Date/Time: Fri, 10 Jan 2025 12:24:00 +0000
Cannot add Custom study
View Count: 1744
[2016-09-13 00:48:59]
bala - Posts: 74
1. Created source (Mytest1.cpp)
2. Compiled the code (Mytest1.dll has been generated)
3. It is in C:\SierraChart\Data and can be seen in explorer
4. Trying to add study by - 'Analysis -> studies -> Add custom study' . My study doesn't show in any list.
Can you please help?
[2016-09-13 01:27:09]
How did you compile this file? Did you do it through Analysis >> Build Custom Studies DLL?
[2016-09-13 11:12:43]
bala - Posts: 74
That is correct - I did use " Analysis >> Build Custom Studies DLL".
Here is the screen output from latest compiling:
- Starting build of Custom Studies Source files: Mytest1.cpp. -- 06:06:43
C:\WINDOWS\system32\cmd.exe /C "C:\SierraChart\ACS_Source\VisualCCompile.Bat"
C:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat"
Mytest1.cpp
Creating library Mytest1.lib and object Mytest1.exp
Generating code
Finished generating code
-- End of Build -- 06:06:45
The above compile has created Mytest1.dll in C:\SierraChart\Data
(By the way it's a simple program to print "Hello World" into the log)
[2016-09-13 17:20:00]
Therefore, what this means is that either there was a problem reading the file which will be logged in the Message Log:
http://www.sierrachart.com/index.php?page=doc/MessageLog.html
Or there are no study functions contained within the DLL file.
All study functions must begin with scsf_
[2016-09-14 00:29:23]
bala - Posts: 74
I am impressed!
The problem was the function not being named scsf_XXXX.
I renamed the function and it wrote to the log file with "Hello World".
Thanks,
Bala
