Date/Time: Fri, 10 Jan 2025 12:27:23 +0000
Study clarify: Chart bars without zero values
View Count: 737
[2016-09-14 09:52:28] |
User514370 - Posts: 62 |
Hello, I´d like to ask you for clarifying mentioned study. Couldn´t find any description in the technical refferences. What exactly show this study? It´s price bar difference (bar to bar)? Anyway, I´m looking for this kind of study, "delta" price bar study. Exists anything like that? Thank you! |
[2016-09-14 18:23:00] |
What exactly do you mean by "Delta". Typically this refers to a difference. So what difference do you want to calculate?
[2016-09-14 19:32:56] |
Exactly. Delta means difference. I would like to see difference (bullish or bearish) between previous and last price bar. Maybe Value Chart?
[2016-09-14 20:15:33] |
For this you need to use the Bar Difference study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s56 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-14 21:47:58] |
Yes, thank you. But this study shows net change only. I´m looking for study which shows increment or decrement in price in the similar way as Cumulative Delta Bars (Volume) does. The same just for price. Thank you. |
[2016-09-14 22:41:19] |
OK we are not understanding specifically what you are looking for then.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-14 22:41:36
