Date/Time: Fri, 10 Jan 2025 13:18:35 +0000
CQG MIT orders unsupported
View Count: 1200
[2016-09-14 07:21:18] |
Napoleon Dynamite - Posts: 54 Invalid SC Account Name. |
Hello, within your documentation, you state that Market If Touched are unsupported with the CQG connection. Is that a restriction forced by CQG or is there another reason it was not implemented ? I'm sad because it's my favourite type of orders to match backtests to real live trading results without divergence. By the way, you can add the following brokers that also offer CQG : RJO'Brien https://www.rjobrien.com NinjaTrader brokerage Date Time Of Last Edit: 2016-09-15 23:02:23
[2016-09-14 07:33:06] |
This is all CQG supports: enum Order_OrderType { Order_OrderType_MKT = 1, Order_OrderType_LMT = 2, Order_OrderType_STP = 3, Order_OrderType_STL = 4 }; Typically we will only list a broker if they request us to do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-14 09:45:11] |
Allright, what a shame on them. Can Sierra simulate MIT orders platform side locally instead of server/broker side ? It would be welcomed |
[2016-09-15 11:48:55] |
Up Can Sierra simulate MIT orders platform side locally instead of server/broker side ? It would be welcomed Sorry if it's a silly question |
[2016-09-15 18:51:56] |
Yes we can put together an order entry study to do this. We will see if we can do that quickly today.
[2016-09-15 19:34:05] |
This study has now been added. It is called "Trading: Market if Touched Order". This will be out in the next release. The source code is also provided. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-15 22:46:45] |
Thank you so much. Amazing service and work ethic. You guys are the best.
Date Time Of Last Edit: 2016-09-15 22:47:15
