Date/Time: Fri, 10 Jan 2025 12:55:59 +0000
First conection to CQG doesnt work...
View Count: 620
[2016-09-14 17:32:20]
User60579 - Posts: 41
Hi there!
I am trying to conect Sierra Charts with a CQG data feed from AMP... all help greatly appreciated!
I have already checked my CQG loginname with AMP and tested web API etc
I get this message log:
Reading Internal Order ID file. | 2016-09-14 19:11:47
Reading Trade Orders file. | 2016-09-14 19:11:47
Reading Trade Positions file. | 2016-09-14 19:11:47
Software version: 1453 | 2016-09-14 19:11:47
Uses New Spreadsheets | 2016-09-14 19:11:47
Usage end date: 2016-09-14 | 2016-09-14 19:11:47
Enabled for: Advanced Features. | 2016-09-14 19:11:47
Enabled for: Advanced Features 2. | 2016-09-14 19:11:47
Enabled for: Sierra Chart Historical Data Service. | 2016-09-14 19:11:47
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-09-14 19:11:47
Current selected Data/Trading service: CQG FIX Trading | 2016-09-14 19:11:47
Chart Update Interval: 500 | 2016-09-14 19:11:47
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2016-09-14 19:11:47
2016-09-14 19:11:50 Local computer time | 2016-09-14 19:11:47
2016-09-14 17:11:50 Local computer time in UTC | 2016-09-14 19:11:47
2016-09-14 19:11:50 Local computer time in SC Time Zone | 2016-09-14 19:11:47
2016-09-14 17:11:47 Server time in UTC | 2016-09-14 19:11:47
Local computer UTC time and Server UTC time difference: 2 seconds. | 2016-09-14 19:11:47
Program path: C:\SierraChart\ | 2016-09-14 19:11:47
Data Files path: C:\SierraChart\Data\ | 2016-09-14 19:11:47
OS Version Number: 6.2 | 2016-09-14 19:11:47
Locale Setting: C | 2016-09-14 19:11:47
Checking for new symbol settings for cqg | 2016-09-14 19:11:47
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-09-14 19:11:47
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-09-14 19:11:47
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-09-14 19:11:47
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-09-14 19:11:47
Symbol settings are up-to-date for cqg | 2016-09-14 19:11:47
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:11:55
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:11:55
socket (4) | Connected. | 2016-09-14 19:11:55
socket (4) | Starting TLS 1.2 connection. | 2016-09-14 19:11:55
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-09-14 19:11:55
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-09-14 19:11:55
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:11:55
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-09-14 19:11:55
socket (4) | SSL connection established. | 2016-09-14 19:11:56
CQG FIX: Sending the Logon message. | 2016-09-14 19:11:56
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:11:56
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:11:56
socket (4) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:11:56
socket (4) | SSL has been shut down. | 2016-09-14 19:11:56
socket (4) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:11:56
socket (4) | Shutdown and closed. | 2016-09-14 19:11:56
CQG FIX: Disconnected. | 2016-09-14 19:11:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:11:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:11:56
CQG FIX Trading | Disconnected. | 2016-09-14 19:11:56
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:11:56
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:11:59
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:11:59
socket (5) | Connected. | 2016-09-14 19:11:59
socket (5) | Starting TLS 1.2 connection. | 2016-09-14 19:11:59
socket (5) | SSL connection established. | 2016-09-14 19:12:00
CQG FIX: Sending the Logon message. | 2016-09-14 19:12:00
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:12:00
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:12:00
socket (5) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:12:00
socket (5) | SSL has been shut down. | 2016-09-14 19:12:00
socket (5) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:12:00
socket (5) | Shutdown and closed. | 2016-09-14 19:12:00
CQG FIX: Disconnected. | 2016-09-14 19:12:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:12:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:12:00
CQG FIX Trading | Disconnected. | 2016-09-14 19:12:00
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:12:00
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:12:03
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:12:03
socket (6) | Connected. | 2016-09-14 19:12:03
socket (6) | Starting TLS 1.2 connection. | 2016-09-14 19:12:03
socket (6) | SSL connection established. | 2016-09-14 19:12:04
CQG FIX: Sending the Logon message. | 2016-09-14 19:12:04
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:12:04
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:12:04
socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:12:04
socket (6) | SSL has been shut down. | 2016-09-14 19:12:04
socket (6) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:12:04
socket (6) | Shutdown and closed. | 2016-09-14 19:12:04
CQG FIX: Disconnected. | 2016-09-14 19:12:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:12:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:12:04
CQG FIX Trading | Disconnected. | 2016-09-14 19:12:04
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:12:04
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:12:07
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:12:07
socket (7) | Connected. | 2016-09-14 19:12:07
socket (7) | Starting TLS 1.2 connection. | 2016-09-14 19:12:07
socket (7) | SSL connection established. | 2016-09-14 19:12:08
CQG FIX: Sending the Logon message. | 2016-09-14 19:12:08
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:12:08
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:12:08
socket (7) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:12:08
socket (7) | SSL has been shut down. | 2016-09-14 19:12:08
socket (7) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:12:08
socket (7) | Shutdown and closed. | 2016-09-14 19:12:08
CQG FIX: Disconnected. | 2016-09-14 19:12:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:12:08
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:12:08
CQG FIX Trading | Disconnected. | 2016-09-14 19:12:08
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:12:08
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:12:11
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:12:11
socket (8) | Connected. | 2016-09-14 19:12:11
socket (8) | Starting TLS 1.2 connection. | 2016-09-14 19:12:11
socket (8) | SSL connection established. | 2016-09-14 19:12:12
CQG FIX: Sending the Logon message. | 2016-09-14 19:12:12
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:12:12
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:12:12
socket (8) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:12:12
socket (8) | SSL has been shut down. | 2016-09-14 19:12:12
socket (8) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:12:12
socket (8) | Shutdown and closed. | 2016-09-14 19:12:12
CQG FIX: Disconnected. | 2016-09-14 19:12:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:12:12
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:12:12
CQG FIX Trading | Disconnected. | 2016-09-14 19:12:12
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:12:12
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:12:15
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:12:15
socket (9) | Connected. | 2016-09-14 19:12:15
socket (9) | Starting TLS 1.2 connection. | 2016-09-14 19:12:15
socket (9) | SSL connection established. | 2016-09-14 19:12:16
CQG FIX: Sending the Logon message. | 2016-09-14 19:12:16
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:12:16
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:12:16
socket (9) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:12:16
socket (9) | SSL has been shut down. | 2016-09-14 19:12:16
socket (9) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:12:16
socket (9) | Shutdown and closed. | 2016-09-14 19:12:16
CQG FIX: Disconnected. | 2016-09-14 19:12:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:12:16
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:12:16
CQG FIX Trading | Disconnected. | 2016-09-14 19:12:16
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:12:16
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:12:19
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:12:19
socket (10) | Connected. | 2016-09-14 19:12:19
socket (10) | Starting TLS 1.2 connection. | 2016-09-14 19:12:19
socket (10) | SSL connection established. | 2016-09-14 19:12:20
CQG FIX: Sending the Logon message. | 2016-09-14 19:12:20
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:12:20
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:12:20
socket (10) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:12:20
socket (10) | SSL has been shut down. | 2016-09-14 19:12:20
socket (10) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:12:20
socket (10) | Shutdown and closed. | 2016-09-14 19:12:20
CQG FIX: Disconnected. | 2016-09-14 19:12:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:12:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:12:20
CQG FIX Trading | Disconnected. | 2016-09-14 19:12:20
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:12:20
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:12:23
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:12:23
socket (11) | Connected. | 2016-09-14 19:12:23
socket (11) | Starting TLS 1.2 connection. | 2016-09-14 19:12:23
socket (11) | SSL connection established. | 2016-09-14 19:12:24
CQG FIX: Sending the Logon message. | 2016-09-14 19:12:24
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:12:24
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:12:24
socket (11) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:12:24
socket (11) | SSL has been shut down. | 2016-09-14 19:12:24
socket (11) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:12:24
socket (11) | Shutdown and closed. | 2016-09-14 19:12:24
CQG FIX: Disconnected. | 2016-09-14 19:12:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:12:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:12:24
CQG FIX Trading | Disconnected. | 2016-09-14 19:12:24
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:12:24
File >> Disconnect selected. | 2016-09-14 19:12:25
CQG FIX Trading | Disconnected. | 2016-09-14 19:12:25
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:14:49
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:14:49
socket (13) | Connected. | 2016-09-14 19:14:49
socket (13) | Starting TLS 1.2 connection. | 2016-09-14 19:14:49
socket (13) | SSL connection established. | 2016-09-14 19:14:50
CQG FIX: Sending the Logon message. | 2016-09-14 19:14:50
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:14:50
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:14:50
socket (13) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:14:50
socket (13) | SSL has been shut down. | 2016-09-14 19:14:50
socket (13) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:14:50
socket (13) | Shutdown and closed. | 2016-09-14 19:14:50
CQG FIX: Disconnected. | 2016-09-14 19:14:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:14:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:14:50
CQG FIX Trading | Disconnected. | 2016-09-14 19:14:50
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:14:50
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:14:53
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:14:53
socket (14) | Connected. | 2016-09-14 19:14:53
socket (14) | Starting TLS 1.2 connection. | 2016-09-14 19:14:53
socket (14) | SSL connection established. | 2016-09-14 19:14:54
CQG FIX: Sending the Logon message. | 2016-09-14 19:14:54
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:14:54
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:14:54
socket (14) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:14:54
socket (14) | SSL has been shut down. | 2016-09-14 19:14:54
socket (14) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:14:54
socket (14) | Shutdown and closed. | 2016-09-14 19:14:54
CQG FIX: Disconnected. | 2016-09-14 19:14:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:14:54
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:14:54
CQG FIX Trading | Disconnected. | 2016-09-14 19:14:54
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:14:54
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:14:57
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:14:57
socket (15) | Connected. | 2016-09-14 19:14:57
socket (15) | Starting TLS 1.2 connection. | 2016-09-14 19:14:57
socket (15) | SSL connection established. | 2016-09-14 19:14:58
CQG FIX: Sending the Logon message. | 2016-09-14 19:14:58
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:14:58
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:14:58
socket (15) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:14:58
socket (15) | SSL has been shut down. | 2016-09-14 19:14:58
socket (15) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:14:58
socket (15) | Shutdown and closed. | 2016-09-14 19:14:58
CQG FIX: Disconnected. | 2016-09-14 19:14:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:14:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:14:58
CQG FIX Trading | Disconnected. | 2016-09-14 19:14:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:14:58
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:15:01
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:15:01
socket (16) | Connected. | 2016-09-14 19:15:01
socket (16) | Starting TLS 1.2 connection. | 2016-09-14 19:15:01
socket (16) | SSL connection established. | 2016-09-14 19:15:02
CQG FIX: Sending the Logon message. | 2016-09-14 19:15:02
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:15:02
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:15:02
socket (16) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:15:02
socket (16) | SSL has been shut down. | 2016-09-14 19:15:02
socket (16) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:15:02
socket (16) | Shutdown and closed. | 2016-09-14 19:15:02
CQG FIX: Disconnected. | 2016-09-14 19:15:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:15:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:15:02
CQG FIX Trading | Disconnected. | 2016-09-14 19:15:02
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:15:02
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:15:05
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:15:05
socket (17) | Connected. | 2016-09-14 19:15:05
socket (17) | Starting TLS 1.2 connection. | 2016-09-14 19:15:05
socket (17) | SSL connection established. | 2016-09-14 19:15:06
CQG FIX: Sending the Logon message. | 2016-09-14 19:15:06
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:15:06
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:15:06
socket (17) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:15:06
socket (17) | SSL has been shut down. | 2016-09-14 19:15:06
socket (17) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:15:06
socket (17) | Shutdown and closed. | 2016-09-14 19:15:06
CQG FIX: Disconnected. | 2016-09-14 19:15:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:15:06
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:15:06
CQG FIX Trading | Disconnected. | 2016-09-14 19:15:06
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:15:06
File >> Disconnect selected. | 2016-09-14 19:15:06
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:18:46
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:18:46
socket (20) | Connected. | 2016-09-14 19:18:47
socket (20) | Starting TLS 1.2 connection. | 2016-09-14 19:18:47
socket (20) | SSL connection established. | 2016-09-14 19:18:47
CQG FIX: Sending the Logon message. | 2016-09-14 19:18:47
CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-09-14 19:18:47
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:18:47
socket (20) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:18:47
socket (20) | SSL has been shut down. | 2016-09-14 19:18:47
socket (20) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:18:47
socket (20) | Shutdown and closed. | 2016-09-14 19:18:47
CQG FIX: Disconnected. | 2016-09-14 19:18:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:18:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:18:47
CQG FIX Trading | Disconnected. | 2016-09-14 19:18:47
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:18:47
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:18:50
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:18:50
socket (21) | Connected. | 2016-09-14 19:18:51
socket (21) | Starting TLS 1.2 connection. | 2016-09-14 19:18:51
socket (21) | SSL connection established. | 2016-09-14 19:18:51
CQG FIX: Sending the Logon message. | 2016-09-14 19:18:51
CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-09-14 19:18:51
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:18:51
socket (21) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:18:51
socket (21) | SSL has been shut down. | 2016-09-14 19:18:51
socket (21) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:18:51
socket (21) | Shutdown and closed. | 2016-09-14 19:18:51
CQG FIX: Disconnected. | 2016-09-14 19:18:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:18:51
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:18:51
CQG FIX Trading | Disconnected. | 2016-09-14 19:18:51
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:18:51
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:18:54
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:18:54
socket (22) | Connected. | 2016-09-14 19:18:54
socket (22) | Starting TLS 1.2 connection. | 2016-09-14 19:18:54
socket (22) | SSL connection established. | 2016-09-14 19:18:55
CQG FIX: Sending the Logon message. | 2016-09-14 19:18:55
CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-09-14 19:18:55
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:18:55
socket (22) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:18:55
socket (22) | SSL has been shut down. | 2016-09-14 19:18:55
socket (22) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:18:55
socket (22) | Shutdown and closed. | 2016-09-14 19:18:55
CQG FIX: Disconnected. | 2016-09-14 19:18:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:18:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:18:55
CQG FIX Trading | Disconnected. | 2016-09-14 19:18:55
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:18:55
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:18:58
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:18:58
socket (23) | Connected. | 2016-09-14 19:18:58
socket (23) | Starting TLS 1.2 connection. | 2016-09-14 19:18:58
socket (23) | SSL connection established. | 2016-09-14 19:18:59
CQG FIX: Sending the Logon message. | 2016-09-14 19:18:59
CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-09-14 19:18:59
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:18:59
socket (23) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:18:59
socket (23) | SSL has been shut down. | 2016-09-14 19:18:59
socket (23) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:18:59
socket (23) | Shutdown and closed. | 2016-09-14 19:18:59
CQG FIX: Disconnected. | 2016-09-14 19:18:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:18:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:18:59
CQG FIX Trading | Disconnected. | 2016-09-14 19:18:59
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:18:59
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:19:02
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:19:02
socket (24) | Connected. | 2016-09-14 19:19:02
socket (24) | Starting TLS 1.2 connection. | 2016-09-14 19:19:02
socket (24) | SSL connection established. | 2016-09-14 19:19:03
CQG FIX: Sending the Logon message. | 2016-09-14 19:19:03
CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-09-14 19:19:03
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:19:03
socket (24) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:19:03
socket (24) | SSL has been shut down. | 2016-09-14 19:19:03
socket (24) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:19:03
socket (24) | Shutdown and closed. | 2016-09-14 19:19:03
CQG FIX: Disconnected. | 2016-09-14 19:19:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:19:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:19:03
CQG FIX Trading | Disconnected. | 2016-09-14 19:19:03
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:19:03
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:19:06
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:19:06
socket (25) | Connected. | 2016-09-14 19:19:06
socket (25) | Starting TLS 1.2 connection. | 2016-09-14 19:19:06
socket (25) | SSL connection established. | 2016-09-14 19:19:07
CQG FIX: Sending the Logon message. | 2016-09-14 19:19:07
CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2016-09-14 19:19:07
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:19:07
socket (25) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:19:07
socket (25) | SSL has been shut down. | 2016-09-14 19:19:07
socket (25) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:19:07
socket (25) | Shutdown and closed. | 2016-09-14 19:19:07
CQG FIX: Disconnected. | 2016-09-14 19:19:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:19:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:19:07
CQG FIX Trading | Disconnected. | 2016-09-14 19:19:07
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:19:07
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:19:10
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:19:10
socket (26) | Connected. | 2016-09-14 19:19:10
socket (26) | Starting TLS 1.2 connection. | 2016-09-14 19:19:10
File >> Disconnect selected. | 2016-09-14 19:19:11
CQG FIX: DisconnectFIX called. | 2016-09-14 19:19:11
socket (26) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:19:11
socket (26) | Shutdown and closed. | 2016-09-14 19:19:11
CQG FIX: Disconnected. | 2016-09-14 19:19:11
CQG FIX Trading | Disconnected. | 2016-09-14 19:19:11
socket (0) | SSL connection timed out. | 2016-09-14 19:19:11 *
socket (0) | SSL connection failed. | 2016-09-14 19:19:11
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:20:31
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:20:31
socket (28) | Connected. | 2016-09-14 19:20:31
socket (28) | Starting TLS 1.2 connection. | 2016-09-14 19:20:31
socket (28) | SSL connection established. | 2016-09-14 19:20:31
CQG FIX: Sending the Logon message. | 2016-09-14 19:20:32
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:20:32
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:20:32
socket (28) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:20:32
socket (28) | SSL has been shut down. | 2016-09-14 19:20:32
socket (28) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:20:32
socket (28) | Shutdown and closed. | 2016-09-14 19:20:32
CQG FIX: Disconnected. | 2016-09-14 19:20:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:20:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:20:32
CQG FIX Trading | Disconnected. | 2016-09-14 19:20:32
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:20:32
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:20:35
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:20:35
socket (29) | Connected. | 2016-09-14 19:20:35
socket (29) | Starting TLS 1.2 connection. | 2016-09-14 19:20:35
socket (29) | SSL connection established. | 2016-09-14 19:20:35
CQG FIX: Sending the Logon message. | 2016-09-14 19:20:36
CQG FIX: Received a Logout message. Text = Too many logon attempts. Please contact your FCM. | 2016-09-14 19:20:36
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-14 19:20:36
socket (29) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-14 19:20:36
socket (29) | SSL has been shut down. | 2016-09-14 19:20:36
socket (29) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:20:36
socket (29) | Shutdown and closed. | 2016-09-14 19:20:36
CQG FIX: Disconnected. | 2016-09-14 19:20:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-14 19:20:36
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-14 19:20:36
CQG FIX Trading | Disconnected. | 2016-09-14 19:20:36
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-14 19:20:36
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2016-09-14 19:20:39
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214. | 2016-09-14 19:20:39
socket (30) | Connected. | 2016-09-14 19:20:39
socket (30) | Starting TLS 1.2 connection. | 2016-09-14 19:20:39
File >> Disconnect selected. | 2016-09-14 19:20:39
CQG FIX: DisconnectFIX called. | 2016-09-14 19:20:39
socket (30) | SSL object has been freed. SSL state is now disconnected. | 2016-09-14 19:20:39
socket (30) | Shutdown and closed. | 2016-09-14 19:20:39
CQG FIX: Disconnected. | 2016-09-14 19:20:39
CQG FIX Trading | Disconnected. | 2016-09-14 19:20:39
socket (0) | SSL connection timed out. | 2016-09-14 19:20:39 *
socket (0) | SSL connection failed. | 2016-09-14 19:20:39
[2016-09-14 20:20:49]
This is what we see:
Select File >> Disconnect.
Wait about 10 minutes and try connecting again with File >> Connect to Data Feed and post a copy of the Message Log again.
Also, you really should contact your broker for help with this because they are the ones who will be able to solve this problem for you. We cannot.
