Date/Time: Mon, 25 Nov 2024 18:29:39 +0000
Text To Speach Alert Cost
View Count: 866
[2016-09-12 17:40:52] |
jsoviero - Posts: 84 |
Please provide detail of the additional services balance necessary to try the Sierra Chart "Text To Speech" alerts feature. Thanks
[2016-09-12 21:43:44] |
Go to this page where the feature is activated: https://www.sierrachart.com/usercp.php?page=TTS The cost is shown there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-12 21:43:57
[2024-02-11 16:17:32] |
j4ytr4der_ - Posts: 938 |
Was just looking into this, is this feature now free? I don't see anything on the page linked here, regarding any cost.
[2024-02-11 19:25:17] |
Sierra_Chart Engineering - Posts: 17174 |
Yes it is free. And in the newer versions of Sierra Chart under Global Settings >> General Settings >> Alerts there is this new setting: Text to Play when this Alert Triggered where you can enter a short phrase which will be played when the alert number is triggered. The voice quality is going to be improved once we work with a new text-to-speech library. Right now it uses the Windows OS text-to-speech functionality. So depending upon your version of Windows the quality may already be very good. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-02-11 23:36:25
