Date/Time: Fri, 10 Jan 2025 13:43:17 +0000
Alert Problem
View Count: 694
[2016-09-14 15:30:14] |
wingz - Posts: 121 |
I have a simple Volume alert set on a 1 min ES chart......... =V>10000........I was just using the Alert 1 sound for the alert, and didn't care for it, so I changed the alert sound to Alert 2. Now, when the alert triggers, I'm getting both of the dang sounds. I tried deleting the alert altogether and putting back in but I'm still getting both sounds when the alert triggers. Can you please tell me how to get just the one alert sound please.
[2016-09-14 20:25:25] |
This sounds like the Alert Condition is set up on more than one chart. Refer to: http://www.sierrachart.com/index.php?page=doc/AlertsManager.html#DisablingAlertSounds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-15 13:29:59] |
You are correct. I had alerts on other charts. I didn't know that alerts sound from charts that are in chartbooks that I'm not actively looking at. Thanks.
