Date/Time: Fri, 10 Jan 2025 12:29:25 +0000
Additional Chart Header Field
View Count: 817
[2016-09-14 06:03:34]
nicktrader - Posts: 725
For the Chart Header there is only available the field "Symbol". CQG is using "meaningless" symbol names.
Is it possible to add the field "Underlying Symbol" for the chart header?
imageUnderlying Symbol.png / V - Attached On 2016-09-14 05:59:03 UTC - Size: 18.97 KB - 245 views
[2016-09-14 07:35:14]
You need to add the "Description" field. It is available in Global Settings >> Customize Chart Header.
[2016-09-14 10:53:13]
I used the "Description" field first but the result was different.
I changed the field in "FDax" but the Chart Header says: Dax Index September 2016 H". Is it possible to change the "Description" field in "FDax"?
imageDescription.png / V - Attached On 2016-09-14 10:48:35 UTC - Size: 28.62 KB - 236 views
[2016-09-14 14:52:31]
No, the description field cannot be changed.
[2016-09-14 15:53:39]
Okay, I understand. In that case I'd like to ask again.
Date Time Of Last Edit: 2016-09-14 15:54:03
[2016-09-14 20:24:09]
This is not a field that we would add.
