you have open? For the missing data issue, refer to: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-15 17:16:39
