Date/Time: Fri, 10 Jan 2025 12:34:45 +0000
Getting over charged for commissions
View Count: 702
[2016-09-12 17:30:59]
User638756 - Posts: 52
Im putting in orders , stop all with 3 targets. IB are charging me a total of 6 orders. The first one should be 300 but instead they are charging 100 , 100, 100, . Is there a different way I can put in the order?
[2016-09-12 21:42:18]
This is because there are three separate OCO Groups. This is explained here:
Attached Orders: OCO Group (Group)
You just need to use a single Target.
[2016-09-12 22:34:21]
Is there a way around that? Maybe entering an order without an attachment and then entering the OCO after?
[2016-09-13 00:17:23]
Yes there is a way around this.
What you need to do is submit the parent order without any Attached Orders, in the quantity that you require.
Once that order fills and you need to wait for it to fill, then you can submit the Attached Orders as explained in this section here:
Order Types: Send Attached Orders - Position/Price
Date Time Of Last Edit: 2016-09-13 00:17:50
