Date/Time: Fri, 10 Jan 2025 12:39:35 +0000
Opening bar volume study?
View Count: 734
[2016-09-12 14:19:29] |
User170575 - Posts: 221 |
Hello, Is there a study that can create a moving average of the volume at a certain time of day---like provide the volume for the first 5 minute bar at 9:35 and creates a moving average using that bar going back whatever days? Many thanks, Cj |
[2016-09-12 16:52:17] |
The best that is available would be the Volume by Price Study: https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php It can be set to display a single volume profile for a set time range. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-12 16:53:24
[2016-09-12 20:00:22] |
There actually is a way to do this---if you want to see what the volume is on the opening bar set the Session Times in the chart for that bar only. Fantastic program!!! |
[2016-09-12 20:32:52] |
This is good.
