Date/Time: Fri, 10 Jan 2025 14:28:54 +0000
QuoteBoard updating but Chart not forming bars--
View Count: 1370
[2016-09-12 13:39:00] |
User170575 - Posts: 221 |
Good morning, QuoteBoard seems fine---but chart not forming bars---though the price quote in the chart is updating. Ameritrade. Any thoughts? Thx, Cj |
[2016-09-12 16:29:24] |
Refer to help topic 3 for all of the possibilities: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-14 14:46:40] |
Good Mmorning--I am still having this issue--intraday charts wont form bars though the quote is updating to the right---I reviewed and the topic 3 and tried alot of it but not getting an improvement. Any thoughts? Thanks, CJ |
[2016-09-14 15:12:45] |
Set your current telephone number here: https://www.sierrachart.com/usercp.php?page=ManageAccountInfo Let us know when that is done and we will call and look into this with remote assistance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-14 15:12:59
[2016-09-14 15:22:50] |
updated
[2016-09-14 15:49:02] |
For the record, we called and there was not a problem with real-time chart updating at the moment but there is missing data from the open until about 10:35 AM US Eastern time today and that is an issue on our side which will be resolved after the close today or sooner if we can. Once the data is added in by us, just right-click in the chart before the missing data and select Delete and Download Data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-16 14:06:56] |
Good morning, Seemed flawless yesterday---but this morning all the charts say "Waiting to Download." The system is connected and the QB is updating. Thoughts appreciated, Cj |
[2016-09-16 16:42:34] |
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-16 16:53:34] |
it eventually started working but at least one of the charts is missing data even after deleting--thanks-and have a nice weekend Reading Internal Order ID file. | 2016-09-16 10:50:08 Reading Trade Orders file. | 2016-09-16 10:50:08 Reading Trade Positions file. | 2016-09-16 10:50:08 Software version: 1461 | 2016-09-16 10:50:08 Uses New Spreadsheets | 2016-09-16 10:50:08 Usage end date: 2016-09-27 | 2016-09-16 10:50:08 Enabled for: Advanced Features. | 2016-09-16 10:50:08 Enabled for: Sierra Chart Historical Data Service. | 2016-09-16 10:50:08 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-09-16 10:50:08 Current selected Data/Trading service: TD Ameritrade | 2016-09-16 10:50:08 Chart Update Interval: 50 | 2016-09-16 10:50:08 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-09-16 10:50:08 2016-09-16 10:50:12 Local computer time | 2016-09-16 10:50:08 2016-09-16 14:50:12 Local computer time in UTC | 2016-09-16 10:50:08 2016-09-16 10:50:12 Local computer time in SC Time Zone | 2016-09-16 10:50:08 2016-09-16 14:49:59 Server time in UTC | 2016-09-16 10:50:08 Local computer UTC time and Server UTC time difference: 12 seconds. | 2016-09-16 10:50:08 Program path: C:\SierraChart\ | 2016-09-16 10:50:08 Data Files path: C:\SierraChart\Data\ | 2016-09-16 10:50:08 OS Version Number: 6.2 | 2016-09-16 10:50:08 Locale Setting: C | 2016-09-16 10:50:08 Checking for new symbol settings for tda | 2016-09-16 10:50:08 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-09-16 10:50:08 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-09-16 10:50:08 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-09-16 10:50:08 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-09-16 10:50:08 Symbol settings are up-to-date for tda | 2016-09-16 10:50:13 Files to Open on Start up | Opening file: QUAD.cht | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for FB | 2016-09-16 10:50:15 FB 1 Min #1 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for TKAI | 2016-09-16 10:50:15 TKAI 1 Min #2 | Reloading chart. | 2016-09-16 10:50:15 Files to Open on Start up | Opening file: OFFICE.cht | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for CIE | 2016-09-16 10:50:15 CIE 1 Min #168 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for CIE | 2016-09-16 10:50:15 CIE Daily #1 | Reloading chart. | 2016-09-16 10:50:15 Files to Open on Start up | Opening file: FOCUS.cht | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for ABUS | 2016-09-16 10:50:15 ABUS 2 Min #1 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for ACIIQ | 2016-09-16 10:50:15 ACIIQ 2 Min #2 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for ADVM | 2016-09-16 10:50:15 ADVM 2 Min #3 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for AFMD | 2016-09-16 10:50:15 AFMD 2 Min #4 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for AMCN | 2016-09-16 10:50:15 AMCN 2 Min #6 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for AMPE | 2016-09-16 10:50:15 AMPE 2 Min #7 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for BAS | 2016-09-16 10:50:15 BAS 2 Min #9 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for BCEI | 2016-09-16 10:50:15 BCEI 2 Min #10 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for BTUUQ | 2016-09-16 10:50:15 BTUUQ 2 Min #13 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for CBYL | 2016-09-16 10:50:15 CBYL 2 Min #16 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for CHMA | 2016-09-16 10:50:15 CHMA 2 Min #19 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for CIE | 2016-09-16 10:50:15 CIE 2 Min #20 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for CLD | 2016-09-16 10:50:15 CLD 2 Min #22 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for CLF | 2016-09-16 10:50:15 CLF 2 Min #23 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for CXDC | 2016-09-16 10:50:15 CXDC 2 Min #28 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for DJIFF | 2016-09-16 10:50:15 DJIFF 2 Min #32 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for DMPI | 2016-09-16 10:50:15 DMPI 2 Min #33 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for DNAI | 2016-09-16 10:50:15 DNAI 2 Min #34 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for DRYS | 2016-09-16 10:50:15 DRYS 2 Min #35 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for ERS | 2016-09-16 10:50:15 ERS 2 Min #38 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for EVOK | 2016-09-16 10:50:15 EVOK 2 Min #40 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for EXAS | 2016-09-16 10:50:15 EXAS 2 Min #41 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for FES | 2016-09-16 10:50:15 FES 2 Min #43 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for FNMA | 2016-09-16 10:50:15 FNMA 2 Min #44 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for GRSH | 2016-09-16 10:50:15 GRSH 2 Min #49 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for GSAT | 2016-09-16 10:50:15 GSAT 2 Min #51 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for HPJ | 2016-09-16 10:50:15 HPJ 2 Min #54 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for IMGN | 2016-09-16 10:50:15 IMGN 2 Min #56 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for INFI | 2016-09-16 10:50:15 INFI 2 Min #58 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for KEM | 2016-09-16 10:50:15 KEM 2 Min #59 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for FB | 2016-09-16 10:50:15 FB 2 Min #63 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for MRNS | 2016-09-16 10:50:15 MRNS 2 Min #65 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for NEOT | 2016-09-16 10:50:15 NEOT 2 Min #68 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for NK | 2016-09-16 10:50:15 NK 2 Min #70 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for NKTR | 2016-09-16 10:50:15 NKTR 2 Min #71 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for NRP | 2016-09-16 10:50:15 NRP 2 Min #72 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for NUGT | 2016-09-16 10:50:15 NUGT 2 Min #73 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for ORIG | 2016-09-16 10:50:15 ORIG 2 Min #78 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for PIRS | 2016-09-16 10:50:15 PIRS 2 Min #81 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for PTX | 2016-09-16 10:50:15 PTX 2 Min #82 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for RPRX | 2016-09-16 10:50:15 RPRX 2 Min #84 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for SDRL | 2016-09-16 10:50:15 SDRL 2 Min #86 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for SORL | 2016-09-16 10:50:15 SORL 2 Min #88 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for STEM | 2016-09-16 10:50:15 STEM 2 Min #89 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for STV | 2016-09-16 10:50:15 STV 2 Min #90 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for SXC | 2016-09-16 10:50:15 SXC 2 Min #91 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for TDW | 2016-09-16 10:50:15 TDW 2 Min #92 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for THLD | 2016-09-16 10:50:15 THLD 2 Min #93 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for TKAI | 2016-09-16 10:50:15 TKAI 2 Min #94 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for TNXP | 2016-09-16 10:50:15 TNXP 2 Min #95 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for TRIL | 2016-09-16 10:50:15 TRIL 2 Min #96 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for UWTI | 2016-09-16 10:50:15 UWTI 2 Min #98 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for VRX | 2016-09-16 10:50:15 VRX 2 Min #99 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for VSLR | 2016-09-16 10:50:15 VSLR 2 Min #100 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for VTSI | 2016-09-16 10:50:15 VTSI 2 Min #101 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for VUZI | 2016-09-16 10:50:15 VUZI 2 Min #102 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for ZFGN | 2016-09-16 10:50:15 ZFGN 2 Min #103 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for ZX | 2016-09-16 10:50:15 ZX 2 Min #104 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for PSID | 2016-09-16 10:50:15 PSID 2 Min #106 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for CETX | 2016-09-16 10:50:15 CETX 2 Min #107 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for GRO | 2016-09-16 10:50:15 GRO 2 Min #109 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for BXC | 2016-09-16 10:50:15 BXC 2 Min #111 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for MGT | 2016-09-16 10:50:15 MGT 2 Min #57 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for RTRX | 2016-09-16 10:50:15 RTRX 2 Min #116 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for CMG | 2016-09-16 10:50:15 CMG 2 Min #118 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for FCX | 2016-09-16 10:50:15 FCX 2 Min #18 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for NVAX | 2016-09-16 10:50:15 NVAX 2 Min #37 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for AAPL | 2016-09-16 10:50:15 AAPL 2 Min #46 | Reloading chart. | 2016-09-16 10:50:15 TD Ameritrade | Using primary service for historical data for NFLX | 2016-09-16 10:50:15 NFLX 2 Min #77 | Reloading chart. | 2016-09-16 10:50:15 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-09-16 10:50:15 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-09-16 10:50:15 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 10:50:15 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-09-16 10:50:15 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-09-16 10:50:19 TD Ameritrade | Connecting. | 2016-09-16 10:50:20 TD Ameritrade | Logging in. (Step 1 of 3) | 2016-09-16 10:50:20 HTTP connection to www.sierrachart.com:80 (4) | Connected. | 2016-09-16 10:50:20 HTTPS connection to apis.tdameritrade.com:443 (0) | Resolved address apis.tdameritrade.com to IP 216.105.251.201. | 2016-09-16 10:50:20 HTTPS connection to apis.tdameritrade.com:443 (5) | Connected. | 2016-09-16 10:50:20 HTTPS connection to apis.tdameritrade.com:443 (5) | Starting TLS 1.0 connection. | 2016-09-16 10:50:20 Received Date-time from server. Delay adjusted UTC Date-time: 2016-09-16 14:50:07.669. Round-trip delay: 00:00:00.187 | 2016-09-16 10:50:20 Error setting the system Date-time. Windows error code 1314: A required privilege is not held by the client. | 2016-09-16 10:50:20 * HTTPS connection to apis.tdameritrade.com:443 (5) | SSL connection established. | 2016-09-16 10:50:20 TD Ameritrade | Authorized for streamer data. Account: 75*** | 2016-09-16 10:50:21 TD Ameritrade | Authorized for streamer data. Account: 75*** | 2016-09-16 10:50:21 TD Ameritrade | Authorized for streamer data. Account: 75*** | 2016-09-16 10:50:21 TD Ameritrade | Authorized for streamer data. Account: 75*** | 2016-09-16 10:50:21 TD Ameritrade | Authorized for streamer data. Account: 75*** | 2016-09-16 10:50:21 TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2016-09-16 10:50:21 TD Ameritrade | Requesting message key for account activity streamer (Step 3 of 3) | 2016-09-16 10:50:21 TD Ameritrade | Requesting account balance data. Connection will be complete once received. | 2016-09-16 10:50:21 TD Ameritrade | Connected to data and trading server. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: TERP. ID: 1 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: TERP. ID: 1 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TERP | 2016-09-16 10:50:22 Intraday data recording state for symbol TERP is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: BXC. ID: 2 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: BXC. ID: 2 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CLBS. ID: 3 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CLBS. ID: 3 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CPRX. ID: 4 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CPRX. ID: 4 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: COCP. ID: 5 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: COCP. ID: 5 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CHMA. ID: 6 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CHMA. ID: 6 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CTIC. ID: 7 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CTIC. ID: 7 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CMRX. ID: 8 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CMRX. ID: 8 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: IMGN. ID: 9 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: IMGN. ID: 9 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: MNKD. ID: 10 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: MNKD. ID: 10 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CIE. ID: 11 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CIE. ID: 11 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: MRTX. ID: 12 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: MRTX. ID: 12 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: FMCC. ID: 13 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: FMCC. ID: 13 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: FNMA. ID: 14 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: FNMA. ID: 14 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: VCEL. ID: 15 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: VCEL. ID: 15 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CBMX. ID: 16 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CBMX. ID: 16 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: MGT. ID: 17 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: MGT. ID: 17 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: REXX. ID: 18 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: REXX. ID: 18 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: STEM. ID: 19 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: STEM. ID: 19 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: MRNS. ID: 20 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: MRNS. ID: 20 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: INFI. ID: 21 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: INFI. ID: 21 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: NWBO. ID: 22 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: NWBO. ID: 22 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ACIIQ. ID: 23 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ACIIQ. ID: 23 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: DNAI. ID: 24 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: DNAI. ID: 24 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: PTX. ID: 25 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: PTX. ID: 25 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: MSTX. ID: 26 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: MSTX. ID: 26 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: APPS. ID: 27 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: APPS. ID: 27 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CJES. ID: 28 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CJES. ID: 28 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: IBB. ID: 29 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: IBB. ID: 29 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ADVM. ID: 30 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ADVM. ID: 30 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ERN. ID: 31 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ERN. ID: 31 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: TNXP. ID: 32 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: TNXP. ID: 32 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: BIOC. ID: 33 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: BIOC. ID: 33 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CLNT. ID: 34 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CLNT. ID: 34 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CGIX. ID: 35 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CGIX. ID: 35 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: AXAS. ID: 36 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: AXAS. ID: 36 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: SPY. ID: 37 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: SPY. ID: 37 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: NUGT. ID: 38 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: NUGT. ID: 38 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: TWER. ID: 39 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: TWER. ID: 39 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: TDW. ID: 40 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: TDW. ID: 40 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: LGCY. ID: 41 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: LGCY. ID: 41 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GALE. ID: 42 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GALE. ID: 42 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: AMD. ID: 43 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: AMD. ID: 43 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ETRM. ID: 44 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ETRM. ID: 44 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GBSN. ID: 45 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GBSN. ID: 45 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GSAT. ID: 46 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GSAT. ID: 46 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GSS. ID: 47 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GSS. ID: 47 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: LODE. ID: 48 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: LODE. ID: 48 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: NAVB. ID: 49 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: NAVB. ID: 49 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: VHC. ID: 50 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: VHC. ID: 50 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: EGI. ID: 51 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: EGI. ID: 51 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: MGH. ID: 52 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: MGH. ID: 52 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: SCYX. ID: 53 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: SCYX. ID: 53 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ARP. ID: 54 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ARP. ID: 54 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: AMPE. ID: 55 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: AMPE. ID: 55 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: EPRS. ID: 56 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: EPRS. ID: 56 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GBR. ID: 57 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GBR. ID: 57 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: TKAI. ID: 58 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: TKAI. ID: 58 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ADMP. ID: 59 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ADMP. ID: 59 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: BAA. ID: 60 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: BAA. ID: 60 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: TSRO. ID: 61 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: TSRO. ID: 61 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CERU. ID: 62 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CERU. ID: 62 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GLPW. ID: 63 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GLPW. ID: 63 | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TERP | 2016-09-16 10:50:22 Delaying start of download for TERP | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CMG. ID: 64 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CMG. ID: 64 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CMG | 2016-09-16 10:50:22 Intraday data recording state for symbol CMG is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TERP | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: FB. ID: 65 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: FB. ID: 65 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: FB | 2016-09-16 10:50:22 Intraday data recording state for symbol FB is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TERP | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TKAI | 2016-09-16 10:50:22 Intraday data recording state for symbol TKAI is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TERP | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ABUS. ID: 66 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ABUS. ID: 66 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ABUS | 2016-09-16 10:50:22 Intraday data recording state for symbol ABUS is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TERP | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: AMCN. ID: 67 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: AMCN. ID: 67 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: AMCN | 2016-09-16 10:50:22 Intraday data recording state for symbol AMCN is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TERP | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: BTUUQ. ID: 68 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: BTUUQ. ID: 68 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: BTUUQ | 2016-09-16 10:50:22 Intraday data recording state for symbol BTUUQ is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TERP | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for CIE | 2016-09-16 10:50:22 Intraday data recording state for symbol CIE is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CIE | 2016-09-16 10:50:22 Delaying start of download for CIE | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: DJIFF. ID: 69 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: DJIFF. ID: 69 | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for DJIFF | 2016-09-16 10:50:22 Intraday data recording state for symbol DJIFF is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CIE | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: FES. ID: 70 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: FES. ID: 70 | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for FES | 2016-09-16 10:50:22 Intraday data recording state for symbol FES is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CIE | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GSAT | 2016-09-16 10:50:22 Intraday data recording state for symbol GSAT is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TERP | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for INFI | 2016-09-16 10:50:22 Intraday data recording state for symbol INFI is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CIE | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for MRNS | 2016-09-16 10:50:22 Intraday data recording state for symbol MRNS is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CIE | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: NKTR. ID: 71 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: NKTR. ID: 71 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NKTR | 2016-09-16 10:50:22 Intraday data recording state for symbol NKTR is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TERP | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NUGT | 2016-09-16 10:50:22 Intraday data recording state for symbol NUGT is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TERP | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for PTX | 2016-09-16 10:50:22 Intraday data recording state for symbol PTX is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CIE | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: SXC. ID: 72 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: SXC. ID: 72 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: SXC | 2016-09-16 10:50:22 Intraday data recording state for symbol SXC is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TERP | 2016-09-16 10:50:22 HD Request # 2 | Downloading Intraday chart data for TERP to the file TERP.scid. Service: equities.us | 2016-09-16 10:50:22 HD Request # 2 | Download start Date-Time: 2016-09-16 10:49:32.000 | 2016-09-16 10:50:22 HD Request # 2 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:22 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: UWTI. ID: 73 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: UWTI. ID: 73 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: UWTI | 2016-09-16 10:50:22 Intraday data recording state for symbol UWTI is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ZFGN. ID: 74 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ZFGN. ID: 74 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZFGN | 2016-09-16 10:50:22 Intraday data recording state for symbol ZFGN is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CETX. ID: 75 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CETX. ID: 75 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CETX | 2016-09-16 10:50:22 Socket (6) | Connected. | 2016-09-16 10:50:22 HD Request # 2 | Sending historical data logon request message. | 2016-09-16 10:50:22 Intraday data recording state for symbol CETX is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CLD. ID: 76 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CLD. ID: 76 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CLD | 2016-09-16 10:50:22 Intraday data recording state for symbol CLD is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: DMPI. ID: 77 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: DMPI. ID: 77 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: DMPI | 2016-09-16 10:50:22 Intraday data recording state for symbol DMPI is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ERS. ID: 78 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ERS. ID: 78 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ERS | 2016-09-16 10:50:22 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:49:32. Record interval: 1. Symbol: TERP | 2016-09-16 10:50:22 Intraday data recording state for symbol ERS is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: HPJ. ID: 79 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: HPJ. ID: 79 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: HPJ | 2016-09-16 10:50:22 Intraday data recording state for symbol HPJ is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: KEM. ID: 80 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: KEM. ID: 80 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: KEM | 2016-09-16 10:50:22 Intraday data recording state for symbol KEM is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: NEOT. ID: 81 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: NEOT. ID: 81 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NEOT | 2016-09-16 10:50:22 HD Request # 2 | Decompressing data. | 2016-09-16 10:50:22 Intraday data recording state for symbol NEOT is set to download 'Pending'. | 2016-09-16 10:50:22 HD Request # 2 | Receiving Intraday data for TERP starting at 2016-09-15 10:49:19 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ORIG. ID: 82 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ORIG. ID: 82 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ORIG | 2016-09-16 10:50:22 Intraday data recording state for symbol ORIG is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for STEM | 2016-09-16 10:50:22 Intraday data recording state for symbol STEM is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CIE | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TDW | 2016-09-16 10:50:22 Intraday data recording state for symbol TDW is set to download 'Pending'. | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TNXP | 2016-09-16 10:50:22 Intraday data recording state for symbol TNXP is set to download 'Pending'. | 2016-09-16 10:50:22 Socket (6) | Shutdown and closed. | 2016-09-16 10:50:22 The network socket for historical data has been closed. | 2016-09-16 10:50:22 HD Request # 2 | Received 1242 records from 2016-09-15 10:49:19 to 2016-09-16 10:34:23 (23.8 hours) and wrote 0 records for TERP | 2016-09-16 10:50:22 HD Request # 2 | Intraday download COMPLETE for TERP. Completion time: 0s. Unique request ID: 1 | 2016-09-16 10:50:22 Removed historical data download ID 1 | 2016-09-16 10:50:22 Real-time Intraday chart data file updates started for TERP | 2016-09-16 10:50:22 Opened cached Intraday file: C:\SierraChart\Data\TERP.scid | 2016-09-16 10:50:22 Intraday chart data file opened for TERP | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for TERP | 2016-09-16 10:50:22 Intraday data recording state for symbol TERP is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CIE | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CMG | 2016-09-16 10:50:22 Delaying start of download for CMG | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: VTSI. ID: 83 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: VTSI. ID: 83 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: VTSI | 2016-09-16 10:50:22 Intraday data recording state for symbol VTSI is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CMG | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ZX. ID: 84 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ZX. ID: 84 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZX | 2016-09-16 10:50:22 Intraday data recording state for symbol ZX is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CMG | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: MGT | 2016-09-16 10:50:22 Intraday data recording state for symbol MGT is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CMG | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: FCX. ID: 85 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: FCX. ID: 85 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: FCX | 2016-09-16 10:50:22 Intraday data recording state for symbol FCX is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CMG | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: AAPL. ID: 86 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: AAPL. ID: 86 | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for AAPL | 2016-09-16 10:50:22 Intraday data recording state for symbol AAPL is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CIE | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for ACIIQ | 2016-09-16 10:50:22 Intraday data recording state for symbol ACIIQ is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CIE | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: AMPE | 2016-09-16 10:50:22 Intraday data recording state for symbol AMPE is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CMG | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CBYL. ID: 87 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CBYL. ID: 87 | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for CBYL | 2016-09-16 10:50:22 Intraday data recording state for symbol CBYL is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CIE | 2016-09-16 10:50:22 HD Request # 3 | Downloading Intraday chart data for CIE to the file CIE.scid. Service: tda | 2016-09-16 10:50:22 HD Request # 3 | Download start Date-Time: 2016-09-16 10:49:52.000 | 2016-09-16 10:50:22 HD Request # 3 | Requesting historical Minute data for the current day. | 2016-09-16 10:50:22 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: RPRX. ID: 88 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: RPRX. ID: 88 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RPRX | 2016-09-16 10:50:22 Intraday data recording state for symbol RPRX is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CMG | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: STV. ID: 89 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: STV. ID: 89 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: STV | 2016-09-16 10:50:22 Intraday data recording state for symbol STV is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CMG | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: THLD. ID: 90 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: THLD. ID: 90 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: THLD | 2016-09-16 10:50:22 Intraday data recording state for symbol THLD is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CMG | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: VRX. ID: 91 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: VRX. ID: 91 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: VRX | 2016-09-16 10:50:22 Intraday data recording state for symbol VRX is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CMG | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: VUZI. ID: 92 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: VUZI. ID: 92 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: VUZI | 2016-09-16 10:50:22 Intraday data recording state for symbol VUZI is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: CMG | 2016-09-16 10:50:22 HD Request # 4 | Downloading Intraday chart data for CMG to the file CMG.scid. Service: equities.us | 2016-09-16 10:50:22 HD Request # 4 | Download start Date-Time: 2016-09-16 09:47:47.000 | 2016-09-16 10:50:22 HD Request # 4 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:22 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GRO. ID: 93 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GRO. ID: 93 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GRO | 2016-09-16 10:50:22 Intraday data recording state for symbol GRO is set to download 'Pending'. | 2016-09-16 10:50:22 HTTPS connection to ameritrade02.streamer.com:443 (7) | Connected. | 2016-09-16 10:50:22 HTTPS connection to ameritrade02.streamer.com:443 (7) | Starting TLS 1.0 connection. | 2016-09-16 10:50:22 Socket (8) | Connected. | 2016-09-16 10:50:22 HD Request # 4 | Sending historical data logon request message. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: RTRX. ID: 94 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: RTRX. ID: 94 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTRX | 2016-09-16 10:50:22 Intraday data recording state for symbol RTRX is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: NFLX. ID: 95 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: NFLX. ID: 95 | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for NFLX | 2016-09-16 10:50:22 Intraday data recording state for symbol NFLX is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for CIE | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ADVM | 2016-09-16 10:50:22 Intraday data recording state for symbol ADVM is set to download 'Pending'. | 2016-09-16 10:50:22 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:47:47. Record interval: 1. Symbol: CMG | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: BAS. ID: 96 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: BAS. ID: 96 | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for BAS | 2016-09-16 10:50:22 Intraday data recording state for symbol BAS is set to download 'Pending'. | 2016-09-16 10:50:22 HD Request # 4 | Decompressing data. | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CHMA | 2016-09-16 10:50:22 HD Request # 4 | Receiving Intraday data for CMG starting at 2016-09-16 09:47:47 | 2016-09-16 10:50:22 Intraday data recording state for symbol CHMA is set to download 'Pending'. | 2016-09-16 10:50:22 HD Request # 4 | Timestamp of first Intraday data file record written: 2016-09-16 09:47:47 | 2016-09-16 10:50:22 Socket (8) | Shutdown and closed. | 2016-09-16 10:50:22 The network socket for historical data has been closed. | 2016-09-16 10:50:22 HD Request # 4 | Received 148 records from 2016-09-16 09:47:47 to 2016-09-16 10:35:09 (47.4 minutes) and wrote 148 records for CMG | 2016-09-16 10:50:22 HD Request # 4 | Intraday download COMPLETE for CMG. Completion time: 0s. Unique request ID: 2 | 2016-09-16 10:50:22 Removed historical data download ID 2 | 2016-09-16 10:50:22 Real-time Intraday chart data file updates started for CMG | 2016-09-16 10:50:22 Opened cached Intraday file: C:\SierraChart\Data\CMG.scid | 2016-09-16 10:50:22 Intraday chart data file opened for CMG | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for CMG | 2016-09-16 10:50:22 Intraday data recording state for symbol CMG is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: FB | 2016-09-16 10:50:22 Delaying start of download for FB | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CLF. ID: 97 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CLF. ID: 97 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CLF | 2016-09-16 10:50:22 Intraday data recording state for symbol CLF is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: FB | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for DNAI | 2016-09-16 10:50:22 Intraday data recording state for symbol DNAI is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: EVOK. ID: 98 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: EVOK. ID: 98 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: EVOK | 2016-09-16 10:50:22 Intraday data recording state for symbol EVOK is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: FB | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: FNMA | 2016-09-16 10:50:22 Intraday data recording state for symbol FNMA is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: FB | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: IMGN | 2016-09-16 10:50:22 Intraday data recording state for symbol IMGN is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: FB | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: NRP. ID: 99 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: NRP. ID: 99 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NRP | 2016-09-16 10:50:22 Intraday data recording state for symbol NRP is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: FB | 2016-09-16 10:50:22 HTTPS connection to ameritrade02.streamer.com:443 (7) | SSL connection established. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: TRIL. ID: 100 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: TRIL. ID: 100 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: TRIL | 2016-09-16 10:50:22 Intraday data recording state for symbol TRIL is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: FB | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: VSLR. ID: 101 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: VSLR. ID: 101 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: VSLR | 2016-09-16 10:50:22 Intraday data recording state for symbol VSLR is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: FB | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: PSID. ID: 102 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: PSID. ID: 102 | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for PSID | 2016-09-16 10:50:22 Intraday data recording state for symbol PSID is set to download 'Pending'. | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: BXC | 2016-09-16 10:50:22 Intraday data recording state for symbol BXC is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: FB | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: NVAX. ID: 103 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: NVAX. ID: 103 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NVAX | 2016-09-16 10:50:22 Intraday data recording state for symbol NVAX is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: FB | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: AFMD. ID: 104 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: AFMD. ID: 104 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: AFMD | 2016-09-16 10:50:22 Intraday data recording state for symbol AFMD is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: FB | 2016-09-16 10:50:22 HD Request # 5 | Downloading Intraday chart data for FB to the file FB.scid. Service: equities.us | 2016-09-16 10:50:22 HD Request # 5 | Download start Date-Time: 2016-09-16 10:49:58.000 | 2016-09-16 10:50:22 HD Request # 5 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:22 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: BCEI. ID: 105 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: BCEI. ID: 105 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: BCEI | 2016-09-16 10:50:22 Intraday data recording state for symbol BCEI is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CXDC. ID: 106 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CXDC. ID: 106 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CXDC | 2016-09-16 10:50:22 Intraday data recording state for symbol CXDC is set to download 'Pending'. | 2016-09-16 10:50:22 Socket (9) | Connected. | 2016-09-16 10:50:22 HD Request # 5 | Sending historical data logon request message. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: DRYS. ID: 107 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: DRYS. ID: 107 | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for DRYS | 2016-09-16 10:50:22 Intraday data recording state for symbol DRYS is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: EXAS. ID: 108 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: EXAS. ID: 108 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: EXAS | 2016-09-16 10:50:22 Intraday data recording state for symbol EXAS is set to download 'Pending'. | 2016-09-16 10:50:22 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:49:58. Record interval: 1. Symbol: FB | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GRSH. ID: 109 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GRSH. ID: 109 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GRSH | 2016-09-16 10:50:22 Intraday data recording state for symbol GRSH is set to download 'Pending'. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: NK. ID: 110 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: NK. ID: 110 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NK | 2016-09-16 10:50:22 Intraday data recording state for symbol NK is set to download 'Pending'. | 2016-09-16 10:50:22 HD Request # 5 | Decompressing data. | 2016-09-16 10:50:22 Socket (9) | Shutdown and closed. | 2016-09-16 10:50:22 The network socket for historical data has been closed. | 2016-09-16 10:50:22 HD Request # 5 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FB | 2016-09-16 10:50:22 HD Request # 5 | Intraday download COMPLETE for FB. Completion time: 0s. Unique request ID: 3 | 2016-09-16 10:50:22 Removed historical data download ID 3 | 2016-09-16 10:50:22 Real-time Intraday chart data file updates started for FB | 2016-09-16 10:50:22 Opened cached Intraday file: C:\SierraChart\Data\FB.scid | 2016-09-16 10:50:22 Intraday chart data file opened for FB | 2016-09-16 10:50:22 TD Ameritrade | Using primary service for historical data for FB | 2016-09-16 10:50:22 Intraday data recording state for symbol FB is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TKAI | 2016-09-16 10:50:22 Delaying start of download for TKAI | 2016-09-16 10:50:22 HTTPS connection to ameritrade02.streamer.com:443 (7) | SSL connection closed by remote side. | 2016-09-16 10:50:22 HTTPS connection to ameritrade02.streamer.com:443 (7) | Connection gracefully closed by remote side. | 2016-09-16 10:50:22 HTTPS connection to ameritrade02.streamer.com:443 (7) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 10:50:22 HTTPS connection to ameritrade02.streamer.com:443 (7) | Shutdown and closed. | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: PIRS. ID: 111 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: PIRS. ID: 111 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: PIRS | 2016-09-16 10:50:22 Intraday data recording state for symbol PIRS is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TKAI | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: SDRL. ID: 112 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: SDRL. ID: 112 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: SDRL | 2016-09-16 10:50:22 Intraday data recording state for symbol SDRL is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TKAI | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: SORL. ID: 113 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: SORL. ID: 113 | 2016-09-16 10:50:22 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: SORL | 2016-09-16 10:50:22 Intraday data recording state for symbol SORL is set to download 'Pending'. | 2016-09-16 10:50:22 Market data subscription status is not known while delaying historical data download for symbol: TKAI | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CHK. ID: 114 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CHK. ID: 114 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ONVO. ID: 115 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ONVO. ID: 115 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: OREX. ID: 116 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: OREX. ID: 116 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: NG. ID: 117 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: NG. ID: 117 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: EGO. ID: 118 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: EGO. ID: 118 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: SKLN. ID: 119 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: SKLN. ID: 119 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: NXTD. ID: 120 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: NXTD. ID: 120 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: OXIS. ID: 121 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: OXIS. ID: 121 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ALIM. ID: 122 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ALIM. ID: 122 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: AEZS. ID: 123 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: AEZS. ID: 123 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: XENE. ID: 124 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: XENE. ID: 124 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GNRT. ID: 125 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GNRT. ID: 125 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: OGXI. ID: 126 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: OGXI. ID: 126 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CPHI. ID: 127 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CPHI. ID: 127 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: PIP. ID: 128 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: PIP. ID: 128 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: BGI. ID: 129 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: BGI. ID: 129 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: DGSE. ID: 130 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: DGSE. ID: 130 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: RNVA. ID: 131 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: RNVA. ID: 131 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GST. ID: 132 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GST. ID: 132 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GBIM. ID: 133 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GBIM. ID: 133 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: KGJI. ID: 134 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: KGJI. ID: 134 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: ALJ. ID: 135 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: ALJ. ID: 135 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CREG. ID: 136 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CREG. ID: 136 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: CBAK. ID: 137 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: CBAK. ID: 137 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: DELT. ID: 138 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: DELT. ID: 138 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: DELTW. ID: 139 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: DELTW. ID: 139 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GRSHW. ID: 140 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GRSHW. ID: 140 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: BVX. ID: 141 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: BVX. ID: 141 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: MIFI. ID: 142 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: MIFI. ID: 142 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: GLD. ID: 143 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: GLD. ID: 143 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: WPRT. ID: 144 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: WPRT. ID: 144 | 2016-09-16 10:50:22 TD Ameritrade | Starting real-time market data updates for: AKS. ID: 145 | 2016-09-16 10:50:22 TD Ameritrade | Requesting security definition data for: AKS. ID: 145 | 2016-09-16 10:50:22 HTTPS connection to ameritrade02.streamer.com:443 (0) | SSL connection timed out. | 2016-09-16 10:50:23 * HTTPS connection to ameritrade02.streamer.com:443 (0) | SSL connection failed. | 2016-09-16 10:50:23 Market data subscription status is not known while delaying historical data download for symbol: TKAI | 2016-09-16 10:50:24 TD Ameritrade | Streamer request #1 initiated. | 2016-09-16 10:50:24 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 10:50:24 HTTPS connection to ameritrade02.streamer.com:443 (10) | Connected. | 2016-09-16 10:50:24 HTTPS connection to ameritrade02.streamer.com:443 (10) | Starting TLS 1.0 connection. | 2016-09-16 10:50:24 HTTPS connection to ameritrade02.streamer.com:443 (10) | SSL connection established. | 2016-09-16 10:50:24 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-3 | 2016-09-16 10:50:24 HTTP connection to www.sierrachart.com:80 (4) | Closed. No error. | 2016-09-16 10:50:25 HTTP connection to www.sierrachart.com:80 (4) | Shutdown and closed. | 2016-09-16 10:50:25 Delaying start of download for TKAI | 2016-09-16 10:50:25 HD Request # 6 | Downloading Intraday chart data for TKAI to the file TKAI.scid. Service: equities.us | 2016-09-16 10:50:27 HD Request # 6 | Download start Date-Time: 2016-09-16 10:49:22.000 | 2016-09-16 10:50:27 HD Request # 6 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:27 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:27 Socket (11) | Connected. | 2016-09-16 10:50:27 HD Request # 6 | Sending historical data logon request message. | 2016-09-16 10:50:27 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:49:22. Record interval: 1. Symbol: TKAI | 2016-09-16 10:50:27 HD Request # 6 | Decompressing data. | 2016-09-16 10:50:27 HD Request # 6 | Receiving Intraday data for TKAI starting at 2016-09-15 10:49:09 | 2016-09-16 10:50:27 Socket (11) | Shutdown and closed. | 2016-09-16 10:50:27 The network socket for historical data has been closed. | 2016-09-16 10:50:27 HD Request # 6 | Received 2437 records from 2016-09-15 10:49:09 to 2016-09-16 10:34:47 (23.8 hours) and wrote 0 records for TKAI | 2016-09-16 10:50:27 HD Request # 6 | Intraday download COMPLETE for TKAI. Completion time: 0s. Unique request ID: 4 | 2016-09-16 10:50:27 Removed historical data download ID 4 | 2016-09-16 10:50:27 Real-time Intraday chart data file updates started for TKAI | 2016-09-16 10:50:27 Opened cached Intraday file: C:\SierraChart\Data\TKAI.scid | 2016-09-16 10:50:27 Intraday chart data file opened for TKAI | 2016-09-16 10:50:27 TD Ameritrade | Using primary service for historical data for TKAI | 2016-09-16 10:50:27 Intraday data recording state for symbol TKAI is set to download 'Pending'. | 2016-09-16 10:50:27 HD Request # 7 | Downloading Intraday chart data for ABUS to the file ABUS.scid. Service: equities.us | 2016-09-16 10:50:27 HD Request # 7 | Download start Date-Time: 2016-09-16 10:47:38.000 | 2016-09-16 10:50:27 HD Request # 7 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:27 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:27 Socket (12) | Connected. | 2016-09-16 10:50:27 HD Request # 7 | Sending historical data logon request message. | 2016-09-16 10:50:27 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:47:38. Record interval: 1. Symbol: ABUS | 2016-09-16 10:50:27 HD Request # 7 | Decompressing data. | 2016-09-16 10:50:27 HD Request # 7 | Receiving Intraday data for ABUS starting at 2016-09-15 10:49:23 | 2016-09-16 10:50:27 Socket (12) | Shutdown and closed. | 2016-09-16 10:50:27 The network socket for historical data has been closed. | 2016-09-16 10:50:27 HD Request # 7 | Received 132 records from 2016-09-15 10:49:23 to 2016-09-16 10:34:51 (23.8 hours) and wrote 0 records for ABUS | 2016-09-16 10:50:27 HD Request # 7 | Intraday download COMPLETE for ABUS. Completion time: 0s. Unique request ID: 5 | 2016-09-16 10:50:27 Removed historical data download ID 5 | 2016-09-16 10:50:27 Real-time Intraday chart data file updates started for ABUS | 2016-09-16 10:50:27 Opened cached Intraday file: C:\SierraChart\Data\ABUS.scid | 2016-09-16 10:50:27 Intraday chart data file opened for ABUS | 2016-09-16 10:50:27 TD Ameritrade | Using primary service for historical data for ABUS | 2016-09-16 10:50:27 Intraday data recording state for symbol ABUS is set to download 'Pending'. | 2016-09-16 10:50:27 HD Request # 8 | Downloading Intraday chart data for AMCN to the file AMCN.scid. Service: equities.us | 2016-09-16 10:50:27 HD Request # 8 | Download start Date-Time: 2016-09-16 09:40:01.000 | 2016-09-16 10:50:27 HD Request # 8 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:27 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:27 Socket (13) | Connected. | 2016-09-16 10:50:27 HD Request # 8 | Sending historical data logon request message. | 2016-09-16 10:50:27 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:40:01. Record interval: 1. Symbol: AMCN | 2016-09-16 10:50:27 HD Request # 8 | Decompressing data. | 2016-09-16 10:50:28 HD Request # 8 | Receiving Intraday data for AMCN starting at 2016-09-16 09:40:01 | 2016-09-16 10:50:28 HD Request # 8 | Timestamp of first Intraday data file record written: 2016-09-16 09:40:01 | 2016-09-16 10:50:28 Socket (13) | Shutdown and closed. | 2016-09-16 10:50:28 The network socket for historical data has been closed. | 2016-09-16 10:50:28 HD Request # 8 | Received 7 records from 2016-09-16 09:40:01 to 2016-09-16 10:25:49 (45.8 minutes) and wrote 7 records for AMCN | 2016-09-16 10:50:28 HD Request # 8 | Intraday download COMPLETE for AMCN. Completion time: 0s. Unique request ID: 6 | 2016-09-16 10:50:28 Removed historical data download ID 6 | 2016-09-16 10:50:28 Real-time Intraday chart data file updates started for AMCN | 2016-09-16 10:50:28 Opened cached Intraday file: C:\SierraChart\Data\AMCN.scid | 2016-09-16 10:50:28 Intraday chart data file opened for AMCN | 2016-09-16 10:50:28 TD Ameritrade | Using primary service for historical data for AMCN | 2016-09-16 10:50:28 Intraday data recording state for symbol AMCN is set to download 'Pending'. | 2016-09-16 10:50:28 HD Request # 9 | Downloading Intraday chart data for BTUUQ to the file BTUUQ.scid. Service: equities.us | 2016-09-16 10:50:28 HD Request # 9 | Download start Date-Time: 2016-09-16 10:42:44.000 | 2016-09-16 10:50:28 HD Request # 9 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:28 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:28 Socket (14) | Connected. | 2016-09-16 10:50:28 HD Request # 9 | Sending historical data logon request message. | 2016-09-16 10:50:28 HD Request # 9 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:42:44. Record interval: 1. Symbol: BTUUQ | 2016-09-16 10:50:28 HD Request # 9 | Decompressing data. | 2016-09-16 10:50:28 Socket (14) | Shutdown and closed. | 2016-09-16 10:50:28 The network socket for historical data has been closed. | 2016-09-16 10:50:28 HD Request # 9 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for BTUUQ | 2016-09-16 10:50:28 HD Request # 9 | Intraday download COMPLETE for BTUUQ. Completion time: 0s. Unique request ID: 7 | 2016-09-16 10:50:28 Removed historical data download ID 7 | 2016-09-16 10:50:28 Real-time Intraday chart data file updates started for BTUUQ | 2016-09-16 10:50:28 Opened cached Intraday file: C:\SierraChart\Data\BTUUQ.scid | 2016-09-16 10:50:28 Intraday chart data file opened for BTUUQ | 2016-09-16 10:50:28 TD Ameritrade | Using primary service for historical data for BTUUQ | 2016-09-16 10:50:28 Intraday data recording state for symbol BTUUQ is set to download 'Pending'. | 2016-09-16 10:50:28 HD Request # 10 | Downloading Intraday chart data for GSAT to the file GSAT.scid. Service: equities.us | 2016-09-16 10:50:28 HD Request # 10 | Download start Date-Time: 2016-09-16 10:49:40.000 | 2016-09-16 10:50:28 HD Request # 10 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:28 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:28 Socket (15) | Connected. | 2016-09-16 10:50:28 HD Request # 10 | Sending historical data logon request message. | 2016-09-16 10:50:28 HD Request # 10 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:49:40. Record interval: 1. Symbol: GSAT | 2016-09-16 10:50:28 HD Request # 10 | Decompressing data. | 2016-09-16 10:50:28 Socket (15) | Shutdown and closed. | 2016-09-16 10:50:28 The network socket for historical data has been closed. | 2016-09-16 10:50:28 HD Request # 10 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GSAT | 2016-09-16 10:50:28 HD Request # 10 | Intraday download COMPLETE for GSAT. Completion time: 0s. Unique request ID: 11 | 2016-09-16 10:50:28 Removed historical data download ID 11 | 2016-09-16 10:50:28 Real-time Intraday chart data file updates started for GSAT | 2016-09-16 10:50:28 Opened cached Intraday file: C:\SierraChart\Data\GSAT.scid | 2016-09-16 10:50:28 Intraday chart data file opened for GSAT | 2016-09-16 10:50:28 TD Ameritrade | Using primary service for historical data for GSAT | 2016-09-16 10:50:28 Intraday data recording state for symbol GSAT is set to download 'Pending'. | 2016-09-16 10:50:28 HD Request # 11 | Downloading Intraday chart data for NKTR to the file NKTR.scid. Service: equities.us | 2016-09-16 10:50:28 HD Request # 11 | Download start Date-Time: 2016-09-16 09:47:42.000 | 2016-09-16 10:50:28 HD Request # 11 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:28 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:28 Socket (16) | Connected. | 2016-09-16 10:50:28 HD Request # 11 | Sending historical data logon request message. | 2016-09-16 10:50:28 HD Request # 11 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:47:42. Record interval: 1. Symbol: NKTR | 2016-09-16 10:50:28 HD Request # 11 | Decompressing data. | 2016-09-16 10:50:28 HD Request # 11 | Receiving Intraday data for NKTR starting at 2016-09-16 09:47:42 | 2016-09-16 10:50:28 HD Request # 11 | Timestamp of first Intraday data file record written: 2016-09-16 09:47:42 | 2016-09-16 10:50:28 Socket (16) | Shutdown and closed. | 2016-09-16 10:50:28 The network socket for historical data has been closed. | 2016-09-16 10:50:28 HD Request # 11 | Received 191 records from 2016-09-16 09:47:42 to 2016-09-16 10:34:54 (47.2 minutes) and wrote 191 records for NKTR | 2016-09-16 10:50:28 HD Request # 11 | Intraday download COMPLETE for NKTR. Completion time: 0s. Unique request ID: 14 | 2016-09-16 10:50:28 Removed historical data download ID 14 | 2016-09-16 10:50:28 Real-time Intraday chart data file updates started for NKTR | 2016-09-16 10:50:28 Opened cached Intraday file: C:\SierraChart\Data\NKTR.scid | 2016-09-16 10:50:28 Intraday chart data file opened for NKTR | 2016-09-16 10:50:28 TD Ameritrade | Using primary service for historical data for NKTR | 2016-09-16 10:50:28 Intraday data recording state for symbol NKTR is set to download 'Pending'. | 2016-09-16 10:50:28 HD Request # 12 | Downloading Intraday chart data for NUGT to the file NUGT.scid. Service: equities.us | 2016-09-16 10:50:28 HD Request # 12 | Download start Date-Time: 2016-09-16 09:48:28.000 | 2016-09-16 10:50:28 HD Request # 12 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:28 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:28 Socket (17) | Connected. | 2016-09-16 10:50:28 HD Request # 12 | Sending historical data logon request message. | 2016-09-16 10:50:28 HD Request # 12 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:28. Record interval: 1. Symbol: NUGT | 2016-09-16 10:50:28 HD Request # 12 | Decompressing data. | 2016-09-16 10:50:28 HD Request # 12 | Receiving Intraday data for NUGT starting at 2016-09-16 09:48:28 | 2016-09-16 10:50:28 HD Request # 12 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:28 | 2016-09-16 10:50:28 Socket (17) | Shutdown and closed. | 2016-09-16 10:50:28 The network socket for historical data has been closed. | 2016-09-16 10:50:28 HD Request # 12 | Received 1304 records from 2016-09-16 09:48:28 to 2016-09-16 10:35:14 (46.8 minutes) and wrote 1304 records for NUGT | 2016-09-16 10:50:28 HD Request # 12 | Intraday download COMPLETE for NUGT. Completion time: 0s. Unique request ID: 15 | 2016-09-16 10:50:28 Removed historical data download ID 15 | 2016-09-16 10:50:28 Real-time Intraday chart data file updates started for NUGT | 2016-09-16 10:50:28 Opened cached Intraday file: C:\SierraChart\Data\NUGT.scid | 2016-09-16 10:50:28 Intraday chart data file opened for NUGT | 2016-09-16 10:50:28 TD Ameritrade | Using primary service for historical data for NUGT | 2016-09-16 10:50:28 Intraday data recording state for symbol NUGT is set to download 'Pending'. | 2016-09-16 10:50:28 HD Request # 13 | Downloading Intraday chart data for SXC to the file SXC.scid. Service: equities.us | 2016-09-16 10:50:28 HD Request # 13 | Download start Date-Time: 2016-09-16 10:49:10.000 | 2016-09-16 10:50:28 HD Request # 13 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:28 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:28 Socket (18) | Connected. | 2016-09-16 10:50:28 HD Request # 13 | Sending historical data logon request message. | 2016-09-16 10:50:28 HD Request # 13 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:49:10. Record interval: 1. Symbol: SXC | 2016-09-16 10:50:28 HD Request # 13 | Decompressing data. | 2016-09-16 10:50:28 HD Request # 13 | Receiving Intraday data for SXC starting at 2016-09-15 10:49:18 | 2016-09-16 10:50:28 Socket (18) | Shutdown and closed. | 2016-09-16 10:50:28 The network socket for historical data has been closed. | 2016-09-16 10:50:28 HD Request # 13 | Received 1065 records from 2016-09-15 10:49:18 to 2016-09-16 10:35:13 (23.8 hours) and wrote 0 records for SXC | 2016-09-16 10:50:28 HD Request # 13 | Intraday download COMPLETE for SXC. Completion time: 1s. Unique request ID: 17 | 2016-09-16 10:50:28 Removed historical data download ID 17 | 2016-09-16 10:50:28 Real-time Intraday chart data file updates started for SXC | 2016-09-16 10:50:28 Opened cached Intraday file: C:\SierraChart\Data\SXC.scid | 2016-09-16 10:50:28 Intraday chart data file opened for SXC | 2016-09-16 10:50:28 TD Ameritrade | Using primary service for historical data for SXC | 2016-09-16 10:50:28 Intraday data recording state for symbol SXC is set to download 'Pending'. | 2016-09-16 10:50:28 HD Request # 14 | Downloading Intraday chart data for UWTI to the file UWTI.scid. Service: equities.us | 2016-09-16 10:50:28 HD Request # 14 | Download start Date-Time: 2016-09-16 10:49:58.000 | 2016-09-16 10:50:28 HD Request # 14 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:28 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:28 Socket (19) | Connected. | 2016-09-16 10:50:28 HD Request # 14 | Sending historical data logon request message. | 2016-09-16 10:50:28 HD Request # 14 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:49:58. Record interval: 1. Symbol: UWTI | 2016-09-16 10:50:28 HD Request # 14 | Decompressing data. | 2016-09-16 10:50:28 Socket (19) | Shutdown and closed. | 2016-09-16 10:50:28 The network socket for historical data has been closed. | 2016-09-16 10:50:28 HD Request # 14 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for UWTI | 2016-09-16 10:50:28 HD Request # 14 | Intraday download COMPLETE for UWTI. Completion time: 0s. Unique request ID: 18 | 2016-09-16 10:50:28 Removed historical data download ID 18 | 2016-09-16 10:50:28 Real-time Intraday chart data file updates started for UWTI | 2016-09-16 10:50:28 Opened cached Intraday file: C:\SierraChart\Data\UWTI.scid | 2016-09-16 10:50:28 Intraday chart data file opened for UWTI | 2016-09-16 10:50:28 TD Ameritrade | Using primary service for historical data for UWTI | 2016-09-16 10:50:28 Intraday data recording state for symbol UWTI is set to download 'Pending'. | 2016-09-16 10:50:28 HD Request # 15 | Downloading Intraday chart data for ZFGN to the file ZFGN.scid. Service: equities.us | 2016-09-16 10:50:28 HD Request # 15 | Download start Date-Time: 2016-09-16 09:46:27.000 | 2016-09-16 10:50:28 HD Request # 15 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:28 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:28 Socket (20) | Connected. | 2016-09-16 10:50:28 HD Request # 15 | Sending historical data logon request message. | 2016-09-16 10:50:28 HD Request # 15 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:46:27. Record interval: 1. Symbol: ZFGN | 2016-09-16 10:50:28 HD Request # 15 | Decompressing data. | 2016-09-16 10:50:28 HD Request # 15 | Receiving Intraday data for ZFGN starting at 2016-09-16 09:46:27 | 2016-09-16 10:50:28 HD Request # 15 | Timestamp of first Intraday data file record written: 2016-09-16 09:46:27 | 2016-09-16 10:50:28 Socket (20) | Shutdown and closed. | 2016-09-16 10:50:28 The network socket for historical data has been closed. | 2016-09-16 10:50:28 HD Request # 15 | Received 38 records from 2016-09-16 09:46:27 to 2016-09-16 10:33:26 (47.0 minutes) and wrote 38 records for ZFGN | 2016-09-16 10:50:28 HD Request # 15 | Intraday download COMPLETE for ZFGN. Completion time: 0s. Unique request ID: 19 | 2016-09-16 10:50:28 Removed historical data download ID 19 | 2016-09-16 10:50:28 Real-time Intraday chart data file updates started for ZFGN | 2016-09-16 10:50:28 Opened cached Intraday file: C:\SierraChart\Data\ZFGN.scid | 2016-09-16 10:50:28 Intraday chart data file opened for ZFGN | 2016-09-16 10:50:28 TD Ameritrade | Using primary service for historical data for ZFGN | 2016-09-16 10:50:28 Intraday data recording state for symbol ZFGN is set to download 'Pending'. | 2016-09-16 10:50:28 HD Request # 16 | Downloading Intraday chart data for CETX to the file CETX.scid. Service: equities.us | 2016-09-16 10:50:28 HD Request # 16 | Download start Date-Time: 2016-09-16 10:48:20.000 | 2016-09-16 10:50:28 HD Request # 16 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:28 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:28 Socket (21) | Connected. | 2016-09-16 10:50:28 HD Request # 16 | Sending historical data logon request message. | 2016-09-16 10:50:28 HD Request # 16 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:48:20. Record interval: 1. Symbol: CETX | 2016-09-16 10:50:28 HD Request # 16 | Decompressing data. | 2016-09-16 10:50:28 HD Request # 16 | Receiving Intraday data for CETX starting at 2016-09-15 10:54:30 | 2016-09-16 10:50:28 Socket (21) | Shutdown and closed. | 2016-09-16 10:50:28 The network socket for historical data has been closed. | 2016-09-16 10:50:28 HD Request # 16 | Received 165 records from 2016-09-15 10:54:30 to 2016-09-16 10:29:15 (23.6 hours) and wrote 0 records for CETX | 2016-09-16 10:50:28 HD Request # 16 | Intraday download COMPLETE for CETX. Completion time: 0s. Unique request ID: 20 | 2016-09-16 10:50:28 Removed historical data download ID 20 | 2016-09-16 10:50:28 Real-time Intraday chart data file updates started for CETX | 2016-09-16 10:50:28 Opened cached Intraday file: C:\SierraChart\Data\CETX.scid | 2016-09-16 10:50:28 Intraday chart data file opened for CETX | 2016-09-16 10:50:28 TD Ameritrade | Using primary service for historical data for CETX | 2016-09-16 10:50:28 Intraday data recording state for symbol CETX is set to download 'Pending'. | 2016-09-16 10:50:28 HD Request # 17 | Downloading Intraday chart data for CLD to the file CLD.scid. Service: equities.us | 2016-09-16 10:50:28 HD Request # 17 | Download start Date-Time: 2016-09-16 09:47:59.000 | 2016-09-16 10:50:28 HD Request # 17 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:28 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:28 Socket (22) | Connected. | 2016-09-16 10:50:28 HD Request # 17 | Sending historical data logon request message. | 2016-09-16 10:50:28 HD Request # 17 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:47:59. Record interval: 1. Symbol: CLD | 2016-09-16 10:50:28 HD Request # 17 | Decompressing data. | 2016-09-16 10:50:28 HD Request # 17 | Receiving Intraday data for CLD starting at 2016-09-16 09:47:59 | 2016-09-16 10:50:28 HD Request # 17 | Timestamp of first Intraday data file record written: 2016-09-16 09:47:59 | 2016-09-16 10:50:28 Socket (22) | Shutdown and closed. | 2016-09-16 10:50:28 The network socket for historical data has been closed. | 2016-09-16 10:50:28 HD Request # 17 | Received 94 records from 2016-09-16 09:47:59 to 2016-09-16 10:34:54 (46.9 minutes) and wrote 94 records for CLD | 2016-09-16 10:50:28 HD Request # 17 | Intraday download COMPLETE for CLD. Completion time: 0s. Unique request ID: 21 | 2016-09-16 10:50:28 Removed historical data download ID 21 | 2016-09-16 10:50:28 Real-time Intraday chart data file updates started for CLD | 2016-09-16 10:50:28 Opened cached Intraday file: C:\SierraChart\Data\CLD.scid | 2016-09-16 10:50:28 Intraday chart data file opened for CLD | 2016-09-16 10:50:28 TD Ameritrade | Using primary service for historical data for CLD | 2016-09-16 10:50:28 Intraday data recording state for symbol CLD is set to download 'Pending'. | 2016-09-16 10:50:28 HD Request # 18 | Downloading Intraday chart data for DMPI to the file DMPI.scid. Service: equities.us | 2016-09-16 10:50:28 HD Request # 18 | Download start Date-Time: 2016-09-16 09:32:01.000 | 2016-09-16 10:50:28 HD Request # 18 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:28 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:28 Socket (23) | Connected. | 2016-09-16 10:50:28 HD Request # 18 | Sending historical data logon request message. | 2016-09-16 10:50:28 HD Request # 18 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:32:01. Record interval: 1. Symbol: DMPI | 2016-09-16 10:50:28 HD Request # 18 | Decompressing data. | 2016-09-16 10:50:29 HD Request # 18 | Receiving Intraday data for DMPI starting at 2016-09-16 09:32:01 | 2016-09-16 10:50:29 HD Request # 18 | Timestamp of first Intraday data file record written: 2016-09-16 09:32:01 | 2016-09-16 10:50:29 Socket (23) | Shutdown and closed. | 2016-09-16 10:50:29 The network socket for historical data has been closed. | 2016-09-16 10:50:29 HD Request # 18 | Received 3 records from 2016-09-16 09:32:01 to 2016-09-16 10:14:47 (42.8 minutes) and wrote 3 records for DMPI | 2016-09-16 10:50:29 HD Request # 18 | Intraday download COMPLETE for DMPI. Completion time: 0s. Unique request ID: 22 | 2016-09-16 10:50:29 Removed historical data download ID 22 | 2016-09-16 10:50:29 Real-time Intraday chart data file updates started for DMPI | 2016-09-16 10:50:29 Opened cached Intraday file: C:\SierraChart\Data\DMPI.scid | 2016-09-16 10:50:29 Intraday chart data file opened for DMPI | 2016-09-16 10:50:29 TD Ameritrade | Using primary service for historical data for DMPI | 2016-09-16 10:50:29 Intraday data recording state for symbol DMPI is set to download 'Pending'. | 2016-09-16 10:50:29 HD Request # 19 | Downloading Intraday chart data for ERS to the file ERS.scid. Service: equities.us | 2016-09-16 10:50:29 HD Request # 19 | Download start Date-Time: 2016-09-15 15:56:25.000 | 2016-09-16 10:50:29 HD Request # 19 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:29 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:29 Socket (24) | Connected. | 2016-09-16 10:50:29 HD Request # 19 | Sending historical data logon request message. | 2016-09-16 10:50:29 HD Request # 19 | Requesting Intraday data. Start Date-Time: 2016-09-15 15:56:25. Record interval: 1. Symbol: ERS | 2016-09-16 10:50:29 HD Request # 19 | Decompressing data. | 2016-09-16 10:50:29 HD Request # 19 | Receiving Intraday data for ERS starting at 2016-09-15 15:56:25 | 2016-09-16 10:50:29 HD Request # 19 | Timestamp of first Intraday data file record written: 2016-09-15 15:56:25 | 2016-09-16 10:50:29 Socket (24) | Shutdown and closed. | 2016-09-16 10:50:29 The network socket for historical data has been closed. | 2016-09-16 10:50:29 HD Request # 19 | Received 1 record from 2016-09-15 15:56:25 to 2016-09-15 15:56:25 (0.0 seconds) and wrote 1 record for ERS | 2016-09-16 10:50:29 HD Request # 19 | Intraday download COMPLETE for ERS. Completion time: 0s. Unique request ID: 23 | 2016-09-16 10:50:29 Removed historical data download ID 23 | 2016-09-16 10:50:29 Real-time Intraday chart data file updates started for ERS | 2016-09-16 10:50:29 Opened cached Intraday file: C:\SierraChart\Data\ERS.scid | 2016-09-16 10:50:29 Intraday chart data file opened for ERS | 2016-09-16 10:50:29 TD Ameritrade | Using primary service for historical data for ERS | 2016-09-16 10:50:29 Intraday data recording state for symbol ERS is set to download 'Pending'. | 2016-09-16 10:50:29 HD Request # 20 | Downloading Intraday chart data for HPJ to the file HPJ.scid. Service: equities.us | 2016-09-16 10:50:29 HD Request # 20 | Download start Date-Time: 2016-09-16 09:45:11.000 | 2016-09-16 10:50:29 HD Request # 20 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:29 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:29 Socket (25) | Connected. | 2016-09-16 10:50:29 HD Request # 20 | Sending historical data logon request message. | 2016-09-16 10:50:29 HD Request # 20 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:45:11. Record interval: 1. Symbol: HPJ | 2016-09-16 10:50:29 HD Request # 20 | Decompressing data. | 2016-09-16 10:50:29 HD Request # 20 | Receiving Intraday data for HPJ starting at 2016-09-16 09:45:11 | 2016-09-16 10:50:29 HD Request # 20 | Timestamp of first Intraday data file record written: 2016-09-16 09:45:11 | 2016-09-16 10:50:29 Socket (25) | Shutdown and closed. | 2016-09-16 10:50:29 The network socket for historical data has been closed. | 2016-09-16 10:50:29 HD Request # 20 | Received 7 records from 2016-09-16 09:45:11 to 2016-09-16 10:31:47 (46.6 minutes) and wrote 7 records for HPJ | 2016-09-16 10:50:29 HD Request # 20 | Intraday download COMPLETE for HPJ. Completion time: 0s. Unique request ID: 24 | 2016-09-16 10:50:29 Removed historical data download ID 24 | 2016-09-16 10:50:29 Real-time Intraday chart data file updates started for HPJ | 2016-09-16 10:50:29 Opened cached Intraday file: C:\SierraChart\Data\HPJ.scid | 2016-09-16 10:50:29 Intraday chart data file opened for HPJ | 2016-09-16 10:50:29 TD Ameritrade | Using primary service for historical data for HPJ | 2016-09-16 10:50:29 Intraday data recording state for symbol HPJ is set to download 'Pending'. | 2016-09-16 10:50:29 HD Request # 21 | Downloading Intraday chart data for KEM to the file KEM.scid. Service: equities.us | 2016-09-16 10:50:29 HD Request # 21 | Download start Date-Time: 2016-09-16 10:48:00.000 | 2016-09-16 10:50:29 HD Request # 21 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:29 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:29 Socket (26) | Connected. | 2016-09-16 10:50:29 HD Request # 21 | Sending historical data logon request message. | 2016-09-16 10:50:29 HD Request # 21 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:48:00. Record interval: 1. Symbol: KEM | 2016-09-16 10:50:29 HD Request # 21 | Decompressing data. | 2016-09-16 10:50:29 HD Request # 21 | Receiving Intraday data for KEM starting at 2016-09-15 10:50:11 | 2016-09-16 10:50:29 Socket (26) | Shutdown and closed. | 2016-09-16 10:50:29 The network socket for historical data has been closed. | 2016-09-16 10:50:29 HD Request # 21 | Received 136 records from 2016-09-15 10:50:11 to 2016-09-16 10:33:23 (23.7 hours) and wrote 0 records for KEM | 2016-09-16 10:50:29 HD Request # 21 | Intraday download COMPLETE for KEM. Completion time: 0s. Unique request ID: 25 | 2016-09-16 10:50:29 Removed historical data download ID 25 | 2016-09-16 10:50:29 Real-time Intraday chart data file updates started for KEM | 2016-09-16 10:50:29 Opened cached Intraday file: C:\SierraChart\Data\KEM.scid | 2016-09-16 10:50:29 Intraday chart data file opened for KEM | 2016-09-16 10:50:29 TD Ameritrade | Using primary service for historical data for KEM | 2016-09-16 10:50:29 Intraday data recording state for symbol KEM is set to download 'Pending'. | 2016-09-16 10:50:29 HD Request # 22 | Downloading Intraday chart data for NEOT to the file NEOT.scid. Service: equities.us | 2016-09-16 10:50:29 HD Request # 22 | Download start Date-Time: 2016-09-16 09:38:06.000 | 2016-09-16 10:50:29 HD Request # 22 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:29 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:29 Socket (27) | Connected. | 2016-09-16 10:50:29 HD Request # 22 | Sending historical data logon request message. | 2016-09-16 10:50:29 HD Request # 22 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:38:06. Record interval: 1. Symbol: NEOT | 2016-09-16 10:50:29 HD Request # 22 | Decompressing data. | 2016-09-16 10:50:29 HD Request # 22 | Receiving Intraday data for NEOT starting at 2016-09-16 09:38:06 | 2016-09-16 10:50:29 HD Request # 22 | Timestamp of first Intraday data file record written: 2016-09-16 09:38:06 | 2016-09-16 10:50:29 Socket (27) | Shutdown and closed. | 2016-09-16 10:50:29 The network socket for historical data has been closed. | 2016-09-16 10:50:29 HD Request # 22 | Received 7 records from 2016-09-16 09:38:06 to 2016-09-16 10:35:03 (56.9 minutes) and wrote 7 records for NEOT | 2016-09-16 10:50:29 HD Request # 22 | Intraday download COMPLETE for NEOT. Completion time: 0s. Unique request ID: 26 | 2016-09-16 10:50:29 Removed historical data download ID 26 | 2016-09-16 10:50:29 Real-time Intraday chart data file updates started for NEOT | 2016-09-16 10:50:29 Opened cached Intraday file: C:\SierraChart\Data\NEOT.scid | 2016-09-16 10:50:29 Intraday chart data file opened for NEOT | 2016-09-16 10:50:29 TD Ameritrade | Using primary service for historical data for NEOT | 2016-09-16 10:50:29 Intraday data recording state for symbol NEOT is set to download 'Pending'. | 2016-09-16 10:50:29 HD Request # 23 | Downloading Intraday chart data for ORIG to the file ORIG.scid. Service: equities.us | 2016-09-16 10:50:29 HD Request # 23 | Download start Date-Time: 2016-09-16 09:47:09.000 | 2016-09-16 10:50:29 HD Request # 23 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:29 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:29 Socket (28) | Connected. | 2016-09-16 10:50:29 HD Request # 23 | Sending historical data logon request message. | 2016-09-16 10:50:29 HD Request # 23 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:47:09. Record interval: 1. Symbol: ORIG | 2016-09-16 10:50:29 HD Request # 23 | Decompressing data. | 2016-09-16 10:50:29 HD Request # 23 | Receiving Intraday data for ORIG starting at 2016-09-16 09:47:09 | 2016-09-16 10:50:29 HD Request # 23 | Timestamp of first Intraday data file record written: 2016-09-16 09:47:09 | 2016-09-16 10:50:29 Socket (28) | Shutdown and closed. | 2016-09-16 10:50:29 The network socket for historical data has been closed. | 2016-09-16 10:50:29 HD Request # 23 | Received 49 records from 2016-09-16 09:47:09 to 2016-09-16 10:33:52 (46.7 minutes) and wrote 49 records for ORIG | 2016-09-16 10:50:29 HD Request # 23 | Intraday download COMPLETE for ORIG. Completion time: 0s. Unique request ID: 27 | 2016-09-16 10:50:29 Removed historical data download ID 27 | 2016-09-16 10:50:29 Real-time Intraday chart data file updates started for ORIG | 2016-09-16 10:50:29 Opened cached Intraday file: C:\SierraChart\Data\ORIG.scid | 2016-09-16 10:50:29 Intraday chart data file opened for ORIG | 2016-09-16 10:50:29 TD Ameritrade | Using primary service for historical data for ORIG | 2016-09-16 10:50:29 Intraday data recording state for symbol ORIG is set to download 'Pending'. | 2016-09-16 10:50:29 HD Request # 24 | Downloading Intraday chart data for TDW to the file TDW.scid. Service: equities.us | 2016-09-16 10:50:29 HD Request # 24 | Download start Date-Time: 2016-09-16 09:48:16.000 | 2016-09-16 10:50:29 HD Request # 24 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:29 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:29 Socket (29) | Connected. | 2016-09-16 10:50:29 HD Request # 24 | Sending historical data logon request message. | 2016-09-16 10:50:29 HD Request # 24 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:16. Record interval: 1. Symbol: TDW | 2016-09-16 10:50:29 HD Request # 24 | Decompressing data. | 2016-09-16 10:50:29 HD Request # 24 | Receiving Intraday data for TDW starting at 2016-09-16 09:48:16 | 2016-09-16 10:50:29 HD Request # 24 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:16 | 2016-09-16 10:50:29 Socket (29) | Shutdown and closed. | 2016-09-16 10:50:29 The network socket for historical data has been closed. | 2016-09-16 10:50:29 HD Request # 24 | Received 109 records from 2016-09-16 09:48:16 to 2016-09-16 10:35:14 (47.0 minutes) and wrote 109 records for TDW | 2016-09-16 10:50:29 HD Request # 24 | Intraday download COMPLETE for TDW. Completion time: 0s. Unique request ID: 29 | 2016-09-16 10:50:29 Removed historical data download ID 29 | 2016-09-16 10:50:29 Real-time Intraday chart data file updates started for TDW | 2016-09-16 10:50:29 Opened cached Intraday file: C:\SierraChart\Data\TDW.scid | 2016-09-16 10:50:29 Intraday chart data file opened for TDW | 2016-09-16 10:50:29 TD Ameritrade | Using primary service for historical data for TDW | 2016-09-16 10:50:29 Intraday data recording state for symbol TDW is set to download 'Pending'. | 2016-09-16 10:50:29 HD Request # 25 | Downloading Intraday chart data for TNXP to the file TNXP.scid. Service: equities.us | 2016-09-16 10:50:29 HD Request # 25 | Download start Date-Time: 2016-09-16 09:48:09.000 | 2016-09-16 10:50:29 HD Request # 25 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:29 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:29 Socket (30) | Connected. | 2016-09-16 10:50:29 HD Request # 25 | Sending historical data logon request message. | 2016-09-16 10:50:29 HD Request # 25 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:09. Record interval: 1. Symbol: TNXP | 2016-09-16 10:50:29 HD Request # 25 | Decompressing data. | 2016-09-16 10:50:29 HD Request # 25 | Receiving Intraday data for TNXP starting at 2016-09-16 09:48:09 | 2016-09-16 10:50:29 HD Request # 25 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:09 | 2016-09-16 10:50:29 Socket (30) | Shutdown and closed. | 2016-09-16 10:50:29 The network socket for historical data has been closed. | 2016-09-16 10:50:29 HD Request # 25 | Received 91 records from 2016-09-16 09:48:09 to 2016-09-16 10:35:05 (46.9 minutes) and wrote 91 records for TNXP | 2016-09-16 10:50:29 HD Request # 25 | Intraday download COMPLETE for TNXP. Completion time: 0s. Unique request ID: 30 | 2016-09-16 10:50:29 Removed historical data download ID 30 | 2016-09-16 10:50:29 Real-time Intraday chart data file updates started for TNXP | 2016-09-16 10:50:29 Opened cached Intraday file: C:\SierraChart\Data\TNXP.scid | 2016-09-16 10:50:29 Intraday chart data file opened for TNXP | 2016-09-16 10:50:29 TD Ameritrade | Using primary service for historical data for TNXP | 2016-09-16 10:50:29 Intraday data recording state for symbol TNXP is set to download 'Pending'. | 2016-09-16 10:50:29 HD Request # 26 | Downloading Intraday chart data for VTSI to the file VTSI.scid. Service: equities.us | 2016-09-16 10:50:29 HD Request # 26 | Download start Date-Time: 2016-09-16 09:30:00.000 | 2016-09-16 10:50:29 HD Request # 26 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:29 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:29 Socket (31) | Connected. | 2016-09-16 10:50:29 HD Request # 26 | Sending historical data logon request message. | 2016-09-16 10:50:29 HD Request # 26 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:30:00. Record interval: 1. Symbol: VTSI | 2016-09-16 10:50:29 HD Request # 26 | Decompressing data. | 2016-09-16 10:50:29 HD Request # 26 | Receiving Intraday data for VTSI starting at 2016-09-16 09:30:00 | 2016-09-16 10:50:29 HD Request # 26 | Timestamp of first Intraday data file record written: 2016-09-16 09:30:00 | 2016-09-16 10:50:29 Socket (31) | Shutdown and closed. | 2016-09-16 10:50:29 The network socket for historical data has been closed. | 2016-09-16 10:50:29 HD Request # 26 | Received 6 records from 2016-09-16 09:30:00 to 2016-09-16 10:12:32 (42.5 minutes) and wrote 6 records for VTSI | 2016-09-16 10:50:29 HD Request # 26 | Intraday download COMPLETE for VTSI. Completion time: 0s. Unique request ID: 32 | 2016-09-16 10:50:29 Removed historical data download ID 32 | 2016-09-16 10:50:29 Real-time Intraday chart data file updates started for VTSI | 2016-09-16 10:50:29 Opened cached Intraday file: C:\SierraChart\Data\VTSI.scid | 2016-09-16 10:50:29 Intraday chart data file opened for VTSI | 2016-09-16 10:50:29 TD Ameritrade | Using primary service for historical data for VTSI | 2016-09-16 10:50:29 Intraday data recording state for symbol VTSI is set to download 'Pending'. | 2016-09-16 10:50:29 HD Request # 27 | Downloading Intraday chart data for ZX to the file ZX.scid. Service: equities.us | 2016-09-16 10:50:29 HD Request # 27 | Download start Date-Time: 2016-09-16 09:47:15.000 | 2016-09-16 10:50:29 HD Request # 27 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:29 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:29 Socket (32) | Connected. | 2016-09-16 10:50:29 HD Request # 27 | Sending historical data logon request message. | 2016-09-16 10:50:29 HD Request # 27 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:47:15. Record interval: 1. Symbol: ZX | 2016-09-16 10:50:29 HD Request # 27 | Decompressing data. | 2016-09-16 10:50:29 HD Request # 27 | Receiving Intraday data for ZX starting at 2016-09-15 11:37:47 | 2016-09-16 10:50:29 Socket (32) | Shutdown and closed. | 2016-09-16 10:50:29 The network socket for historical data has been closed. | 2016-09-16 10:50:29 HD Request # 27 | Received 15 records from 2016-09-15 11:37:47 to 2016-09-16 09:47:03 (22.2 hours) and wrote 0 records for ZX | 2016-09-16 10:50:29 HD Request # 27 | Intraday download COMPLETE for ZX. Completion time: 0s. Unique request ID: 33 | 2016-09-16 10:50:29 Removed historical data download ID 33 | 2016-09-16 10:50:29 Real-time Intraday chart data file updates started for ZX | 2016-09-16 10:50:29 Opened cached Intraday file: C:\SierraChart\Data\ZX.scid | 2016-09-16 10:50:29 Intraday chart data file opened for ZX | 2016-09-16 10:50:29 TD Ameritrade | Using primary service for historical data for ZX | 2016-09-16 10:50:29 Intraday data recording state for symbol ZX is set to download 'Pending'. | 2016-09-16 10:50:29 HD Request # 28 | Downloading Intraday chart data for MGT to the file MGT.scid. Service: equities.us | 2016-09-16 10:50:29 HD Request # 28 | Download start Date-Time: 2016-09-16 10:49:40.000 | 2016-09-16 10:50:29 HD Request # 28 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:29 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:29 Socket (33) | Connected. | 2016-09-16 10:50:29 HD Request # 28 | Sending historical data logon request message. | 2016-09-16 10:50:29 HD Request # 28 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:49:40. Record interval: 1. Symbol: MGT | 2016-09-16 10:50:29 HD Request # 28 | Decompressing data. | 2016-09-16 10:50:29 Socket (33) | Shutdown and closed. | 2016-09-16 10:50:29 The network socket for historical data has been closed. | 2016-09-16 10:50:29 HD Request # 28 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MGT | 2016-09-16 10:50:29 HD Request # 28 | Intraday download COMPLETE for MGT. Completion time: 0s. Unique request ID: 34 | 2016-09-16 10:50:29 Removed historical data download ID 34 | 2016-09-16 10:50:29 Real-time Intraday chart data file updates started for MGT | 2016-09-16 10:50:29 Opened cached Intraday file: C:\SierraChart\Data\MGT.scid | 2016-09-16 10:50:29 Intraday chart data file opened for MGT | 2016-09-16 10:50:29 TD Ameritrade | Using primary service for historical data for MGT | 2016-09-16 10:50:29 Intraday data recording state for symbol MGT is set to download 'Pending'. | 2016-09-16 10:50:29 HD Request # 29 | Downloading Intraday chart data for FCX to the file FCX.scid. Service: equities.us | 2016-09-16 10:50:29 HD Request # 29 | Download start Date-Time: 2016-09-16 09:48:13.000 | 2016-09-16 10:50:29 HD Request # 29 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:29 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:29 Socket (34) | Connected. | 2016-09-16 10:50:29 HD Request # 29 | Sending historical data logon request message. | 2016-09-16 10:50:29 HD Request # 29 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:13. Record interval: 1. Symbol: FCX | 2016-09-16 10:50:30 HD Request # 29 | Decompressing data. | 2016-09-16 10:50:30 HD Request # 29 | Receiving Intraday data for FCX starting at 2016-09-16 09:48:13 | 2016-09-16 10:50:30 HD Request # 29 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:13 | 2016-09-16 10:50:30 Socket (34) | Shutdown and closed. | 2016-09-16 10:50:30 The network socket for historical data has been closed. | 2016-09-16 10:50:30 HD Request # 29 | Received 1173 records from 2016-09-16 09:48:13 to 2016-09-16 10:35:14 (47.0 minutes) and wrote 1173 records for FCX | 2016-09-16 10:50:30 HD Request # 29 | Intraday download COMPLETE for FCX. Completion time: 0s. Unique request ID: 35 | 2016-09-16 10:50:30 Removed historical data download ID 35 | 2016-09-16 10:50:30 Real-time Intraday chart data file updates started for FCX | 2016-09-16 10:50:30 Opened cached Intraday file: C:\SierraChart\Data\FCX.scid | 2016-09-16 10:50:30 Intraday chart data file opened for FCX | 2016-09-16 10:50:30 TD Ameritrade | Using primary service for historical data for FCX | 2016-09-16 10:50:30 Intraday data recording state for symbol FCX is set to download 'Pending'. | 2016-09-16 10:50:30 HD Request # 30 | Downloading Intraday chart data for AMPE to the file AMPE.scid. Service: equities.us | 2016-09-16 10:50:30 HD Request # 30 | Download start Date-Time: 2016-09-16 09:45:11.000 | 2016-09-16 10:50:30 HD Request # 30 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:30 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:30 Socket (35) | Connected. | 2016-09-16 10:50:30 HD Request # 30 | Sending historical data logon request message. | 2016-09-16 10:50:30 HD Request # 30 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:45:11. Record interval: 1. Symbol: AMPE | 2016-09-16 10:50:30 HD Request # 30 | Decompressing data. | 2016-09-16 10:50:30 HD Request # 30 | Receiving Intraday data for AMPE starting at 2016-09-16 09:45:11 | 2016-09-16 10:50:30 HD Request # 30 | Timestamp of first Intraday data file record written: 2016-09-16 09:45:11 | 2016-09-16 10:50:30 Socket (35) | Shutdown and closed. | 2016-09-16 10:50:30 The network socket for historical data has been closed. | 2016-09-16 10:50:30 HD Request # 30 | Received 55 records from 2016-09-16 09:45:11 to 2016-09-16 10:32:47 (47.6 minutes) and wrote 55 records for AMPE | 2016-09-16 10:50:30 HD Request # 30 | Intraday download COMPLETE for AMPE. Completion time: 0s. Unique request ID: 38 | 2016-09-16 10:50:30 Removed historical data download ID 38 | 2016-09-16 10:50:30 Real-time Intraday chart data file updates started for AMPE | 2016-09-16 10:50:30 Opened cached Intraday file: C:\SierraChart\Data\AMPE.scid | 2016-09-16 10:50:30 Intraday chart data file opened for AMPE | 2016-09-16 10:50:30 TD Ameritrade | Using primary service for historical data for AMPE | 2016-09-16 10:50:30 Intraday data recording state for symbol AMPE is set to download 'Pending'. | 2016-09-16 10:50:30 HD Request # 31 | Downloading Intraday chart data for RPRX to the file RPRX.scid. Service: equities.us | 2016-09-16 10:50:30 HD Request # 31 | Download start Date-Time: 2016-09-16 09:42:23.000 | 2016-09-16 10:50:30 HD Request # 31 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:30 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:30 Socket (36) | Connected. | 2016-09-16 10:50:30 HD Request # 31 | Sending historical data logon request message. | 2016-09-16 10:50:30 HD Request # 31 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:42:23. Record interval: 1. Symbol: RPRX | 2016-09-16 10:50:30 HD Request # 31 | Decompressing data. | 2016-09-16 10:50:30 HD Request # 31 | Receiving Intraday data for RPRX starting at 2016-09-16 09:42:23 | 2016-09-16 10:50:30 HD Request # 31 | Timestamp of first Intraday data file record written: 2016-09-16 09:42:23 | 2016-09-16 10:50:30 Socket (36) | Shutdown and closed. | 2016-09-16 10:50:30 The network socket for historical data has been closed. | 2016-09-16 10:50:30 HD Request # 31 | Received 22 records from 2016-09-16 09:42:23 to 2016-09-16 10:34:50 (52.5 minutes) and wrote 22 records for RPRX | 2016-09-16 10:50:30 HD Request # 31 | Intraday download COMPLETE for RPRX. Completion time: 0s. Unique request ID: 40 | 2016-09-16 10:50:30 Removed historical data download ID 40 | 2016-09-16 10:50:30 Real-time Intraday chart data file updates started for RPRX | 2016-09-16 10:50:30 Opened cached Intraday file: C:\SierraChart\Data\RPRX.scid | 2016-09-16 10:50:30 Intraday chart data file opened for RPRX | 2016-09-16 10:50:30 TD Ameritrade | Using primary service for historical data for RPRX | 2016-09-16 10:50:30 Intraday data recording state for symbol RPRX is set to download 'Pending'. | 2016-09-16 10:50:30 HD Request # 32 | Downloading Intraday chart data for STV to the file STV.scid. Service: equities.us | 2016-09-16 10:50:30 HD Request # 32 | Download start Date-Time: 2016-09-15 16:02:01.000 | 2016-09-16 10:50:30 HD Request # 32 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:30 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:30 Socket (37) | Connected. | 2016-09-16 10:50:30 HD Request # 32 | Sending historical data logon request message. | 2016-09-16 10:50:30 HD Request # 32 | Requesting Intraday data. Start Date-Time: 2016-09-15 16:02:01. Record interval: 1. Symbol: STV | 2016-09-16 10:50:30 HD Request # 32 | Decompressing data. | 2016-09-16 10:50:30 HD Request # 32 | Receiving Intraday data for STV starting at 2016-09-15 16:02:01 | 2016-09-16 10:50:30 HD Request # 32 | Timestamp of first Intraday data file record written: 2016-09-15 16:02:01 | 2016-09-16 10:50:30 Socket (37) | Shutdown and closed. | 2016-09-16 10:50:30 The network socket for historical data has been closed. | 2016-09-16 10:50:30 HD Request # 32 | Received 8 records from 2016-09-15 16:02:01 to 2016-09-16 10:31:18 (18.5 hours) and wrote 8 records for STV | 2016-09-16 10:50:30 HD Request # 32 | Intraday download COMPLETE for STV. Completion time: 1s. Unique request ID: 41 | 2016-09-16 10:50:30 Removed historical data download ID 41 | 2016-09-16 10:50:30 Real-time Intraday chart data file updates started for STV | 2016-09-16 10:50:30 Opened cached Intraday file: C:\SierraChart\Data\STV.scid | 2016-09-16 10:50:30 Intraday chart data file opened for STV | 2016-09-16 10:50:30 TD Ameritrade | Using primary service for historical data for STV | 2016-09-16 10:50:30 Intraday data recording state for symbol STV is set to download 'Pending'. | 2016-09-16 10:50:30 HD Request # 33 | Downloading Intraday chart data for THLD to the file THLD.scid. Service: equities.us | 2016-09-16 10:50:30 HD Request # 33 | Download start Date-Time: 2016-09-16 09:48:01.000 | 2016-09-16 10:50:30 HD Request # 33 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:30 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:30 Socket (38) | Connected. | 2016-09-16 10:50:30 HD Request # 33 | Sending historical data logon request message. | 2016-09-16 10:50:30 HD Request # 33 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:01. Record interval: 1. Symbol: THLD | 2016-09-16 10:50:30 HD Request # 33 | Decompressing data. | 2016-09-16 10:50:30 HD Request # 33 | Receiving Intraday data for THLD starting at 2016-09-16 09:48:01 | 2016-09-16 10:50:30 HD Request # 33 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:01 | 2016-09-16 10:50:30 Socket (38) | Shutdown and closed. | 2016-09-16 10:50:30 The network socket for historical data has been closed. | 2016-09-16 10:50:30 HD Request # 33 | Received 80 records from 2016-09-16 09:48:01 to 2016-09-16 10:30:41 (42.7 minutes) and wrote 80 records for THLD | 2016-09-16 10:50:30 HD Request # 33 | Intraday download COMPLETE for THLD. Completion time: 0s. Unique request ID: 42 | 2016-09-16 10:50:30 Removed historical data download ID 42 | 2016-09-16 10:50:30 Real-time Intraday chart data file updates started for THLD | 2016-09-16 10:50:30 Opened cached Intraday file: C:\SierraChart\Data\THLD.scid | 2016-09-16 10:50:30 Intraday chart data file opened for THLD | 2016-09-16 10:50:30 TD Ameritrade | Using primary service for historical data for THLD | 2016-09-16 10:50:30 Intraday data recording state for symbol THLD is set to download 'Pending'. | 2016-09-16 10:50:30 HD Request # 34 | Downloading Intraday chart data for VRX to the file VRX.scid. Service: equities.us | 2016-09-16 10:50:30 HD Request # 34 | Download start Date-Time: 2016-09-16 09:48:28.000 | 2016-09-16 10:50:30 HD Request # 34 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:30 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:30 Socket (39) | Connected. | 2016-09-16 10:50:30 HD Request # 34 | Sending historical data logon request message. | 2016-09-16 10:50:30 HD Request # 34 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:28. Record interval: 1. Symbol: VRX | 2016-09-16 10:50:30 HD Request # 34 | Decompressing data. | 2016-09-16 10:50:30 HD Request # 34 | Receiving Intraday data for VRX starting at 2016-09-16 09:48:28 | 2016-09-16 10:50:30 HD Request # 34 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:28 | 2016-09-16 10:50:30 Socket (39) | Shutdown and closed. | 2016-09-16 10:50:30 The network socket for historical data has been closed. | 2016-09-16 10:50:30 HD Request # 34 | Received 1211 records from 2016-09-16 09:48:28 to 2016-09-16 10:35:14 (46.8 minutes) and wrote 1211 records for VRX | 2016-09-16 10:50:30 HD Request # 34 | Intraday download COMPLETE for VRX. Completion time: 0s. Unique request ID: 43 | 2016-09-16 10:50:30 Removed historical data download ID 43 | 2016-09-16 10:50:30 Real-time Intraday chart data file updates started for VRX | 2016-09-16 10:50:30 Opened cached Intraday file: C:\SierraChart\Data\VRX.scid | 2016-09-16 10:50:30 Intraday chart data file opened for VRX | 2016-09-16 10:50:30 TD Ameritrade | Using primary service for historical data for VRX | 2016-09-16 10:50:30 Intraday data recording state for symbol VRX is set to download 'Pending'. | 2016-09-16 10:50:30 HD Request # 35 | Downloading Intraday chart data for VUZI to the file VUZI.scid. Service: equities.us | 2016-09-16 10:50:30 HD Request # 35 | Download start Date-Time: 2016-09-16 09:46:38.000 | 2016-09-16 10:50:30 HD Request # 35 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:30 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:30 Socket (40) | Connected. | 2016-09-16 10:50:30 HD Request # 35 | Sending historical data logon request message. | 2016-09-16 10:50:30 HD Request # 35 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:46:38. Record interval: 1. Symbol: VUZI | 2016-09-16 10:50:30 HD Request # 35 | Decompressing data. | 2016-09-16 10:50:30 HD Request # 35 | Receiving Intraday data for VUZI starting at 2016-09-16 09:46:38 | 2016-09-16 10:50:30 HD Request # 35 | Timestamp of first Intraday data file record written: 2016-09-16 09:46:38 | 2016-09-16 10:50:30 Socket (40) | Shutdown and closed. | 2016-09-16 10:50:30 The network socket for historical data has been closed. | 2016-09-16 10:50:30 HD Request # 35 | Received 72 records from 2016-09-16 09:46:38 to 2016-09-16 10:33:54 (47.3 minutes) and wrote 72 records for VUZI | 2016-09-16 10:50:30 HD Request # 35 | Intraday download COMPLETE for VUZI. Completion time: 0s. Unique request ID: 44 | 2016-09-16 10:50:30 Removed historical data download ID 44 | 2016-09-16 10:50:30 Real-time Intraday chart data file updates started for VUZI | 2016-09-16 10:50:30 Opened cached Intraday file: C:\SierraChart\Data\VUZI.scid | 2016-09-16 10:50:30 Intraday chart data file opened for VUZI | 2016-09-16 10:50:30 TD Ameritrade | Using primary service for historical data for VUZI | 2016-09-16 10:50:30 Intraday data recording state for symbol VUZI is set to download 'Pending'. | 2016-09-16 10:50:30 HD Request # 36 | Downloading Intraday chart data for GRO to the file GRO.scid. Service: equities.us | 2016-09-16 10:50:30 HD Request # 36 | Download start Date-Time: 2016-09-15 16:02:00.000 | 2016-09-16 10:50:30 HD Request # 36 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:30 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:30 Socket (41) | Connected. | 2016-09-16 10:50:30 HD Request # 36 | Sending historical data logon request message. | 2016-09-16 10:50:30 HD Request # 36 | Requesting Intraday data. Start Date-Time: 2016-09-15 16:02:00. Record interval: 1. Symbol: GRO | 2016-09-16 10:50:30 HD Request # 36 | Decompressing data. | 2016-09-16 10:50:30 HD Request # 36 | Receiving Intraday data for GRO starting at 2016-09-15 16:02:00 | 2016-09-16 10:50:30 HD Request # 36 | Timestamp of first Intraday data file record written: 2016-09-15 16:02:00 | 2016-09-16 10:50:30 Socket (41) | Shutdown and closed. | 2016-09-16 10:50:30 The network socket for historical data has been closed. | 2016-09-16 10:50:30 HD Request # 36 | Received 1 record from 2016-09-15 16:02:00 to 2016-09-15 16:02:00 (0.0 seconds) and wrote 1 record for GRO | 2016-09-16 10:50:30 HD Request # 36 | Intraday download COMPLETE for GRO. Completion time: 0s. Unique request ID: 45 | 2016-09-16 10:50:30 Removed historical data download ID 45 | 2016-09-16 10:50:30 Real-time Intraday chart data file updates started for GRO | 2016-09-16 10:50:30 Opened cached Intraday file: C:\SierraChart\Data\GRO.scid | 2016-09-16 10:50:30 Intraday chart data file opened for GRO | 2016-09-16 10:50:30 TD Ameritrade | Using primary service for historical data for GRO | 2016-09-16 10:50:30 Intraday data recording state for symbol GRO is set to download 'Pending'. | 2016-09-16 10:50:30 HD Request # 37 | Downloading Intraday chart data for RTRX to the file RTRX.scid. Service: equities.us | 2016-09-16 10:50:30 HD Request # 37 | Download start Date-Time: 2016-09-16 09:47:41.000 | 2016-09-16 10:50:30 HD Request # 37 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:30 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:30 Socket (42) | Connected. | 2016-09-16 10:50:31 HD Request # 37 | Sending historical data logon request message. | 2016-09-16 10:50:31 HD Request # 37 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:47:41. Record interval: 1. Symbol: RTRX | 2016-09-16 10:50:31 HD Request # 37 | Decompressing data. | 2016-09-16 10:50:31 HD Request # 37 | Receiving Intraday data for RTRX starting at 2016-09-16 09:47:41 | 2016-09-16 10:50:31 HD Request # 37 | Timestamp of first Intraday data file record written: 2016-09-16 09:47:41 | 2016-09-16 10:50:31 Socket (42) | Shutdown and closed. | 2016-09-16 10:50:31 The network socket for historical data has been closed. | 2016-09-16 10:50:31 HD Request # 37 | Received 200 records from 2016-09-16 09:47:41 to 2016-09-16 10:34:25 (46.7 minutes) and wrote 200 records for RTRX | 2016-09-16 10:50:31 HD Request # 37 | Intraday download COMPLETE for RTRX. Completion time: 0s. Unique request ID: 46 | 2016-09-16 10:50:31 Removed historical data download ID 46 | 2016-09-16 10:50:31 Real-time Intraday chart data file updates started for RTRX | 2016-09-16 10:50:31 Opened cached Intraday file: C:\SierraChart\Data\RTRX.scid | 2016-09-16 10:50:31 Intraday chart data file opened for RTRX | 2016-09-16 10:50:31 TD Ameritrade | Using primary service for historical data for RTRX | 2016-09-16 10:50:31 Intraday data recording state for symbol RTRX is set to download 'Pending'. | 2016-09-16 10:50:31 HD Request # 38 | Downloading Intraday chart data for ADVM to the file ADVM.scid. Service: equities.us | 2016-09-16 10:50:31 HD Request # 38 | Download start Date-Time: 2016-09-16 09:45:56.000 | 2016-09-16 10:50:31 HD Request # 38 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:31 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:31 Socket (43) | Connected. | 2016-09-16 10:50:31 HD Request # 38 | Sending historical data logon request message. | 2016-09-16 10:50:31 HD Request # 38 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:45:56. Record interval: 1. Symbol: ADVM | 2016-09-16 10:50:31 HD Request # 38 | Decompressing data. | 2016-09-16 10:50:31 HD Request # 38 | Receiving Intraday data for ADVM starting at 2016-09-16 09:48:45 | 2016-09-16 10:50:31 HD Request # 38 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:45 | 2016-09-16 10:50:31 Socket (43) | Shutdown and closed. | 2016-09-16 10:50:31 The network socket for historical data has been closed. | 2016-09-16 10:50:31 HD Request # 38 | Received 25 records from 2016-09-16 09:48:45 to 2016-09-16 10:34:08 (45.4 minutes) and wrote 25 records for ADVM | 2016-09-16 10:50:31 HD Request # 38 | Intraday download COMPLETE for ADVM. Completion time: 0s. Unique request ID: 49 | 2016-09-16 10:50:31 Removed historical data download ID 49 | 2016-09-16 10:50:31 Real-time Intraday chart data file updates started for ADVM | 2016-09-16 10:50:31 Opened cached Intraday file: C:\SierraChart\Data\ADVM.scid | 2016-09-16 10:50:31 Intraday chart data file opened for ADVM | 2016-09-16 10:50:31 TD Ameritrade | Using primary service for historical data for ADVM | 2016-09-16 10:50:31 Intraday data recording state for symbol ADVM is set to download 'Pending'. | 2016-09-16 10:50:31 HD Request # 39 | Downloading Intraday chart data for CHMA to the file CHMA.scid. Service: equities.us | 2016-09-16 10:50:31 HD Request # 39 | Download start Date-Time: 2016-09-16 09:46:27.000 | 2016-09-16 10:50:31 HD Request # 39 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:31 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:31 Socket (44) | Connected. | 2016-09-16 10:50:31 HD Request # 39 | Sending historical data logon request message. | 2016-09-16 10:50:31 HD Request # 39 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:46:27. Record interval: 1. Symbol: CHMA | 2016-09-16 10:50:31 HD Request # 39 | Decompressing data. | 2016-09-16 10:50:31 HD Request # 39 | Receiving Intraday data for CHMA starting at 2016-09-16 09:46:27 | 2016-09-16 10:50:31 HD Request # 39 | Timestamp of first Intraday data file record written: 2016-09-16 09:46:27 | 2016-09-16 10:50:31 Socket (44) | Shutdown and closed. | 2016-09-16 10:50:31 The network socket for historical data has been closed. | 2016-09-16 10:50:31 HD Request # 39 | Received 16 records from 2016-09-16 09:46:27 to 2016-09-16 10:32:35 (46.1 minutes) and wrote 16 records for CHMA | 2016-09-16 10:50:31 HD Request # 39 | Intraday download COMPLETE for CHMA. Completion time: 0s. Unique request ID: 51 | 2016-09-16 10:50:31 Removed historical data download ID 51 | 2016-09-16 10:50:31 Real-time Intraday chart data file updates started for CHMA | 2016-09-16 10:50:31 Opened cached Intraday file: C:\SierraChart\Data\CHMA.scid | 2016-09-16 10:50:31 Intraday chart data file opened for CHMA | 2016-09-16 10:50:31 TD Ameritrade | Using primary service for historical data for CHMA | 2016-09-16 10:50:31 Intraday data recording state for symbol CHMA is set to download 'Pending'. | 2016-09-16 10:50:31 HD Request # 40 | Downloading Intraday chart data for CLF to the file CLF.scid. Service: equities.us | 2016-09-16 10:50:31 HD Request # 40 | Download start Date-Time: 2016-09-16 09:48:10.000 | 2016-09-16 10:50:31 HD Request # 40 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:31 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:31 Socket (45) | Connected. | 2016-09-16 10:50:31 HD Request # 40 | Sending historical data logon request message. | 2016-09-16 10:50:31 HD Request # 40 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:10. Record interval: 1. Symbol: CLF | 2016-09-16 10:50:31 HD Request # 40 | Decompressing data. | 2016-09-16 10:50:31 HD Request # 40 | Receiving Intraday data for CLF starting at 2016-09-16 09:48:10 | 2016-09-16 10:50:31 HD Request # 40 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:10 | 2016-09-16 10:50:31 Socket (45) | Shutdown and closed. | 2016-09-16 10:50:31 The network socket for historical data has been closed. | 2016-09-16 10:50:31 HD Request # 40 | Received 465 records from 2016-09-16 09:48:10 to 2016-09-16 10:35:13 (47.1 minutes) and wrote 465 records for CLF | 2016-09-16 10:50:31 HD Request # 40 | Intraday download COMPLETE for CLF. Completion time: 0s. Unique request ID: 53 | 2016-09-16 10:50:31 Removed historical data download ID 53 | 2016-09-16 10:50:31 Real-time Intraday chart data file updates started for CLF | 2016-09-16 10:50:31 Opened cached Intraday file: C:\SierraChart\Data\CLF.scid | 2016-09-16 10:50:31 Intraday chart data file opened for CLF | 2016-09-16 10:50:31 TD Ameritrade | Using primary service for historical data for CLF | 2016-09-16 10:50:31 Intraday data recording state for symbol CLF is set to download 'Pending'. | 2016-09-16 10:50:31 HD Request # 41 | Downloading Intraday chart data for EVOK to the file EVOK.scid. Service: equities.us | 2016-09-16 10:50:31 HD Request # 41 | Download start Date-Time: 2016-09-16 09:48:05.000 | 2016-09-16 10:50:31 HD Request # 41 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:31 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:31 Socket (46) | Connected. | 2016-09-16 10:50:31 HD Request # 41 | Sending historical data logon request message. | 2016-09-16 10:50:31 HD Request # 41 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:05. Record interval: 1. Symbol: EVOK | 2016-09-16 10:50:31 HD Request # 41 | Decompressing data. | 2016-09-16 10:50:31 HD Request # 41 | Receiving Intraday data for EVOK starting at 2016-09-16 09:48:05 | 2016-09-16 10:50:31 HD Request # 41 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:05 | 2016-09-16 10:50:31 Socket (46) | Shutdown and closed. | 2016-09-16 10:50:31 The network socket for historical data has been closed. | 2016-09-16 10:50:31 HD Request # 41 | Received 16 records from 2016-09-16 09:48:05 to 2016-09-16 10:33:03 (45.0 minutes) and wrote 16 records for EVOK | 2016-09-16 10:50:31 HD Request # 41 | Intraday download COMPLETE for EVOK. Completion time: 1s. Unique request ID: 55 | 2016-09-16 10:50:31 Removed historical data download ID 55 | 2016-09-16 10:50:31 Real-time Intraday chart data file updates started for EVOK | 2016-09-16 10:50:31 Opened cached Intraday file: C:\SierraChart\Data\EVOK.scid | 2016-09-16 10:50:31 Intraday chart data file opened for EVOK | 2016-09-16 10:50:31 TD Ameritrade | Using primary service for historical data for EVOK | 2016-09-16 10:50:31 Intraday data recording state for symbol EVOK is set to download 'Pending'. | 2016-09-16 10:50:31 HD Request # 42 | Downloading Intraday chart data for FNMA to the file FNMA.scid. Service: equities.us | 2016-09-16 10:50:31 HD Request # 42 | Download start Date-Time: 2016-09-16 09:48:21.000 | 2016-09-16 10:50:31 HD Request # 42 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:31 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:31 Socket (47) | Connected. | 2016-09-16 10:50:31 HD Request # 42 | Sending historical data logon request message. | 2016-09-16 10:50:31 HD Request # 42 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:21. Record interval: 1. Symbol: FNMA | 2016-09-16 10:50:31 HD Request # 42 | Decompressing data. | 2016-09-16 10:50:31 HD Request # 42 | Receiving Intraday data for FNMA starting at 2016-09-16 09:48:21 | 2016-09-16 10:50:31 HD Request # 42 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:21 | 2016-09-16 10:50:31 Socket (47) | Shutdown and closed. | 2016-09-16 10:50:31 The network socket for historical data has been closed. | 2016-09-16 10:50:31 HD Request # 42 | Received 241 records from 2016-09-16 09:48:21 to 2016-09-16 10:35:18 (46.9 minutes) and wrote 241 records for FNMA | 2016-09-16 10:50:31 HD Request # 42 | Intraday download COMPLETE for FNMA. Completion time: 0s. Unique request ID: 56 | 2016-09-16 10:50:31 Removed historical data download ID 56 | 2016-09-16 10:50:31 Real-time Intraday chart data file updates started for FNMA | 2016-09-16 10:50:31 Opened cached Intraday file: C:\SierraChart\Data\FNMA.scid | 2016-09-16 10:50:31 Intraday chart data file opened for FNMA | 2016-09-16 10:50:31 TD Ameritrade | Using primary service for historical data for FNMA | 2016-09-16 10:50:31 Intraday data recording state for symbol FNMA is set to download 'Pending'. | 2016-09-16 10:50:31 HD Request # 43 | Downloading Intraday chart data for IMGN to the file IMGN.scid. Service: equities.us | 2016-09-16 10:50:31 HD Request # 43 | Download start Date-Time: 2016-09-16 09:48:27.000 | 2016-09-16 10:50:31 HD Request # 43 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:31 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:31 Socket (48) | Connected. | 2016-09-16 10:50:31 HD Request # 43 | Sending historical data logon request message. | 2016-09-16 10:50:31 HD Request # 43 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:27. Record interval: 1. Symbol: IMGN | 2016-09-16 10:50:31 HD Request # 43 | Decompressing data. | 2016-09-16 10:50:31 HD Request # 43 | Receiving Intraday data for IMGN starting at 2016-09-16 09:48:27 | 2016-09-16 10:50:31 HD Request # 43 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:27 | 2016-09-16 10:50:31 Socket (48) | Shutdown and closed. | 2016-09-16 10:50:31 The network socket for historical data has been closed. | 2016-09-16 10:50:31 HD Request # 43 | Received 172 records from 2016-09-16 09:48:27 to 2016-09-16 10:35:12 (46.8 minutes) and wrote 172 records for IMGN | 2016-09-16 10:50:31 HD Request # 43 | Intraday download COMPLETE for IMGN. Completion time: 0s. Unique request ID: 57 | 2016-09-16 10:50:31 Removed historical data download ID 57 | 2016-09-16 10:50:31 Real-time Intraday chart data file updates started for IMGN | 2016-09-16 10:50:31 Opened cached Intraday file: C:\SierraChart\Data\IMGN.scid | 2016-09-16 10:50:31 Intraday chart data file opened for IMGN | 2016-09-16 10:50:31 TD Ameritrade | Using primary service for historical data for IMGN | 2016-09-16 10:50:31 Intraday data recording state for symbol IMGN is set to download 'Pending'. | 2016-09-16 10:50:31 HD Request # 44 | Downloading Intraday chart data for NRP to the file NRP.scid. Service: equities.us | 2016-09-16 10:50:31 HD Request # 44 | Download start Date-Time: 2016-09-16 10:48:10.000 | 2016-09-16 10:50:31 HD Request # 44 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:31 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:31 Socket (49) | Connected. | 2016-09-16 10:50:31 HD Request # 44 | Sending historical data logon request message. | 2016-09-16 10:50:31 HD Request # 44 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:48:10. Record interval: 1. Symbol: NRP | 2016-09-16 10:50:31 HD Request # 44 | Decompressing data. | 2016-09-16 10:50:31 HD Request # 44 | Receiving Intraday data for NRP starting at 2016-09-15 10:48:33 | 2016-09-16 10:50:31 Socket (49) | Shutdown and closed. | 2016-09-16 10:50:31 The network socket for historical data has been closed. | 2016-09-16 10:50:31 HD Request # 44 | Received 593 records from 2016-09-15 10:48:33 to 2016-09-16 10:35:01 (23.8 hours) and wrote 0 records for NRP | 2016-09-16 10:50:31 HD Request # 44 | Intraday download COMPLETE for NRP. Completion time: 0s. Unique request ID: 58 | 2016-09-16 10:50:31 Removed historical data download ID 58 | 2016-09-16 10:50:31 Real-time Intraday chart data file updates started for NRP | 2016-09-16 10:50:31 Opened cached Intraday file: C:\SierraChart\Data\NRP.scid | 2016-09-16 10:50:31 Intraday chart data file opened for NRP | 2016-09-16 10:50:31 TD Ameritrade | Using primary service for historical data for NRP | 2016-09-16 10:50:31 Intraday data recording state for symbol NRP is set to download 'Pending'. | 2016-09-16 10:50:31 HD Request # 45 | Downloading Intraday chart data for TRIL to the file TRIL.scid. Service: equities.us | 2016-09-16 10:50:31 HD Request # 45 | Download start Date-Time: 2016-09-16 09:36:23.000 | 2016-09-16 10:50:31 HD Request # 45 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:31 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:31 Socket (50) | Connected. | 2016-09-16 10:50:31 HD Request # 45 | Sending historical data logon request message. | 2016-09-16 10:50:31 HD Request # 45 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:36:23. Record interval: 1. Symbol: TRIL | 2016-09-16 10:50:31 HD Request # 45 | Decompressing data. | 2016-09-16 10:50:31 HD Request # 45 | Receiving Intraday data for TRIL starting at 2016-09-16 09:36:23 | 2016-09-16 10:50:31 HD Request # 45 | Timestamp of first Intraday data file record written: 2016-09-16 09:36:23 | 2016-09-16 10:50:31 Socket (50) | Shutdown and closed. | 2016-09-16 10:50:31 The network socket for historical data has been closed. | 2016-09-16 10:50:31 HD Request # 45 | Received 6 records from 2016-09-16 09:36:23 to 2016-09-16 10:33:31 (57.1 minutes) and wrote 6 records for TRIL | 2016-09-16 10:50:31 HD Request # 45 | Intraday download COMPLETE for TRIL. Completion time: 0s. Unique request ID: 59 | 2016-09-16 10:50:31 Removed historical data download ID 59 | 2016-09-16 10:50:31 Real-time Intraday chart data file updates started for TRIL | 2016-09-16 10:50:31 Opened cached Intraday file: C:\SierraChart\Data\TRIL.scid | 2016-09-16 10:50:31 Intraday chart data file opened for TRIL | 2016-09-16 10:50:31 TD Ameritrade | Using primary service for historical data for TRIL | 2016-09-16 10:50:31 Intraday data recording state for symbol TRIL is set to download 'Pending'. | 2016-09-16 10:50:31 HD Request # 46 | Downloading Intraday chart data for VSLR to the file VSLR.scid. Service: equities.us | 2016-09-16 10:50:31 HD Request # 46 | Download start Date-Time: 2016-09-16 09:47:04.000 | 2016-09-16 10:50:31 HD Request # 46 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:31 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:31 Socket (51) | Connected. | 2016-09-16 10:50:31 HD Request # 46 | Sending historical data logon request message. | 2016-09-16 10:50:31 HD Request # 46 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:47:04. Record interval: 1. Symbol: VSLR | 2016-09-16 10:50:31 HD Request # 46 | Decompressing data. | 2016-09-16 10:50:31 HD Request # 46 | Receiving Intraday data for VSLR starting at 2016-09-16 09:47:04 | 2016-09-16 10:50:31 HD Request # 46 | Timestamp of first Intraday data file record written: 2016-09-16 09:47:04 | 2016-09-16 10:50:31 Socket (51) | Shutdown and closed. | 2016-09-16 10:50:31 The network socket for historical data has been closed. | 2016-09-16 10:50:31 HD Request # 46 | Received 68 records from 2016-09-16 09:47:04 to 2016-09-16 10:35:00 (47.9 minutes) and wrote 68 records for VSLR | 2016-09-16 10:50:31 HD Request # 46 | Intraday download COMPLETE for VSLR. Completion time: 0s. Unique request ID: 60 | 2016-09-16 10:50:31 Removed historical data download ID 60 | 2016-09-16 10:50:31 Real-time Intraday chart data file updates started for VSLR | 2016-09-16 10:50:31 Opened cached Intraday file: C:\SierraChart\Data\VSLR.scid | 2016-09-16 10:50:31 Intraday chart data file opened for VSLR | 2016-09-16 10:50:31 TD Ameritrade | Using primary service for historical data for VSLR | 2016-09-16 10:50:31 Intraday data recording state for symbol VSLR is set to download 'Pending'. | 2016-09-16 10:50:31 HD Request # 47 | Downloading Intraday chart data for BXC to the file BXC.scid. Service: equities.us | 2016-09-16 10:50:31 HD Request # 47 | Download start Date-Time: 2016-09-15 15:23:12.000 | 2016-09-16 10:50:31 HD Request # 47 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:31 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:31 Socket (52) | Connected. | 2016-09-16 10:50:32 HD Request # 47 | Sending historical data logon request message. | 2016-09-16 10:50:32 HD Request # 47 | Requesting Intraday data. Start Date-Time: 2016-09-15 15:23:12. Record interval: 1. Symbol: BXC | 2016-09-16 10:50:32 HD Request # 47 | Decompressing data. | 2016-09-16 10:50:32 HD Request # 47 | Receiving Intraday data for BXC starting at 2016-09-15 15:23:12 | 2016-09-16 10:50:32 HD Request # 47 | Timestamp of first Intraday data file record written: 2016-09-15 15:23:12 | 2016-09-16 10:50:32 Socket (52) | Shutdown and closed. | 2016-09-16 10:50:32 The network socket for historical data has been closed. | 2016-09-16 10:50:32 HD Request # 47 | Received 2 records from 2016-09-15 15:23:12 to 2016-09-16 10:06:40 (18.7 hours) and wrote 2 records for BXC | 2016-09-16 10:50:32 HD Request # 47 | Intraday download COMPLETE for BXC. Completion time: 0s. Unique request ID: 62 | 2016-09-16 10:50:32 Removed historical data download ID 62 | 2016-09-16 10:50:32 Real-time Intraday chart data file updates started for BXC | 2016-09-16 10:50:32 Opened cached Intraday file: C:\SierraChart\Data\BXC.scid | 2016-09-16 10:50:32 Intraday chart data file opened for BXC | 2016-09-16 10:50:32 TD Ameritrade | Using primary service for historical data for BXC | 2016-09-16 10:50:32 Intraday data recording state for symbol BXC is set to download 'Pending'. | 2016-09-16 10:50:32 HD Request # 48 | Downloading Intraday chart data for NVAX to the file NVAX.scid. Service: equities.us | 2016-09-16 10:50:32 HD Request # 48 | Download start Date-Time: 2016-09-16 09:48:28.000 | 2016-09-16 10:50:32 HD Request # 48 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:32 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:32 Socket (53) | Connected. | 2016-09-16 10:50:32 HD Request # 48 | Sending historical data logon request message. | 2016-09-16 10:50:32 HD Request # 48 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:28. Record interval: 1. Symbol: NVAX | 2016-09-16 10:50:32 HD Request # 48 | Decompressing data. | 2016-09-16 10:50:32 HD Request # 48 | Receiving Intraday data for NVAX starting at 2016-09-16 09:48:28 | 2016-09-16 10:50:32 HD Request # 48 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:28 | 2016-09-16 10:50:32 Socket (53) | Shutdown and closed. | 2016-09-16 10:50:32 The network socket for historical data has been closed. | 2016-09-16 10:50:32 HD Request # 48 | Received 2625 records from 2016-09-16 09:48:28 to 2016-09-16 10:35:19 (46.9 minutes) and wrote 2625 records for NVAX | 2016-09-16 10:50:32 HD Request # 48 | Intraday download COMPLETE for NVAX. Completion time: 0s. Unique request ID: 63 | 2016-09-16 10:50:32 Removed historical data download ID 63 | 2016-09-16 10:50:32 Real-time Intraday chart data file updates started for NVAX | 2016-09-16 10:50:32 Opened cached Intraday file: C:\SierraChart\Data\NVAX.scid | 2016-09-16 10:50:32 Intraday chart data file opened for NVAX | 2016-09-16 10:50:32 TD Ameritrade | Using primary service for historical data for NVAX | 2016-09-16 10:50:32 Intraday data recording state for symbol NVAX is set to download 'Pending'. | 2016-09-16 10:50:32 HD Request # 49 | Downloading Intraday chart data for AFMD to the file AFMD.scid. Service: equities.us | 2016-09-16 10:50:32 HD Request # 49 | Download start Date-Time: 2016-09-16 10:41:38.000 | 2016-09-16 10:50:32 HD Request # 49 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:32 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:32 Socket (54) | Connected. | 2016-09-16 10:50:32 HD Request # 49 | Sending historical data logon request message. | 2016-09-16 10:50:32 HD Request # 49 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:41:38. Record interval: 1. Symbol: AFMD | 2016-09-16 10:50:32 HD Request # 49 | Decompressing data. | 2016-09-16 10:50:32 HD Request # 49 | Receiving Intraday data for AFMD starting at 2016-09-15 11:07:37 | 2016-09-16 10:50:32 Socket (54) | Shutdown and closed. | 2016-09-16 10:50:32 The network socket for historical data has been closed. | 2016-09-16 10:50:32 HD Request # 49 | Received 68 records from 2016-09-15 11:07:37 to 2016-09-16 10:18:03 (23.2 hours) and wrote 0 records for AFMD | 2016-09-16 10:50:32 HD Request # 49 | Intraday download COMPLETE for AFMD. Completion time: 0s. Unique request ID: 64 | 2016-09-16 10:50:32 Removed historical data download ID 64 | 2016-09-16 10:50:32 Real-time Intraday chart data file updates started for AFMD | 2016-09-16 10:50:32 Opened cached Intraday file: C:\SierraChart\Data\AFMD.scid | 2016-09-16 10:50:32 Intraday chart data file opened for AFMD | 2016-09-16 10:50:32 TD Ameritrade | Using primary service for historical data for AFMD | 2016-09-16 10:50:32 Intraday data recording state for symbol AFMD is set to download 'Pending'. | 2016-09-16 10:50:32 HD Request # 50 | Downloading Intraday chart data for BCEI to the file BCEI.scid. Service: equities.us | 2016-09-16 10:50:32 HD Request # 50 | Download start Date-Time: 2016-09-16 09:46:29.000 | 2016-09-16 10:50:32 HD Request # 50 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:32 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:32 Socket (55) | Connected. | 2016-09-16 10:50:32 HD Request # 50 | Sending historical data logon request message. | 2016-09-16 10:50:32 HD Request # 50 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:46:29. Record interval: 1. Symbol: BCEI | 2016-09-16 10:50:32 HD Request # 50 | Decompressing data. | 2016-09-16 10:50:32 HD Request # 50 | Receiving Intraday data for BCEI starting at 2016-09-16 09:46:29 | 2016-09-16 10:50:32 HD Request # 50 | Timestamp of first Intraday data file record written: 2016-09-16 09:46:29 | 2016-09-16 10:50:32 Socket (55) | Shutdown and closed. | 2016-09-16 10:50:32 The network socket for historical data has been closed. | 2016-09-16 10:50:32 HD Request # 50 | Received 85 records from 2016-09-16 09:46:29 to 2016-09-16 10:34:23 (47.9 minutes) and wrote 85 records for BCEI | 2016-09-16 10:50:32 HD Request # 50 | Intraday download COMPLETE for BCEI. Completion time: 0s. Unique request ID: 65 | 2016-09-16 10:50:32 Removed historical data download ID 65 | 2016-09-16 10:50:32 Real-time Intraday chart data file updates started for BCEI | 2016-09-16 10:50:32 Opened cached Intraday file: C:\SierraChart\Data\BCEI.scid | 2016-09-16 10:50:32 Intraday chart data file opened for BCEI | 2016-09-16 10:50:32 TD Ameritrade | Using primary service for historical data for BCEI | 2016-09-16 10:50:32 Intraday data recording state for symbol BCEI is set to download 'Pending'. | 2016-09-16 10:50:32 HD Request # 51 | Downloading Intraday chart data for CXDC to the file CXDC.scid. Service: equities.us | 2016-09-16 10:50:32 HD Request # 51 | Download start Date-Time: 2016-09-16 10:44:13.000 | 2016-09-16 10:50:32 HD Request # 51 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:32 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:32 Socket (56) | Connected. | 2016-09-16 10:50:32 HD Request # 51 | Sending historical data logon request message. | 2016-09-16 10:50:32 HD Request # 51 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:44:13. Record interval: 1. Symbol: CXDC | 2016-09-16 10:50:32 HD Request # 51 | Decompressing data. | 2016-09-16 10:50:32 HD Request # 51 | Receiving Intraday data for CXDC starting at 2016-09-15 12:20:35 | 2016-09-16 10:50:32 Socket (56) | Shutdown and closed. | 2016-09-16 10:50:32 The network socket for historical data has been closed. | 2016-09-16 10:50:32 HD Request # 51 | Received 12 records from 2016-09-15 12:20:35 to 2016-09-16 09:45:11 (21.4 hours) and wrote 0 records for CXDC | 2016-09-16 10:50:32 HD Request # 51 | Intraday download COMPLETE for CXDC. Completion time: 0s. Unique request ID: 66 | 2016-09-16 10:50:32 Removed historical data download ID 66 | 2016-09-16 10:50:32 Real-time Intraday chart data file updates started for CXDC | 2016-09-16 10:50:32 Opened cached Intraday file: C:\SierraChart\Data\CXDC.scid | 2016-09-16 10:50:32 Intraday chart data file opened for CXDC | 2016-09-16 10:50:32 TD Ameritrade | Using primary service for historical data for CXDC | 2016-09-16 10:50:32 Intraday data recording state for symbol CXDC is set to download 'Pending'. | 2016-09-16 10:50:32 HD Request # 52 | Downloading Intraday chart data for EXAS to the file EXAS.scid. Service: equities.us | 2016-09-16 10:50:32 HD Request # 52 | Download start Date-Time: 2016-09-16 09:48:16.000 | 2016-09-16 10:50:32 HD Request # 52 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:32 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:32 Socket (57) | Connected. | 2016-09-16 10:50:32 HD Request # 52 | Sending historical data logon request message. | 2016-09-16 10:50:32 HD Request # 52 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:16. Record interval: 1. Symbol: EXAS | 2016-09-16 10:50:32 HD Request # 52 | Decompressing data. | 2016-09-16 10:50:32 HD Request # 52 | Receiving Intraday data for EXAS starting at 2016-09-16 09:48:16 | 2016-09-16 10:50:32 HD Request # 52 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:16 | 2016-09-16 10:50:32 Socket (57) | Shutdown and closed. | 2016-09-16 10:50:32 The network socket for historical data has been closed. | 2016-09-16 10:50:32 HD Request # 52 | Received 292 records from 2016-09-16 09:48:16 to 2016-09-16 10:35:16 (47.0 minutes) and wrote 292 records for EXAS | 2016-09-16 10:50:32 HD Request # 52 | Intraday download COMPLETE for EXAS. Completion time: 0s. Unique request ID: 68 | 2016-09-16 10:50:32 Removed historical data download ID 68 | 2016-09-16 10:50:32 Real-time Intraday chart data file updates started for EXAS | 2016-09-16 10:50:32 Opened cached Intraday file: C:\SierraChart\Data\EXAS.scid | 2016-09-16 10:50:32 Intraday chart data file opened for EXAS | 2016-09-16 10:50:32 TD Ameritrade | Using primary service for historical data for EXAS | 2016-09-16 10:50:32 Intraday data recording state for symbol EXAS is set to download 'Pending'. | 2016-09-16 10:50:32 HD Request # 53 | Downloading Intraday chart data for GRSH to the file GRSH.scid. Service: equities.us | 2016-09-16 10:50:32 HD Request # 53 | Download start Date-Time: 2016-09-16 09:48:04.000 | 2016-09-16 10:50:32 HD Request # 53 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:32 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:32 Socket (58) | Connected. | 2016-09-16 10:50:32 HD Request # 53 | Sending historical data logon request message. | 2016-09-16 10:50:32 HD Request # 53 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:04. Record interval: 1. Symbol: GRSH | 2016-09-16 10:50:32 HD Request # 53 | Decompressing data. | 2016-09-16 10:50:32 HD Request # 53 | Receiving Intraday data for GRSH starting at 2016-09-16 09:48:04 | 2016-09-16 10:50:32 HD Request # 53 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:04 | 2016-09-16 10:50:32 Socket (58) | Shutdown and closed. | 2016-09-16 10:50:32 The network socket for historical data has been closed. | 2016-09-16 10:50:32 HD Request # 53 | Received 78 records from 2016-09-16 09:48:04 to 2016-09-16 10:35:08 (47.1 minutes) and wrote 78 records for GRSH | 2016-09-16 10:50:32 HD Request # 53 | Intraday download COMPLETE for GRSH. Completion time: 0s. Unique request ID: 69 | 2016-09-16 10:50:32 Removed historical data download ID 69 | 2016-09-16 10:50:32 Real-time Intraday chart data file updates started for GRSH | 2016-09-16 10:50:32 Opened cached Intraday file: C:\SierraChart\Data\GRSH.scid | 2016-09-16 10:50:32 Intraday chart data file opened for GRSH | 2016-09-16 10:50:32 TD Ameritrade | Using primary service for historical data for GRSH | 2016-09-16 10:50:32 Intraday data recording state for symbol GRSH is set to download 'Pending'. | 2016-09-16 10:50:32 HD Request # 54 | Downloading Intraday chart data for NK to the file NK.scid. Service: equities.us | 2016-09-16 10:50:32 HD Request # 54 | Download start Date-Time: 2016-09-16 09:46:08.000 | 2016-09-16 10:50:32 HD Request # 54 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:32 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:32 Socket (59) | Connected. | 2016-09-16 10:50:32 HD Request # 54 | Sending historical data logon request message. | 2016-09-16 10:50:32 HD Request # 54 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:46:08. Record interval: 1. Symbol: NK | 2016-09-16 10:50:32 HD Request # 54 | Decompressing data. | 2016-09-16 10:50:33 HD Request # 54 | Receiving Intraday data for NK starting at 2016-09-16 09:46:08 | 2016-09-16 10:50:33 HD Request # 54 | Timestamp of first Intraday data file record written: 2016-09-16 09:46:08 | 2016-09-16 10:50:33 Socket (59) | Shutdown and closed. | 2016-09-16 10:50:33 The network socket for historical data has been closed. | 2016-09-16 10:50:33 HD Request # 54 | Received 58 records from 2016-09-16 09:46:08 to 2016-09-16 10:28:53 (42.7 minutes) and wrote 58 records for NK | 2016-09-16 10:50:33 HD Request # 54 | Intraday download COMPLETE for NK. Completion time: 0s. Unique request ID: 70 | 2016-09-16 10:50:33 Removed historical data download ID 70 | 2016-09-16 10:50:33 Real-time Intraday chart data file updates started for NK | 2016-09-16 10:50:33 Opened cached Intraday file: C:\SierraChart\Data\NK.scid | 2016-09-16 10:50:33 Intraday chart data file opened for NK | 2016-09-16 10:50:33 TD Ameritrade | Using primary service for historical data for NK | 2016-09-16 10:50:33 Intraday data recording state for symbol NK is set to download 'Pending'. | 2016-09-16 10:50:33 HD Request # 55 | Downloading Intraday chart data for PIRS to the file PIRS.scid. Service: equities.us | 2016-09-16 10:50:33 HD Request # 55 | Download start Date-Time: 2016-09-16 09:47:52.000 | 2016-09-16 10:50:33 HD Request # 55 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:33 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:33 Socket (60) | Connected. | 2016-09-16 10:50:33 HD Request # 55 | Sending historical data logon request message. | 2016-09-16 10:50:33 HD Request # 55 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:47:52. Record interval: 1. Symbol: PIRS | 2016-09-16 10:50:33 HD Request # 55 | Decompressing data. | 2016-09-16 10:50:33 HD Request # 55 | Receiving Intraday data for PIRS starting at 2016-09-16 09:47:52 | 2016-09-16 10:50:33 HD Request # 55 | Timestamp of first Intraday data file record written: 2016-09-16 09:47:52 | 2016-09-16 10:50:33 Socket (60) | Shutdown and closed. | 2016-09-16 10:50:33 The network socket for historical data has been closed. | 2016-09-16 10:50:33 HD Request # 55 | Received 12 records from 2016-09-16 09:47:52 to 2016-09-16 10:15:32 (27.7 minutes) and wrote 12 records for PIRS | 2016-09-16 10:50:33 HD Request # 55 | Intraday download COMPLETE for PIRS. Completion time: 0s. Unique request ID: 72 | 2016-09-16 10:50:33 Removed historical data download ID 72 | 2016-09-16 10:50:33 Real-time Intraday chart data file updates started for PIRS | 2016-09-16 10:50:33 Opened cached Intraday file: C:\SierraChart\Data\PIRS.scid | 2016-09-16 10:50:33 Intraday chart data file opened for PIRS | 2016-09-16 10:50:33 TD Ameritrade | Using primary service for historical data for PIRS | 2016-09-16 10:50:33 Intraday data recording state for symbol PIRS is set to download 'Pending'. | 2016-09-16 10:50:33 HD Request # 56 | Downloading Intraday chart data for SDRL to the file SDRL.scid. Service: equities.us | 2016-09-16 10:50:33 HD Request # 56 | Download start Date-Time: 2016-09-16 09:48:02.000 | 2016-09-16 10:50:33 HD Request # 56 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 10:50:33 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 10:50:33 Socket (61) | Connected. | 2016-09-16 10:50:33 HD Request # 56 | Sending historical data logon request message. | 2016-09-16 10:50:33 HD Request # 56 | Requesting Intraday data. Start Date-Time: 2016-09-16 09:48:02. Record interval: 1. Symbol: SDRL | 2016-09-16 10:50:33 HD Request # 56 | Decompressing data. | 2016-09-16 10:50:33 HD Request # 56 | Receiving Intraday data for SDRL starting at 2016-09-16 09:48:02 | 2016-09-16 10:50:33 HD Request # 56 | Timestamp of first Intraday data file record written: 2016-09-16 09:48:02 | 2016-09-16 10:50:33 Socket (61) | Shutdown and closed. | 2016-09-16 10:50:33 The network socket for historical data has been closed. | 2016-09-16 10:50:33 HD Request # 56 | Received 512 records from 2016-09-16 09:48:02 to 2016-09-16 10:35:09 (47.1 minutes) and wrote 512 records for SDRL | 2016-09-16 10:50:33 HD Request # 56 | Intraday download COMPLETE for SDRL. Completion time: 0s. Unique request ID: 73 | 2016-09-16 10:50:33 Removed historical data download ID 73 | 2016-09-16 10:50:33 Real-time Intraday chart data file updates started for SDRL | 2016-09-16 10:50:33 Opened cached Intraday file: C:\SierraChart\Data\SDRL.scid | 2016-09-16 10:50:33 Intraday chart data file opened for SDRL | 2016-09-16 10:50:33 TD Ameritrade | Using primary service for historical data for SDRL | 2016-09-16 10:50:33 Intraday data recording state for symbol SDRL is set to download 'Pending'. | 2016-09-16 10:50:33 HD Request # 57 | Downloading Intraday chart data for SORL to the file SORL.scid. Service: equities.us | 2016-09-16 10:50:33 HD Request # 57 | Download start Date-Time: 2016-09-16 10:48:09.000 | 2016-09-16 10:50:33 HD Request # 57 | Using server: ds6.sierracharts.com port 10149 | 2016-09-16 10:50:33 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-09-16 10:50:33 Socket (62) | Connected. | 2016-09-16 10:50:33 HD Request # 57 | Sending historical data logon request message. | 2016-09-16 10:50:33 HD Request # 57 | Requesting Intraday data. Start Date-Time: 2016-09-16 10:48:09. Record interval: 1. Symbol: SORL | 2016-09-16 10:50:33 HD Request # 57 | Decompressing data. | 2016-09-16 10:50:33 HD Request # 57 | Receiving Intraday data for SORL starting at 2016-09-15 10:47:58 | 2016-09-16 10:50:33 Socket (62) | Shutdown and closed. | 2016-09-16 10:50:33 The network socket for historical data has been closed. | 2016-09-16 10:50:33 HD Request # 57 | Received 231 records from 2016-09-15 10:47:58 to 2016-09-16 10:34:12 (23.8 hours) and wrote 0 records for SORL | 2016-09-16 10:50:33 HD Request # 57 | Intraday download COMPLETE for SORL. Completion time: 0s. Unique request ID: 74 | 2016-09-16 10:50:33 Removed historical data download ID 74 | 2016-09-16 10:50:33 Real-time Intraday chart data file updates started for SORL | 2016-09-16 10:50:33 Opened cached Intraday file: C:\SierraChart\Data\SORL.scid | 2016-09-16 10:50:33 Intraday chart data file opened for SORL | 2016-09-16 10:50:33 TD Ameritrade | Using primary service for historical data for SORL | 2016-09-16 10:50:33 Intraday data recording state for symbol SORL is set to download 'Pending'. | 2016-09-16 10:50:33 HD Request # 3 | Error downloading historical Intraday data for CIE. The download timed out. | 2016-09-16 10:51:23 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CIE | 2016-09-16 10:51:23 HD Request # 3 | Receiving Intraday data for CIE starting at 2016-09-16 10:50:25 | 2016-09-16 10:51:23 HD Request # 3 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:25 | 2016-09-16 10:51:23 Added 54 Time and Sales records to Intraday data file for CIE after download. | 2016-09-16 10:51:23 HD Request # 3 | Intraday download COMPLETE for CIE. Completion time: 1m 1s. Unique request ID: 8 | 2016-09-16 10:51:23 Removed historical data download ID 8 | 2016-09-16 10:51:23 Real-time Intraday chart data file updates started for CIE | 2016-09-16 10:51:23 Opened cached Intraday file: C:\SierraChart\Data\CIE.scid | 2016-09-16 10:51:23 Intraday chart data file opened for CIE | 2016-09-16 10:51:23 HD Request # 58 | Downloading Intraday chart data for DJIFF to the file DJIFF.scid. Service: tda | 2016-09-16 10:51:23 HD Request # 58 | Download start Date-Time: 2016-09-16 10:30:19.000 | 2016-09-16 10:51:23 HD Request # 58 | Requesting historical Minute data for the current day. | 2016-09-16 10:51:23 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 10:51:23 HTTPS connection to ameritrade02.streamer.com:443 (63) | Connected. | 2016-09-16 10:51:23 HTTPS connection to ameritrade02.streamer.com:443 (63) | Starting TLS 1.0 connection. | 2016-09-16 10:51:23 HTTPS connection to ameritrade02.streamer.com:443 (63) | SSL connection established. | 2016-09-16 10:51:23 HD Request # 58 | Error downloading historical Intraday data for DJIFF. The download timed out. | 2016-09-16 10:52:23 HD Request # 58 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for DJIFF | 2016-09-16 10:52:23 HD Request # 58 | Intraday download COMPLETE for DJIFF. Completion time: 1m. Unique request ID: 9 | 2016-09-16 10:52:23 Removed historical data download ID 9 | 2016-09-16 10:52:23 Real-time Intraday chart data file updates started for DJIFF | 2016-09-16 10:52:23 Opened cached Intraday file: C:\SierraChart\Data\DJIFF.scid | 2016-09-16 10:52:23 Intraday chart data file opened for DJIFF | 2016-09-16 10:52:23 HD Request # 59 | Downloading Intraday chart data for FES to the file FES.scid. Service: tda | 2016-09-16 10:52:23 HD Request # 59 | Download start Date-Time: 2016-09-16 10:47:00.000 | 2016-09-16 10:52:23 HD Request # 59 | Requesting historical Minute data for the current day. | 2016-09-16 10:52:23 HTTPS connection to ameritrade02.streamer.com:443 (63) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 10:52:28 HTTPS connection to ameritrade02.streamer.com:443 (63) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 10:52:28 HTTPS connection to ameritrade02.streamer.com:443 (63) | SSL has been shut down. | 2016-09-16 10:52:28 HTTPS connection to ameritrade02.streamer.com:443 (63) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 10:52:28 HTTPS connection to ameritrade02.streamer.com:443 (63) | Shutdown and closed. | 2016-09-16 10:52:28 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 10:52:28 HTTPS connection to ameritrade02.streamer.com:443 (65) | Connected. | 2016-09-16 10:52:28 HTTPS connection to ameritrade02.streamer.com:443 (65) | Starting TLS 1.0 connection. | 2016-09-16 10:52:28 HTTPS connection to ameritrade02.streamer.com:443 (65) | SSL connection established. | 2016-09-16 10:52:29 HD Request # 59 | Error downloading historical Intraday data for FES. The download timed out. | 2016-09-16 10:53:23 HD Request # 59 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FES | 2016-09-16 10:53:23 HD Request # 59 | Intraday download COMPLETE for FES. Completion time: 1m. Unique request ID: 10 | 2016-09-16 10:53:23 Removed historical data download ID 10 | 2016-09-16 10:53:23 Real-time Intraday chart data file updates started for FES | 2016-09-16 10:53:23 Opened cached Intraday file: C:\SierraChart\Data\FES.scid | 2016-09-16 10:53:23 Intraday chart data file opened for FES | 2016-09-16 10:53:23 HD Request # 60 | Downloading Intraday chart data for INFI to the file INFI.scid. Service: tda | 2016-09-16 10:53:23 HD Request # 60 | Download start Date-Time: 2016-09-16 10:49:42.000 | 2016-09-16 10:53:23 HD Request # 60 | Requesting historical Minute data for the current day. | 2016-09-16 10:53:23 HTTPS connection to ameritrade02.streamer.com:443 (65) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 10:53:38 HTTPS connection to ameritrade02.streamer.com:443 (65) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 10:53:38 HTTPS connection to ameritrade02.streamer.com:443 (65) | SSL has been shut down. | 2016-09-16 10:53:38 HTTPS connection to ameritrade02.streamer.com:443 (65) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 10:53:38 HTTPS connection to ameritrade02.streamer.com:443 (65) | Shutdown and closed. | 2016-09-16 10:53:38 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 10:53:38 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 25. | 2016-09-16 10:53:38 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 10:53:38 HTTPS connection to ameritrade02.streamer.com:443 (66) | Connected. | 2016-09-16 10:53:38 HTTPS connection to ameritrade02.streamer.com:443 (66) | Starting TLS 1.0 connection. | 2016-09-16 10:53:38 HTTPS connection to ameritrade02.streamer.com:443 (66) | SSL connection established. | 2016-09-16 10:53:39 HD Request # 60 | Error downloading historical Intraday data for INFI. The download timed out. | 2016-09-16 10:54:24 HD Request # 60 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for INFI | 2016-09-16 10:54:24 HD Request # 60 | Receiving Intraday data for INFI starting at 2016-09-16 10:51:58 | 2016-09-16 10:54:24 HD Request # 60 | Timestamp of first Intraday data file record written: 2016-09-16 10:51:58 | 2016-09-16 10:54:24 Added 11 Time and Sales records to Intraday data file for INFI after download. | 2016-09-16 10:54:24 HD Request # 60 | Intraday download COMPLETE for INFI. Completion time: 1m. Unique request ID: 12 | 2016-09-16 10:54:24 Removed historical data download ID 12 | 2016-09-16 10:54:24 Real-time Intraday chart data file updates started for INFI | 2016-09-16 10:54:24 Opened cached Intraday file: C:\SierraChart\Data\INFI.scid | 2016-09-16 10:54:24 Intraday chart data file opened for INFI | 2016-09-16 10:54:24 HD Request # 61 | Downloading Intraday chart data for MRNS to the file MRNS.scid. Service: tda | 2016-09-16 10:54:24 HD Request # 61 | Download start Date-Time: 2016-09-16 10:38:26.000 | 2016-09-16 10:54:24 HD Request # 61 | Requesting historical Minute data for the current day. | 2016-09-16 10:54:24 HTTPS connection to ameritrade02.streamer.com:443 (66) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 10:54:48 HTTPS connection to ameritrade02.streamer.com:443 (66) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 10:54:48 HTTPS connection to ameritrade02.streamer.com:443 (66) | SSL has been shut down. | 2016-09-16 10:54:48 HTTPS connection to ameritrade02.streamer.com:443 (66) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 10:54:48 HTTPS connection to ameritrade02.streamer.com:443 (66) | Shutdown and closed. | 2016-09-16 10:54:48 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 10:54:48 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 26. | 2016-09-16 10:54:48 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 10:54:48 HTTPS connection to ameritrade02.streamer.com:443 (68) | Connected. | 2016-09-16 10:54:48 HTTPS connection to ameritrade02.streamer.com:443 (68) | Starting TLS 1.0 connection. | 2016-09-16 10:54:48 HTTPS connection to ameritrade02.streamer.com:443 (68) | SSL connection established. | 2016-09-16 10:54:49 HD Request # 61 | Error downloading historical Intraday data for MRNS. The download timed out. | 2016-09-16 10:55:24 HD Request # 61 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MRNS | 2016-09-16 10:55:24 HD Request # 61 | Receiving Intraday data for MRNS starting at 2016-09-16 10:51:14 | 2016-09-16 10:55:24 HD Request # 61 | Timestamp of first Intraday data file record written: 2016-09-16 10:51:14 | 2016-09-16 10:55:24 Added 8 Time and Sales records to Intraday data file for MRNS after download. | 2016-09-16 10:55:24 HD Request # 61 | Intraday download COMPLETE for MRNS. Completion time: 1m. Unique request ID: 13 | 2016-09-16 10:55:24 Removed historical data download ID 13 | 2016-09-16 10:55:24 Real-time Intraday chart data file updates started for MRNS | 2016-09-16 10:55:24 Opened cached Intraday file: C:\SierraChart\Data\MRNS.scid | 2016-09-16 10:55:24 Intraday chart data file opened for MRNS | 2016-09-16 10:55:24 HD Request # 62 | Downloading Intraday chart data for PTX to the file PTX.scid. Service: tda | 2016-09-16 10:55:24 HD Request # 62 | Download start Date-Time: 2016-09-16 10:49:55.000 | 2016-09-16 10:55:24 HD Request # 62 | Requesting historical Minute data for the current day. | 2016-09-16 10:55:24 HTTPS connection to ameritrade02.streamer.com:443 (68) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 10:55:58 HTTPS connection to ameritrade02.streamer.com:443 (68) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 10:55:58 HTTPS connection to ameritrade02.streamer.com:443 (68) | SSL has been shut down. | 2016-09-16 10:55:58 HTTPS connection to ameritrade02.streamer.com:443 (68) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 10:55:58 HTTPS connection to ameritrade02.streamer.com:443 (68) | Shutdown and closed. | 2016-09-16 10:55:58 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 10:55:58 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 28. | 2016-09-16 10:55:58 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 10:55:58 HTTPS connection to ameritrade02.streamer.com:443 (69) | Connected. | 2016-09-16 10:55:58 HTTPS connection to ameritrade02.streamer.com:443 (69) | Starting TLS 1.0 connection. | 2016-09-16 10:55:58 HTTPS connection to ameritrade02.streamer.com:443 (69) | SSL connection established. | 2016-09-16 10:55:59 HD Request # 62 | Error downloading historical Intraday data for PTX. The download timed out. | 2016-09-16 10:56:24 HD Request # 62 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for PTX | 2016-09-16 10:56:24 HD Request # 62 | Receiving Intraday data for PTX starting at 2016-09-16 10:50:39 | 2016-09-16 10:56:24 HD Request # 62 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:39 | 2016-09-16 10:56:24 Added 68 Time and Sales records to Intraday data file for PTX after download. | 2016-09-16 10:56:24 HD Request # 62 | Intraday download COMPLETE for PTX. Completion time: 1m. Unique request ID: 16 | 2016-09-16 10:56:24 Removed historical data download ID 16 | 2016-09-16 10:56:24 Real-time Intraday chart data file updates started for PTX | 2016-09-16 10:56:24 Opened cached Intraday file: C:\SierraChart\Data\PTX.scid | 2016-09-16 10:56:24 Intraday chart data file opened for PTX | 2016-09-16 10:56:24 HD Request # 63 | Downloading Intraday chart data for STEM to the file STEM.scid. Service: tda | 2016-09-16 10:56:24 HD Request # 63 | Download start Date-Time: 2016-09-16 10:49:21.000 | 2016-09-16 10:56:24 HD Request # 63 | Requesting historical Minute data for the current day. | 2016-09-16 10:56:24 HTTPS connection to ameritrade02.streamer.com:443 (69) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 10:57:08 HTTPS connection to ameritrade02.streamer.com:443 (69) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 10:57:08 HTTPS connection to ameritrade02.streamer.com:443 (69) | SSL has been shut down. | 2016-09-16 10:57:08 HTTPS connection to ameritrade02.streamer.com:443 (69) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 10:57:08 HTTPS connection to ameritrade02.streamer.com:443 (69) | Shutdown and closed. | 2016-09-16 10:57:08 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 10:57:08 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 29. | 2016-09-16 10:57:08 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 10:57:08 HTTPS connection to ameritrade02.streamer.com:443 (71) | Connected. | 2016-09-16 10:57:08 HTTPS connection to ameritrade02.streamer.com:443 (71) | Starting TLS 1.0 connection. | 2016-09-16 10:57:08 HTTPS connection to ameritrade02.streamer.com:443 (71) | SSL connection established. | 2016-09-16 10:57:09 HD Request # 63 | Error downloading historical Intraday data for STEM. The download timed out. | 2016-09-16 10:57:24 HD Request # 63 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for STEM | 2016-09-16 10:57:24 HD Request # 63 | Receiving Intraday data for STEM starting at 2016-09-16 10:50:36 | 2016-09-16 10:57:24 HD Request # 63 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:36 | 2016-09-16 10:57:24 Added 7 Time and Sales records to Intraday data file for STEM after download. | 2016-09-16 10:57:24 HD Request # 63 | Intraday download COMPLETE for STEM. Completion time: 1m. Unique request ID: 28 | 2016-09-16 10:57:24 Removed historical data download ID 28 | 2016-09-16 10:57:24 Real-time Intraday chart data file updates started for STEM | 2016-09-16 10:57:24 Opened cached Intraday file: C:\SierraChart\Data\STEM.scid | 2016-09-16 10:57:24 Intraday chart data file opened for STEM | 2016-09-16 10:57:24 HD Request # 64 | Downloading Intraday chart data for TERP to the file TERP.scid. Service: equities.us | 2016-09-16 10:57:24 HD Request # 64 | Download start Date-Time: 2016-09-16 10:49:32.000 | 2016-09-16 10:57:24 HD Request # 64 | Requesting historical Minute data for the current day. | 2016-09-16 10:57:24 HTTPS connection to ameritrade02.streamer.com:443 (71) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 10:58:11 HTTPS connection to ameritrade02.streamer.com:443 (71) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 10:58:11 HTTPS connection to ameritrade02.streamer.com:443 (71) | SSL has been shut down. | 2016-09-16 10:58:11 HTTPS connection to ameritrade02.streamer.com:443 (71) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 10:58:11 HTTPS connection to ameritrade02.streamer.com:443 (71) | Shutdown and closed. | 2016-09-16 10:58:11 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 10:58:11 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 30. | 2016-09-16 10:58:11 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 10:58:11 HTTPS connection to ameritrade02.streamer.com:443 (72) | Connected. | 2016-09-16 10:58:11 HTTPS connection to ameritrade02.streamer.com:443 (72) | Starting TLS 1.0 connection. | 2016-09-16 10:58:11 HTTPS connection to ameritrade02.streamer.com:443 (72) | SSL connection established. | 2016-09-16 10:58:11 HD Request # 64 | Error downloading historical Intraday data for TERP. The download timed out. | 2016-09-16 10:58:24 HD Request # 64 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TERP | 2016-09-16 10:58:24 HD Request # 64 | Receiving Intraday data for TERP starting at 2016-09-16 10:50:33 | 2016-09-16 10:58:24 HD Request # 64 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:33 | 2016-09-16 10:58:24 Added 78 Time and Sales records to Intraday data file for TERP after download. | 2016-09-16 10:58:24 HD Request # 64 | Intraday download COMPLETE for TERP. Completion time: 1m. Unique request ID: 31 | 2016-09-16 10:58:24 Removed historical data download ID 31 | 2016-09-16 10:58:24 Real-time Intraday chart data file updates started for TERP | 2016-09-16 10:58:24 Opened cached Intraday file: C:\SierraChart\Data\TERP.scid | 2016-09-16 10:58:24 Intraday chart data file opened for TERP | 2016-09-16 10:58:24 HD Request # 65 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: tda | 2016-09-16 10:58:24 HD Request # 65 | Download start Date-Time: 2016-09-16 10:49:58.000 | 2016-09-16 10:58:24 HD Request # 65 | Requesting historical Minute data for the current day. | 2016-09-16 10:58:24 HTTPS connection to ameritrade02.streamer.com:443 (72) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 10:59:21 HTTPS connection to ameritrade02.streamer.com:443 (72) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 10:59:21 HTTPS connection to ameritrade02.streamer.com:443 (72) | SSL has been shut down. | 2016-09-16 10:59:21 HTTPS connection to ameritrade02.streamer.com:443 (72) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 10:59:21 HTTPS connection to ameritrade02.streamer.com:443 (72) | Shutdown and closed. | 2016-09-16 10:59:21 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 10:59:21 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 32. | 2016-09-16 10:59:21 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 10:59:21 HTTPS connection to ameritrade02.streamer.com:443 (74) | Connected. | 2016-09-16 10:59:21 HTTPS connection to ameritrade02.streamer.com:443 (74) | Starting TLS 1.0 connection. | 2016-09-16 10:59:21 HTTPS connection to ameritrade02.streamer.com:443 (74) | SSL connection established. | 2016-09-16 10:59:21 HD Request # 65 | Error downloading historical Intraday data for AAPL. The download timed out. | 2016-09-16 10:59:24 HD Request # 65 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AAPL | 2016-09-16 10:59:24 HD Request # 65 | Receiving Intraday data for AAPL starting at 2016-09-16 10:50:26 | 2016-09-16 10:59:24 HD Request # 65 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:26 | 2016-09-16 10:59:24 Added 5677 Time and Sales records to Intraday data file for AAPL after download. | 2016-09-16 10:59:24 HD Request # 65 | Intraday download COMPLETE for AAPL. Completion time: 1m. Unique request ID: 36 | 2016-09-16 10:59:24 Removed historical data download ID 36 | 2016-09-16 10:59:24 Real-time Intraday chart data file updates started for AAPL | 2016-09-16 10:59:24 Opened cached Intraday file: C:\SierraChart\Data\AAPL.scid | 2016-09-16 10:59:24 Intraday chart data file opened for AAPL | 2016-09-16 10:59:24 HD Request # 66 | Downloading Intraday chart data for ACIIQ to the file ACIIQ.scid. Service: tda | 2016-09-16 10:59:24 HD Request # 66 | Download start Date-Time: 2016-09-16 10:35:44.000 | 2016-09-16 10:59:24 HD Request # 66 | Requesting historical Minute data for the current day. | 2016-09-16 10:59:24 HD Request # 66 | Error downloading historical Intraday data for ACIIQ. The download timed out. | 2016-09-16 11:00:24 HD Request # 66 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ACIIQ | 2016-09-16 11:00:24 HD Request # 66 | Intraday download COMPLETE for ACIIQ. Completion time: 1m. Unique request ID: 37 | 2016-09-16 11:00:24 Removed historical data download ID 37 | 2016-09-16 11:00:24 Real-time Intraday chart data file updates started for ACIIQ | 2016-09-16 11:00:24 Opened cached Intraday file: C:\SierraChart\Data\ACIIQ.scid | 2016-09-16 11:00:24 Intraday chart data file opened for ACIIQ | 2016-09-16 11:00:24 HD Request # 67 | Downloading Intraday chart data for CBYL to the file CBYL.scid. Service: tda | 2016-09-16 11:00:24 HD Request # 67 | Download start Date-Time: 2016-09-16 10:46:03.000 | 2016-09-16 11:00:24 HD Request # 67 | Requesting historical Minute data for the current day. | 2016-09-16 11:00:24 HTTPS connection to ameritrade02.streamer.com:443 (74) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:00:31 HTTPS connection to ameritrade02.streamer.com:443 (74) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:00:31 HTTPS connection to ameritrade02.streamer.com:443 (74) | SSL has been shut down. | 2016-09-16 11:00:31 HTTPS connection to ameritrade02.streamer.com:443 (74) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:00:31 HTTPS connection to ameritrade02.streamer.com:443 (74) | Shutdown and closed. | 2016-09-16 11:00:31 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:00:31 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 33. | 2016-09-16 11:00:31 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:00:31 HTTPS connection to ameritrade02.streamer.com:443 (76) | Connected. | 2016-09-16 11:00:31 HTTPS connection to ameritrade02.streamer.com:443 (76) | Starting TLS 1.0 connection. | 2016-09-16 11:00:31 HTTPS connection to ameritrade02.streamer.com:443 (76) | SSL connection established. | 2016-09-16 11:00:31 HD Request # 67 | Error downloading historical Intraday data for CBYL. The download timed out. | 2016-09-16 11:01:24 HD Request # 67 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CBYL | 2016-09-16 11:01:24 HD Request # 67 | Receiving Intraday data for CBYL starting at 2016-09-16 10:51:34 | 2016-09-16 11:01:24 HD Request # 67 | Timestamp of first Intraday data file record written: 2016-09-16 10:51:34 | 2016-09-16 11:01:24 Added 5 Time and Sales records to Intraday data file for CBYL after download. | 2016-09-16 11:01:24 HD Request # 67 | Intraday download COMPLETE for CBYL. Completion time: 1m. Unique request ID: 39 | 2016-09-16 11:01:24 Removed historical data download ID 39 | 2016-09-16 11:01:24 Real-time Intraday chart data file updates started for CBYL | 2016-09-16 11:01:24 Opened cached Intraday file: C:\SierraChart\Data\CBYL.scid | 2016-09-16 11:01:24 Intraday chart data file opened for CBYL | 2016-09-16 11:01:24 HD Request # 68 | Downloading Intraday chart data for NFLX to the file NFLX.scid. Service: tda | 2016-09-16 11:01:24 HD Request # 68 | Download start Date-Time: 2016-09-16 10:49:53.000 | 2016-09-16 11:01:24 HD Request # 68 | Requesting historical Minute data for the current day. | 2016-09-16 11:01:24 HTTPS connection to ameritrade02.streamer.com:443 (76) | Error reading data. SSL error: 5. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2016-09-16 11:01:41 * HTTPS connection to ameritrade02.streamer.com:443 (76) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:01:41 HTTPS connection to ameritrade02.streamer.com:443 (76) | SSL has been shut down. | 2016-09-16 11:01:41 HTTPS connection to ameritrade02.streamer.com:443 (76) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:01:41 HTTPS connection to ameritrade02.streamer.com:443 (76) | Shutdown and closed. | 2016-09-16 11:01:41 TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 34. | 2016-09-16 11:01:41 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:01:41 HTTPS connection to ameritrade02.streamer.com:443 (77) | Connected. | 2016-09-16 11:01:41 HTTPS connection to ameritrade02.streamer.com:443 (77) | Starting TLS 1.0 connection. | 2016-09-16 11:01:41 HTTPS connection to ameritrade02.streamer.com:443 (77) | SSL connection established. | 2016-09-16 11:01:41 HD Request # 68 | Error downloading historical Intraday data for NFLX. The download timed out. | 2016-09-16 11:02:24 HD Request # 68 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NFLX | 2016-09-16 11:02:24 HD Request # 68 | Receiving Intraday data for NFLX starting at 2016-09-16 10:50:26 | 2016-09-16 11:02:24 HD Request # 68 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:26 | 2016-09-16 11:02:24 Added 963 Time and Sales records to Intraday data file for NFLX after download. | 2016-09-16 11:02:24 HD Request # 68 | Intraday download COMPLETE for NFLX. Completion time: 1m. Unique request ID: 47 | 2016-09-16 11:02:24 Removed historical data download ID 47 | 2016-09-16 11:02:24 Real-time Intraday chart data file updates started for NFLX | 2016-09-16 11:02:24 Opened cached Intraday file: C:\SierraChart\Data\NFLX.scid | 2016-09-16 11:02:24 Intraday chart data file opened for NFLX | 2016-09-16 11:02:24 HD Request # 69 | Downloading Historical Daily chart data for CIE. Starting date: 2016-09-07. Service: tda | 2016-09-16 11:02:24 HD Request # 69 | Requesting 11 days of historical Daily data. | 2016-09-16 11:02:24 HD Request # 69 | Receiving historical Daily data for CIE starting at 2016-09-07 | 2016-09-16 11:02:24 HD Request # 69 | Writing historical Daily data to the file CIE.dly | 2016-09-16 11:02:24 HD Request # 69 | Received 7 records from 2016-09-07 00:00:00 to 2016-09-15 04:00:00 (9.2 days) and wrote 7 records for CIE | 2016-09-16 11:02:24 HD Request # 69 | Daily download COMPLETE for CIE. Completion time: 0s. Unique request ID: 48 | 2016-09-16 11:02:24 Removed historical data download ID 48 | 2016-09-16 11:02:24 HD Request # 70 | Downloading Intraday chart data for BAS to the file BAS.scid. Service: tda | 2016-09-16 11:02:24 HD Request # 70 | Download start Date-Time: 2016-09-16 10:49:49.000 | 2016-09-16 11:02:24 HD Request # 70 | Requesting historical Minute data for the current day. | 2016-09-16 11:02:24 TD Ameritrade | Using primary service for historical data for CIE | 2016-09-16 11:02:24 CIE Daily #1 | Reloading chart. | 2016-09-16 11:02:24 HTTPS connection to ameritrade02.streamer.com:443 (77) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:02:51 HTTPS connection to ameritrade02.streamer.com:443 (77) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:02:51 HTTPS connection to ameritrade02.streamer.com:443 (77) | SSL has been shut down. | 2016-09-16 11:02:51 HTTPS connection to ameritrade02.streamer.com:443 (77) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:02:51 HTTPS connection to ameritrade02.streamer.com:443 (77) | Shutdown and closed. | 2016-09-16 11:02:51 TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 36. | 2016-09-16 11:02:51 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:02:51 HTTPS connection to ameritrade02.streamer.com:443 (79) | Connected. | 2016-09-16 11:02:51 HTTPS connection to ameritrade02.streamer.com:443 (79) | Starting TLS 1.0 connection. | 2016-09-16 11:02:51 HTTPS connection to ameritrade02.streamer.com:443 (79) | SSL connection established. | 2016-09-16 11:02:51 HD Request # 70 | Error downloading historical Intraday data for BAS. The download timed out. | 2016-09-16 11:03:24 HD Request # 70 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for BAS | 2016-09-16 11:03:24 HD Request # 70 | Receiving Intraday data for BAS starting at 2016-09-16 10:51:18 | 2016-09-16 11:03:24 HD Request # 70 | Timestamp of first Intraday data file record written: 2016-09-16 10:51:18 | 2016-09-16 11:03:24 Added 68 Time and Sales records to Intraday data file for BAS after download. | 2016-09-16 11:03:24 HD Request # 70 | Intraday download COMPLETE for BAS. Completion time: 1m. Unique request ID: 50 | 2016-09-16 11:03:24 Removed historical data download ID 50 | 2016-09-16 11:03:24 Real-time Intraday chart data file updates started for BAS | 2016-09-16 11:03:24 Opened cached Intraday file: C:\SierraChart\Data\BAS.scid | 2016-09-16 11:03:24 Intraday chart data file opened for BAS | 2016-09-16 11:03:24 HD Request # 71 | Downloading Intraday chart data for CMG to the file CMG.scid. Service: equities.us | 2016-09-16 11:03:24 HD Request # 71 | Download start Date-Time: 2016-09-16 10:35:09.000 | 2016-09-16 11:03:24 HD Request # 71 | Requesting historical Minute data for the current day. | 2016-09-16 11:03:24 HTTPS connection to ameritrade02.streamer.com:443 (79) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:04:01 HTTPS connection to ameritrade02.streamer.com:443 (79) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:04:01 HTTPS connection to ameritrade02.streamer.com:443 (79) | SSL has been shut down. | 2016-09-16 11:04:01 HTTPS connection to ameritrade02.streamer.com:443 (79) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:04:01 HTTPS connection to ameritrade02.streamer.com:443 (79) | Shutdown and closed. | 2016-09-16 11:04:01 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:04:01 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 37. | 2016-09-16 11:04:01 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:04:01 HTTPS connection to ameritrade02.streamer.com:443 (80) | Connected. | 2016-09-16 11:04:01 HTTPS connection to ameritrade02.streamer.com:443 (80) | Starting TLS 1.0 connection. | 2016-09-16 11:04:01 HTTPS connection to ameritrade02.streamer.com:443 (80) | SSL connection established. | 2016-09-16 11:04:01 HD Request # 71 | Error downloading historical Intraday data for CMG. The download timed out. | 2016-09-16 11:04:24 HD Request # 71 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CMG | 2016-09-16 11:04:24 HD Request # 71 | Receiving Intraday data for CMG starting at 2016-09-16 10:50:55 | 2016-09-16 11:04:24 HD Request # 71 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:55 | 2016-09-16 11:04:24 Added 366 Time and Sales records to Intraday data file for CMG after download. | 2016-09-16 11:04:24 HD Request # 71 | Intraday download COMPLETE for CMG. Completion time: 1m. Unique request ID: 52 | 2016-09-16 11:04:24 Removed historical data download ID 52 | 2016-09-16 11:04:24 Real-time Intraday chart data file updates started for CMG | 2016-09-16 11:04:24 Opened cached Intraday file: C:\SierraChart\Data\CMG.scid | 2016-09-16 11:04:24 Intraday chart data file opened for CMG | 2016-09-16 11:04:24 HD Request # 72 | Downloading Intraday chart data for DNAI to the file DNAI.scid. Service: tda | 2016-09-16 11:04:24 HD Request # 72 | Download start Date-Time: 2016-09-16 10:48:20.000 | 2016-09-16 11:04:24 HD Request # 72 | Requesting historical Minute data for the current day. | 2016-09-16 11:04:24 HTTPS connection to ameritrade02.streamer.com:443 (80) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (80) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (80) | SSL has been shut down. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (80) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (80) | Shutdown and closed. | 2016-09-16 11:05:11 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:05:11 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 38. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (82) | Connected. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (82) | Starting TLS 1.0 connection. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (82) | SSL connection established. | 2016-09-16 11:05:11 HD Request # 72 | Error downloading historical Intraday data for DNAI. The download timed out. | 2016-09-16 11:05:24 HD Request # 72 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for DNAI | 2016-09-16 11:05:24 HD Request # 72 | Receiving Intraday data for DNAI starting at 2016-09-16 10:55:49 | 2016-09-16 11:05:24 HD Request # 72 | Timestamp of first Intraday data file record written: 2016-09-16 10:55:49 | 2016-09-16 11:05:24 Added 11 Time and Sales records to Intraday data file for DNAI after download. | 2016-09-16 11:05:24 HD Request # 72 | Intraday download COMPLETE for DNAI. Completion time: 1m. Unique request ID: 54 | 2016-09-16 11:05:24 Removed historical data download ID 54 | 2016-09-16 11:05:24 Real-time Intraday chart data file updates started for DNAI | 2016-09-16 11:05:24 Opened cached Intraday file: C:\SierraChart\Data\DNAI.scid | 2016-09-16 11:05:24 Intraday chart data file opened for DNAI | 2016-09-16 11:05:24 HD Request # 73 | Downloading Intraday chart data for PSID to the file PSID.scid. Service: tda | 2016-09-16 11:05:24 HD Request # 73 | Download start Date-Time: 2016-09-16 10:38:23.000 | 2016-09-16 11:05:24 HD Request # 73 | Requesting historical Minute data for the current day. | 2016-09-16 11:05:24 HTTPS connection to ameritrade02.streamer.com:443 (82) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:06:21 HTTPS connection to ameritrade02.streamer.com:443 (82) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:06:21 HTTPS connection to ameritrade02.streamer.com:443 (82) | SSL has been shut down. | 2016-09-16 11:06:21 HTTPS connection to ameritrade02.streamer.com:443 (82) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:06:21 HTTPS connection to ameritrade02.streamer.com:443 (82) | Shutdown and closed. | 2016-09-16 11:06:21 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:06:21 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 41. | 2016-09-16 11:06:21 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:06:21 HTTPS connection to ameritrade02.streamer.com:443 (84) | Connected. | 2016-09-16 11:06:21 HTTPS connection to ameritrade02.streamer.com:443 (84) | Starting TLS 1.0 connection. | 2016-09-16 11:06:21 HTTPS connection to ameritrade02.streamer.com:443 (84) | SSL connection established. | 2016-09-16 11:06:21 HD Request # 73 | Error downloading historical Intraday data for PSID. The download timed out. | 2016-09-16 11:06:24 HD Request # 73 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for PSID | 2016-09-16 11:06:24 HD Request # 73 | Receiving Intraday data for PSID starting at 2016-09-16 11:06:21 | 2016-09-16 11:06:24 HD Request # 73 | Timestamp of first Intraday data file record written: 2016-09-16 11:06:21 | 2016-09-16 11:06:24 Added 2 Time and Sales records to Intraday data file for PSID after download. | 2016-09-16 11:06:24 HD Request # 73 | Intraday download COMPLETE for PSID. Completion time: 1m. Unique request ID: 61 | 2016-09-16 11:06:24 Removed historical data download ID 61 | 2016-09-16 11:06:24 Real-time Intraday chart data file updates started for PSID | 2016-09-16 11:06:24 Opened cached Intraday file: C:\SierraChart\Data\PSID.scid | 2016-09-16 11:06:24 Intraday chart data file opened for PSID | 2016-09-16 11:06:24 HD Request # 74 | Downloading Intraday chart data for DRYS to the file DRYS.scid. Service: tda | 2016-09-16 11:06:24 HD Request # 74 | Download start Date-Time: 2016-09-16 10:49:49.000 | 2016-09-16 11:06:24 HD Request # 74 | Requesting historical Minute data for the current day. | 2016-09-16 11:06:24 HD Request # 74 | Error downloading historical Intraday data for DRYS. The download timed out. | 2016-09-16 11:07:24 HD Request # 74 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for DRYS | 2016-09-16 11:07:24 HD Request # 74 | Receiving Intraday data for DRYS starting at 2016-09-16 10:50:29 | 2016-09-16 11:07:24 HD Request # 74 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:29 | 2016-09-16 11:07:24 Added 147 Time and Sales records to Intraday data file for DRYS after download. | 2016-09-16 11:07:24 HD Request # 74 | Intraday download COMPLETE for DRYS. Completion time: 1m. Unique request ID: 67 | 2016-09-16 11:07:24 Removed historical data download ID 67 | 2016-09-16 11:07:24 Real-time Intraday chart data file updates started for DRYS | 2016-09-16 11:07:24 Opened cached Intraday file: C:\SierraChart\Data\DRYS.scid | 2016-09-16 11:07:24 Intraday chart data file opened for DRYS | 2016-09-16 11:07:24 HD Request # 75 | Downloading Intraday chart data for FB to the file FB.scid. Service: equities.us | 2016-09-16 11:07:24 HD Request # 75 | Download start Date-Time: 2016-09-16 10:49:58.000 | 2016-09-16 11:07:24 HD Request # 75 | Requesting historical Minute data for the current day. | 2016-09-16 11:07:24 HTTPS connection to ameritrade02.streamer.com:443 (84) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:07:31 HTTPS connection to ameritrade02.streamer.com:443 (84) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:07:31 HTTPS connection to ameritrade02.streamer.com:443 (84) | SSL has been shut down. | 2016-09-16 11:07:31 HTTPS connection to ameritrade02.streamer.com:443 (84) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:07:31 HTTPS connection to ameritrade02.streamer.com:443 (84) | Shutdown and closed. | 2016-09-16 11:07:31 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:07:31 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 42. | 2016-09-16 11:07:31 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:07:31 HTTPS connection to ameritrade02.streamer.com:443 (85) | Connected. | 2016-09-16 11:07:31 HTTPS connection to ameritrade02.streamer.com:443 (85) | Starting TLS 1.0 connection. | 2016-09-16 11:07:31 HTTPS connection to ameritrade02.streamer.com:443 (85) | SSL connection established. | 2016-09-16 11:07:31 HD Request # 75 | Error downloading historical Intraday data for FB. The download timed out. | 2016-09-16 11:08:24 HD Request # 75 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FB | 2016-09-16 11:08:24 HD Request # 75 | Receiving Intraday data for FB starting at 2016-09-16 10:50:26 | 2016-09-16 11:08:24 HD Request # 75 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:26 | 2016-09-16 11:08:24 Added 2746 Time and Sales records to Intraday data file for FB after download. | 2016-09-16 11:08:24 HD Request # 75 | Intraday download COMPLETE for FB. Completion time: 1m. Unique request ID: 71 | 2016-09-16 11:08:24 Removed historical data download ID 71 | 2016-09-16 11:08:24 Real-time Intraday chart data file updates started for FB | 2016-09-16 11:08:24 Opened cached Intraday file: C:\SierraChart\Data\FB.scid | 2016-09-16 11:08:24 Intraday chart data file opened for FB | 2016-09-16 11:08:24 HD Request # 76 | Downloading Intraday chart data for TKAI to the file TKAI.scid. Service: equities.us | 2016-09-16 11:08:24 HD Request # 76 | Download start Date-Time: 2016-09-16 10:49:22.000 | 2016-09-16 11:08:24 HD Request # 76 | Requesting historical Minute data for the current day. | 2016-09-16 11:08:24 HTTPS connection to ameritrade02.streamer.com:443 (85) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:08:41 HTTPS connection to ameritrade02.streamer.com:443 (85) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:08:41 HTTPS connection to ameritrade02.streamer.com:443 (85) | SSL has been shut down. | 2016-09-16 11:08:41 HTTPS connection to ameritrade02.streamer.com:443 (85) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:08:41 HTTPS connection to ameritrade02.streamer.com:443 (85) | Shutdown and closed. | 2016-09-16 11:08:41 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:08:41 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 43. | 2016-09-16 11:08:41 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:08:41 HTTPS connection to ameritrade02.streamer.com:443 (87) | Connected. | 2016-09-16 11:08:41 HTTPS connection to ameritrade02.streamer.com:443 (87) | Starting TLS 1.0 connection. | 2016-09-16 11:08:41 HTTPS connection to ameritrade02.streamer.com:443 (87) | SSL connection established. | 2016-09-16 11:08:41 HD Request # 76 | Error downloading historical Intraday data for TKAI. The download timed out. | 2016-09-16 11:09:24 HD Request # 76 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TKAI | 2016-09-16 11:09:24 HD Request # 76 | Receiving Intraday data for TKAI starting at 2016-09-16 10:51:44 | 2016-09-16 11:09:24 HD Request # 76 | Timestamp of first Intraday data file record written: 2016-09-16 10:51:44 | 2016-09-16 11:09:24 Added 152 Time and Sales records to Intraday data file for TKAI after download. | 2016-09-16 11:09:24 HD Request # 76 | Intraday download COMPLETE for TKAI. Completion time: 1m. Unique request ID: 75 | 2016-09-16 11:09:24 Removed historical data download ID 75 | 2016-09-16 11:09:24 Real-time Intraday chart data file updates started for TKAI | 2016-09-16 11:09:24 Opened cached Intraday file: C:\SierraChart\Data\TKAI.scid | 2016-09-16 11:09:24 Intraday chart data file opened for TKAI | 2016-09-16 11:09:24 HD Request # 77 | Downloading Intraday chart data for ABUS to the file ABUS.scid. Service: equities.us | 2016-09-16 11:09:24 HD Request # 77 | Download start Date-Time: 2016-09-16 10:47:38.000 | 2016-09-16 11:09:24 HD Request # 77 | Requesting historical Minute data for the current day. | 2016-09-16 11:09:24 HTTPS connection to ameritrade02.streamer.com:443 (87) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:09:51 HTTPS connection to ameritrade02.streamer.com:443 (87) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:09:51 HTTPS connection to ameritrade02.streamer.com:443 (87) | SSL has been shut down. | 2016-09-16 11:09:51 HTTPS connection to ameritrade02.streamer.com:443 (87) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:09:51 HTTPS connection to ameritrade02.streamer.com:443 (87) | Shutdown and closed. | 2016-09-16 11:09:51 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:09:51 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 45. | 2016-09-16 11:09:51 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:09:51 HTTPS connection to ameritrade02.streamer.com:443 (88) | Connected. | 2016-09-16 11:09:51 HTTPS connection to ameritrade02.streamer.com:443 (88) | Starting TLS 1.0 connection. | 2016-09-16 11:09:51 HTTPS connection to ameritrade02.streamer.com:443 (88) | SSL connection established. | 2016-09-16 11:09:51 HD Request # 77 | Error downloading historical Intraday data for ABUS. The download timed out. | 2016-09-16 11:10:24 HD Request # 77 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ABUS | 2016-09-16 11:10:24 HD Request # 77 | Receiving Intraday data for ABUS starting at 2016-09-16 10:51:21 | 2016-09-16 11:10:24 HD Request # 77 | Timestamp of first Intraday data file record written: 2016-09-16 10:51:21 | 2016-09-16 11:10:24 Added 26 Time and Sales records to Intraday data file for ABUS after download. | 2016-09-16 11:10:24 HD Request # 77 | Intraday download COMPLETE for ABUS. Completion time: 1m 1s. Unique request ID: 76 | 2016-09-16 11:10:24 Removed historical data download ID 76 | 2016-09-16 11:10:24 Real-time Intraday chart data file updates started for ABUS | 2016-09-16 11:10:24 Opened cached Intraday file: C:\SierraChart\Data\ABUS.scid | 2016-09-16 11:10:24 Intraday chart data file opened for ABUS | 2016-09-16 11:10:24 HD Request # 78 | Downloading Intraday chart data for AMCN to the file AMCN.scid. Service: equities.us | 2016-09-16 11:10:24 HD Request # 78 | Download start Date-Time: 2016-09-16 10:25:49.000 | 2016-09-16 11:10:24 HD Request # 78 | Requesting historical Minute data for the current day. | 2016-09-16 11:10:24 HTTPS connection to ameritrade02.streamer.com:443 (88) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:11:01 HTTPS connection to ameritrade02.streamer.com:443 (88) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:11:01 HTTPS connection to ameritrade02.streamer.com:443 (88) | SSL has been shut down. | 2016-09-16 11:11:01 HTTPS connection to ameritrade02.streamer.com:443 (88) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:11:01 HTTPS connection to ameritrade02.streamer.com:443 (88) | Shutdown and closed. | 2016-09-16 11:11:01 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:11:01 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 46. | 2016-09-16 11:11:01 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:11:01 HTTPS connection to ameritrade02.streamer.com:443 (90) | Connected. | 2016-09-16 11:11:01 HTTPS connection to ameritrade02.streamer.com:443 (90) | Starting TLS 1.0 connection. | 2016-09-16 11:11:01 HTTPS connection to ameritrade02.streamer.com:443 (90) | SSL connection established. | 2016-09-16 11:11:01 HD Request # 78 | Error downloading historical Intraday data for AMCN. The download timed out. | 2016-09-16 11:11:24 HD Request # 78 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AMCN | 2016-09-16 11:11:24 HD Request # 78 | Receiving Intraday data for AMCN starting at 2016-09-16 10:59:43 | 2016-09-16 11:11:24 HD Request # 78 | Timestamp of first Intraday data file record written: 2016-09-16 10:59:43 | 2016-09-16 11:11:24 Added 14 Time and Sales records to Intraday data file for AMCN after download. | 2016-09-16 11:11:24 HD Request # 78 | Intraday download COMPLETE for AMCN. Completion time: 1m. Unique request ID: 77 | 2016-09-16 11:11:24 Removed historical data download ID 77 | 2016-09-16 11:11:24 Real-time Intraday chart data file updates started for AMCN | 2016-09-16 11:11:24 Opened cached Intraday file: C:\SierraChart\Data\AMCN.scid | 2016-09-16 11:11:24 Intraday chart data file opened for AMCN | 2016-09-16 11:11:24 HD Request # 79 | Downloading Intraday chart data for BTUUQ to the file BTUUQ.scid. Service: equities.us | 2016-09-16 11:11:24 HD Request # 79 | Download start Date-Time: 2016-09-16 10:42:44.000 | 2016-09-16 11:11:24 HD Request # 79 | Requesting historical Minute data for the current day. | 2016-09-16 11:11:24 HTTPS connection to ameritrade02.streamer.com:443 (90) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:12:11 HTTPS connection to ameritrade02.streamer.com:443 (90) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:12:11 HTTPS connection to ameritrade02.streamer.com:443 (90) | SSL has been shut down. | 2016-09-16 11:12:11 HTTPS connection to ameritrade02.streamer.com:443 (90) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:12:11 HTTPS connection to ameritrade02.streamer.com:443 (90) | Shutdown and closed. | 2016-09-16 11:12:11 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:12:11 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 47. | 2016-09-16 11:12:11 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:12:11 HTTPS connection to ameritrade02.streamer.com:443 (91) | Connected. | 2016-09-16 11:12:11 HTTPS connection to ameritrade02.streamer.com:443 (91) | Starting TLS 1.0 connection. | 2016-09-16 11:12:11 HTTPS connection to ameritrade02.streamer.com:443 (91) | SSL connection established. | 2016-09-16 11:12:11 HD Request # 79 | Error downloading historical Intraday data for BTUUQ. The download timed out. | 2016-09-16 11:12:24 HD Request # 79 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for BTUUQ | 2016-09-16 11:12:24 HD Request # 79 | Receiving Intraday data for BTUUQ starting at 2016-09-16 10:51:02 | 2016-09-16 11:12:24 HD Request # 79 | Timestamp of first Intraday data file record written: 2016-09-16 10:51:02 | 2016-09-16 11:12:24 Added 6 Time and Sales records to Intraday data file for BTUUQ after download. | 2016-09-16 11:12:24 HD Request # 79 | Intraday download COMPLETE for BTUUQ. Completion time: 1m. Unique request ID: 78 | 2016-09-16 11:12:24 Removed historical data download ID 78 | 2016-09-16 11:12:24 Real-time Intraday chart data file updates started for BTUUQ | 2016-09-16 11:12:24 Opened cached Intraday file: C:\SierraChart\Data\BTUUQ.scid | 2016-09-16 11:12:24 Intraday chart data file opened for BTUUQ | 2016-09-16 11:12:24 HD Request # 80 | Downloading Intraday chart data for GSAT to the file GSAT.scid. Service: equities.us | 2016-09-16 11:12:24 HD Request # 80 | Download start Date-Time: 2016-09-16 10:49:40.000 | 2016-09-16 11:12:24 HD Request # 80 | Requesting historical Minute data for the current day. | 2016-09-16 11:12:24 HTTPS connection to ameritrade02.streamer.com:443 (91) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:13:21 HTTPS connection to ameritrade02.streamer.com:443 (91) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:13:21 HTTPS connection to ameritrade02.streamer.com:443 (91) | SSL has been shut down. | 2016-09-16 11:13:21 HTTPS connection to ameritrade02.streamer.com:443 (91) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:13:21 HTTPS connection to ameritrade02.streamer.com:443 (91) | Shutdown and closed. | 2016-09-16 11:13:21 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:13:21 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 49. | 2016-09-16 11:13:21 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:13:21 HTTPS connection to ameritrade02.streamer.com:443 (93) | Connected. | 2016-09-16 11:13:21 HTTPS connection to ameritrade02.streamer.com:443 (93) | Starting TLS 1.0 connection. | 2016-09-16 11:13:21 HTTPS connection to ameritrade02.streamer.com:443 (93) | SSL connection established. | 2016-09-16 11:13:21 HD Request # 80 | Error downloading historical Intraday data for GSAT. The download timed out. | 2016-09-16 11:13:24 HD Request # 80 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GSAT | 2016-09-16 11:13:24 HD Request # 80 | Receiving Intraday data for GSAT starting at 2016-09-16 10:50:42 | 2016-09-16 11:13:24 HD Request # 80 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:42 | 2016-09-16 11:13:24 Added 221 Time and Sales records to Intraday data file for GSAT after download. | 2016-09-16 11:13:24 HD Request # 80 | Intraday download COMPLETE for GSAT. Completion time: 1m. Unique request ID: 79 | 2016-09-16 11:13:24 Removed historical data download ID 79 | 2016-09-16 11:13:24 Real-time Intraday chart data file updates started for GSAT | 2016-09-16 11:13:24 Opened cached Intraday file: C:\SierraChart\Data\GSAT.scid | 2016-09-16 11:13:24 Intraday chart data file opened for GSAT | 2016-09-16 11:13:24 HD Request # 81 | Downloading Intraday chart data for NKTR to the file NKTR.scid. Service: equities.us | 2016-09-16 11:13:24 HD Request # 81 | Download start Date-Time: 2016-09-16 10:34:54.000 | 2016-09-16 11:13:24 HD Request # 81 | Requesting historical Minute data for the current day. | 2016-09-16 11:13:24 HD Request # 81 | Error downloading historical Intraday data for NKTR. The download timed out. | 2016-09-16 11:14:24 HD Request # 81 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NKTR | 2016-09-16 11:14:24 HD Request # 81 | Receiving Intraday data for NKTR starting at 2016-09-16 10:50:44 | 2016-09-16 11:14:24 HD Request # 81 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:44 | 2016-09-16 11:14:24 Added 479 Time and Sales records to Intraday data file for NKTR after download. | 2016-09-16 11:14:24 HD Request # 81 | Intraday download COMPLETE for NKTR. Completion time: 1m. Unique request ID: 80 | 2016-09-16 11:14:24 Removed historical data download ID 80 | 2016-09-16 11:14:24 Real-time Intraday chart data file updates started for NKTR | 2016-09-16 11:14:24 Opened cached Intraday file: C:\SierraChart\Data\NKTR.scid | 2016-09-16 11:14:24 Intraday chart data file opened for NKTR | 2016-09-16 11:14:24 HD Request # 82 | Downloading Intraday chart data for NUGT to the file NUGT.scid. Service: equities.us | 2016-09-16 11:14:24 HD Request # 82 | Download start Date-Time: 2016-09-16 10:35:14.000 | 2016-09-16 11:14:24 HD Request # 82 | Requesting historical Minute data for the current day. | 2016-09-16 11:14:24 HTTPS connection to ameritrade02.streamer.com:443 (93) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:14:31 HTTPS connection to ameritrade02.streamer.com:443 (93) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:14:31 HTTPS connection to ameritrade02.streamer.com:443 (93) | SSL has been shut down. | 2016-09-16 11:14:31 HTTPS connection to ameritrade02.streamer.com:443 (93) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:14:31 HTTPS connection to ameritrade02.streamer.com:443 (93) | Shutdown and closed. | 2016-09-16 11:14:31 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:14:31 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 50. | 2016-09-16 11:14:31 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:14:31 HTTPS connection to ameritrade02.streamer.com:443 (95) | Connected. | 2016-09-16 11:14:31 HTTPS connection to ameritrade02.streamer.com:443 (95) | Starting TLS 1.0 connection. | 2016-09-16 11:14:31 HTTPS connection to ameritrade02.streamer.com:443 (95) | SSL connection established. | 2016-09-16 11:14:31 HD Request # 82 | Error downloading historical Intraday data for NUGT. The download timed out. | 2016-09-16 11:15:24 HD Request # 82 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NUGT | 2016-09-16 11:15:24 HD Request # 82 | Receiving Intraday data for NUGT starting at 2016-09-16 10:50:26 | 2016-09-16 11:15:24 HD Request # 82 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:26 | 2016-09-16 11:15:24 Added 3225 Time and Sales records to Intraday data file for NUGT after download. | 2016-09-16 11:15:24 HD Request # 82 | Intraday download COMPLETE for NUGT. Completion time: 1m. Unique request ID: 81 | 2016-09-16 11:15:24 Removed historical data download ID 81 | 2016-09-16 11:15:24 Real-time Intraday chart data file updates started for NUGT | 2016-09-16 11:15:24 Opened cached Intraday file: C:\SierraChart\Data\NUGT.scid | 2016-09-16 11:15:24 Intraday chart data file opened for NUGT | 2016-09-16 11:15:24 HD Request # 83 | Downloading Intraday chart data for SXC to the file SXC.scid. Service: equities.us | 2016-09-16 11:15:24 HD Request # 83 | Download start Date-Time: 2016-09-16 10:49:10.000 | 2016-09-16 11:15:24 HD Request # 83 | Requesting historical Minute data for the current day. | 2016-09-16 11:15:24 HTTPS connection to ameritrade02.streamer.com:443 (95) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:15:41 HTTPS connection to ameritrade02.streamer.com:443 (95) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:15:41 HTTPS connection to ameritrade02.streamer.com:443 (95) | SSL has been shut down. | 2016-09-16 11:15:41 HTTPS connection to ameritrade02.streamer.com:443 (95) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:15:41 HTTPS connection to ameritrade02.streamer.com:443 (95) | Shutdown and closed. | 2016-09-16 11:15:41 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:15:41 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 51. | 2016-09-16 11:15:41 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:15:41 HTTPS connection to ameritrade02.streamer.com:443 (96) | Connected. | 2016-09-16 11:15:41 HTTPS connection to ameritrade02.streamer.com:443 (96) | Starting TLS 1.0 connection. | 2016-09-16 11:15:41 HTTPS connection to ameritrade02.streamer.com:443 (96) | SSL connection established. | 2016-09-16 11:15:41 HD Request # 83 | Error downloading historical Intraday data for SXC. The download timed out. | 2016-09-16 11:16:24 HD Request # 83 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SXC | 2016-09-16 11:16:24 HD Request # 83 | Receiving Intraday data for SXC starting at 2016-09-16 10:50:35 | 2016-09-16 11:16:24 HD Request # 83 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:35 | 2016-09-16 11:16:24 Added 180 Time and Sales records to Intraday data file for SXC after download. | 2016-09-16 11:16:24 HD Request # 83 | Intraday download COMPLETE for SXC. Completion time: 1m. Unique request ID: 82 | 2016-09-16 11:16:24 Removed historical data download ID 82 | 2016-09-16 11:16:24 Real-time Intraday chart data file updates started for SXC | 2016-09-16 11:16:24 Opened cached Intraday file: C:\SierraChart\Data\SXC.scid | 2016-09-16 11:16:24 Intraday chart data file opened for SXC | 2016-09-16 11:16:24 HD Request # 84 | Downloading Intraday chart data for UWTI to the file UWTI.scid. Service: equities.us | 2016-09-16 11:16:24 HD Request # 84 | Download start Date-Time: 2016-09-16 10:49:58.000 | 2016-09-16 11:16:24 HD Request # 84 | Requesting historical Minute data for the current day. | 2016-09-16 11:16:24 HTTPS connection to ameritrade02.streamer.com:443 (96) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:16:51 HTTPS connection to ameritrade02.streamer.com:443 (96) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:16:51 HTTPS connection to ameritrade02.streamer.com:443 (96) | SSL has been shut down. | 2016-09-16 11:16:51 HTTPS connection to ameritrade02.streamer.com:443 (96) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:16:51 HTTPS connection to ameritrade02.streamer.com:443 (96) | Shutdown and closed. | 2016-09-16 11:16:51 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:16:51 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 53. | 2016-09-16 11:16:51 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:16:51 HTTPS connection to ameritrade02.streamer.com:443 (98) | Connected. | 2016-09-16 11:16:51 HTTPS connection to ameritrade02.streamer.com:443 (98) | Starting TLS 1.0 connection. | 2016-09-16 11:16:51 HTTPS connection to ameritrade02.streamer.com:443 (98) | SSL connection established. | 2016-09-16 11:16:51 HD Request # 84 | Error downloading historical Intraday data for UWTI. The download timed out. | 2016-09-16 11:17:24 HD Request # 84 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for UWTI | 2016-09-16 11:17:24 HD Request # 84 | Receiving Intraday data for UWTI starting at 2016-09-16 10:52:19 | 2016-09-16 11:17:24 HD Request # 84 | Timestamp of first Intraday data file record written: 2016-09-16 10:52:19 | 2016-09-16 11:17:24 Added 6407 Time and Sales records to Intraday data file for UWTI after download. | 2016-09-16 11:17:24 HD Request # 84 | Intraday download COMPLETE for UWTI. Completion time: 1m. Unique request ID: 83 | 2016-09-16 11:17:24 Removed historical data download ID 83 | 2016-09-16 11:17:24 Real-time Intraday chart data file updates started for UWTI | 2016-09-16 11:17:24 Opened cached Intraday file: C:\SierraChart\Data\UWTI.scid | 2016-09-16 11:17:24 Intraday chart data file opened for UWTI | 2016-09-16 11:17:24 HD Request # 85 | Downloading Intraday chart data for ZFGN to the file ZFGN.scid. Service: equities.us | 2016-09-16 11:17:24 HD Request # 85 | Download start Date-Time: 2016-09-16 10:33:26.000 | 2016-09-16 11:17:24 HD Request # 85 | Requesting historical Minute data for the current day. | 2016-09-16 11:17:24 HTTPS connection to ameritrade02.streamer.com:443 (98) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:18:01 HTTPS connection to ameritrade02.streamer.com:443 (98) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:18:01 HTTPS connection to ameritrade02.streamer.com:443 (98) | SSL has been shut down. | 2016-09-16 11:18:01 HTTPS connection to ameritrade02.streamer.com:443 (98) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:18:01 HTTPS connection to ameritrade02.streamer.com:443 (98) | Shutdown and closed. | 2016-09-16 11:18:01 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:18:01 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 54. | 2016-09-16 11:18:01 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:18:01 HTTPS connection to ameritrade02.streamer.com:443 (99) | Connected. | 2016-09-16 11:18:01 HTTPS connection to ameritrade02.streamer.com:443 (99) | Starting TLS 1.0 connection. | 2016-09-16 11:18:01 HTTPS connection to ameritrade02.streamer.com:443 (99) | SSL connection established. | 2016-09-16 11:18:01 HD Request # 85 | Error downloading historical Intraday data for ZFGN. The download timed out. | 2016-09-16 11:18:24 HD Request # 85 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZFGN | 2016-09-16 11:18:24 HD Request # 85 | Receiving Intraday data for ZFGN starting at 2016-09-16 10:53:13 | 2016-09-16 11:18:24 HD Request # 85 | Timestamp of first Intraday data file record written: 2016-09-16 10:53:13 | 2016-09-16 11:18:24 Added 65 Time and Sales records to Intraday data file for ZFGN after download. | 2016-09-16 11:18:24 HD Request # 85 | Intraday download COMPLETE for ZFGN. Completion time: 1m. Unique request ID: 84 | 2016-09-16 11:18:24 Removed historical data download ID 84 | 2016-09-16 11:18:24 Real-time Intraday chart data file updates started for ZFGN | 2016-09-16 11:18:24 Opened cached Intraday file: C:\SierraChart\Data\ZFGN.scid | 2016-09-16 11:18:24 Intraday chart data file opened for ZFGN | 2016-09-16 11:18:24 HD Request # 86 | Downloading Intraday chart data for CETX to the file CETX.scid. Service: equities.us | 2016-09-16 11:18:24 HD Request # 86 | Download start Date-Time: 2016-09-16 10:48:20.000 | 2016-09-16 11:18:24 HD Request # 86 | Requesting historical Minute data for the current day. | 2016-09-16 11:18:24 HTTPS connection to ameritrade02.streamer.com:443 (99) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:19:08 HTTPS connection to ameritrade02.streamer.com:443 (99) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:19:08 HTTPS connection to ameritrade02.streamer.com:443 (99) | SSL has been shut down. | 2016-09-16 11:19:08 HTTPS connection to ameritrade02.streamer.com:443 (99) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:19:08 HTTPS connection to ameritrade02.streamer.com:443 (99) | Shutdown and closed. | 2016-09-16 11:19:08 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:19:08 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 55. | 2016-09-16 11:19:08 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:19:08 HTTPS connection to ameritrade02.streamer.com:443 (101) | Connected. | 2016-09-16 11:19:08 HTTPS connection to ameritrade02.streamer.com:443 (101) | Starting TLS 1.0 connection. | 2016-09-16 11:19:08 HTTPS connection to ameritrade02.streamer.com:443 (101) | SSL connection established. | 2016-09-16 11:19:09 HD Request # 86 | Error downloading historical Intraday data for CETX. The download timed out. | 2016-09-16 11:19:24 HD Request # 86 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CETX | 2016-09-16 11:19:24 HD Request # 86 | Receiving Intraday data for CETX starting at 2016-09-16 10:58:28 | 2016-09-16 11:19:24 HD Request # 86 | Timestamp of first Intraday data file record written: 2016-09-16 10:58:28 | 2016-09-16 11:19:24 Added 14 Time and Sales records to Intraday data file for CETX after download. | 2016-09-16 11:19:24 HD Request # 86 | Intraday download COMPLETE for CETX. Completion time: 1m. Unique request ID: 85 | 2016-09-16 11:19:24 Removed historical data download ID 85 | 2016-09-16 11:19:24 Real-time Intraday chart data file updates started for CETX | 2016-09-16 11:19:24 Opened cached Intraday file: C:\SierraChart\Data\CETX.scid | 2016-09-16 11:19:24 Intraday chart data file opened for CETX | 2016-09-16 11:19:24 HD Request # 87 | Downloading Intraday chart data for CLD to the file CLD.scid. Service: equities.us | 2016-09-16 11:19:24 HD Request # 87 | Download start Date-Time: 2016-09-16 10:34:54.000 | 2016-09-16 11:19:24 HD Request # 87 | Requesting historical Minute data for the current day. | 2016-09-16 11:19:24 HTTPS connection to ameritrade02.streamer.com:443 (101) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:20:18 HTTPS connection to ameritrade02.streamer.com:443 (101) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:20:18 HTTPS connection to ameritrade02.streamer.com:443 (101) | SSL has been shut down. | 2016-09-16 11:20:18 HTTPS connection to ameritrade02.streamer.com:443 (101) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:20:18 HTTPS connection to ameritrade02.streamer.com:443 (101) | Shutdown and closed. | 2016-09-16 11:20:18 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:20:18 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 57. | 2016-09-16 11:20:18 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:20:18 HTTPS connection to ameritrade02.streamer.com:443 (103) | Connected. | 2016-09-16 11:20:18 HTTPS connection to ameritrade02.streamer.com:443 (103) | Starting TLS 1.0 connection. | 2016-09-16 11:20:18 HTTPS connection to ameritrade02.streamer.com:443 (103) | SSL connection established. | 2016-09-16 11:20:19 HD Request # 87 | Error downloading historical Intraday data for CLD. The download timed out. | 2016-09-16 11:20:24 HD Request # 87 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLD | 2016-09-16 11:20:24 HD Request # 87 | Receiving Intraday data for CLD starting at 2016-09-16 10:50:36 | 2016-09-16 11:20:24 HD Request # 87 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:36 | 2016-09-16 11:20:24 Added 202 Time and Sales records to Intraday data file for CLD after download. | 2016-09-16 11:20:24 HD Request # 87 | Intraday download COMPLETE for CLD. Completion time: 1m. Unique request ID: 86 | 2016-09-16 11:20:24 Removed historical data download ID 86 | 2016-09-16 11:20:24 Real-time Intraday chart data file updates started for CLD | 2016-09-16 11:20:24 Opened cached Intraday file: C:\SierraChart\Data\CLD.scid | 2016-09-16 11:20:24 Intraday chart data file opened for CLD | 2016-09-16 11:20:24 HD Request # 88 | Downloading Intraday chart data for DMPI to the file DMPI.scid. Service: equities.us | 2016-09-16 11:20:24 HD Request # 88 | Download start Date-Time: 2016-09-16 10:14:47.000 | 2016-09-16 11:20:24 HD Request # 88 | Requesting historical Minute data for the current day. | 2016-09-16 11:20:24 HD Request # 88 | Error downloading historical Intraday data for DMPI. The download timed out. | 2016-09-16 11:21:24 HD Request # 88 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for DMPI | 2016-09-16 11:21:24 HD Request # 88 | Receiving Intraday data for DMPI starting at 2016-09-16 10:56:57 | 2016-09-16 11:21:24 HD Request # 88 | Timestamp of first Intraday data file record written: 2016-09-16 10:56:57 | 2016-09-16 11:21:24 Added 9 Time and Sales records to Intraday data file for DMPI after download. | 2016-09-16 11:21:24 HD Request # 88 | Intraday download COMPLETE for DMPI. Completion time: 1m. Unique request ID: 87 | 2016-09-16 11:21:24 Removed historical data download ID 87 | 2016-09-16 11:21:24 Real-time Intraday chart data file updates started for DMPI | 2016-09-16 11:21:24 Opened cached Intraday file: C:\SierraChart\Data\DMPI.scid | 2016-09-16 11:21:24 Intraday chart data file opened for DMPI | 2016-09-16 11:21:24 HD Request # 89 | Downloading Intraday chart data for ERS to the file ERS.scid. Service: equities.us | 2016-09-16 11:21:24 HD Request # 89 | Download start Date-Time: 2016-09-15 15:56:25.000 | 2016-09-16 11:21:24 HD Request # 89 | Requesting 1 day of historical Minute data. | 2016-09-16 11:21:24 HD Request # 89 | Receiving Intraday data for ERS starting at 2016-09-15 11:24:00 | 2016-09-16 11:21:24 HD Request # 89 | Requesting historical Minute data for the current day. | 2016-09-16 11:21:24 HTTPS connection to ameritrade02.streamer.com:443 (103) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:21:28 HTTPS connection to ameritrade02.streamer.com:443 (103) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:21:28 HTTPS connection to ameritrade02.streamer.com:443 (103) | SSL has been shut down. | 2016-09-16 11:21:28 HTTPS connection to ameritrade02.streamer.com:443 (103) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:21:28 HTTPS connection to ameritrade02.streamer.com:443 (103) | Shutdown and closed. | 2016-09-16 11:21:28 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:21:28 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 58. | 2016-09-16 11:21:28 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:21:28 HTTPS connection to ameritrade02.streamer.com:443 (104) | Connected. | 2016-09-16 11:21:28 HTTPS connection to ameritrade02.streamer.com:443 (104) | Starting TLS 1.0 connection. | 2016-09-16 11:21:28 HTTPS connection to ameritrade02.streamer.com:443 (104) | SSL connection established. | 2016-09-16 11:21:29 HD Request # 89 | Error downloading historical Intraday data for ERS. The download timed out. | 2016-09-16 11:22:24 HD Request # 89 | Received 10 records from 2016-09-15 11:24:00 to 2016-09-15 15:56:00 (4.5 hours) and wrote 0 records for ERS | 2016-09-16 11:22:24 HD Request # 89 | Timestamp of first Intraday data file record written: 2016-09-16 11:14:57 | 2016-09-16 11:22:24 Added 6 Time and Sales records to Intraday data file for ERS after download. | 2016-09-16 11:22:24 HD Request # 89 | Intraday download COMPLETE for ERS. Completion time: 1m. Unique request ID: 88 | 2016-09-16 11:22:24 Removed historical data download ID 88 | 2016-09-16 11:22:24 Real-time Intraday chart data file updates started for ERS | 2016-09-16 11:22:24 Opened cached Intraday file: C:\SierraChart\Data\ERS.scid | 2016-09-16 11:22:24 Intraday chart data file opened for ERS | 2016-09-16 11:22:24 HD Request # 90 | Downloading Intraday chart data for HPJ to the file HPJ.scid. Service: equities.us | 2016-09-16 11:22:24 HD Request # 90 | Download start Date-Time: 2016-09-16 10:31:47.000 | 2016-09-16 11:22:24 HD Request # 90 | Requesting historical Minute data for the current day. | 2016-09-16 11:22:24 HTTPS connection to ameritrade02.streamer.com:443 (104) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:22:38 HTTPS connection to ameritrade02.streamer.com:443 (104) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:22:38 HTTPS connection to ameritrade02.streamer.com:443 (104) | SSL has been shut down. | 2016-09-16 11:22:38 HTTPS connection to ameritrade02.streamer.com:443 (104) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:22:38 HTTPS connection to ameritrade02.streamer.com:443 (104) | Shutdown and closed. | 2016-09-16 11:22:38 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:22:38 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 59. | 2016-09-16 11:22:38 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:22:38 HTTPS connection to ameritrade02.streamer.com:443 (106) | Connected. | 2016-09-16 11:22:38 HTTPS connection to ameritrade02.streamer.com:443 (106) | Starting TLS 1.0 connection. | 2016-09-16 11:22:38 HTTPS connection to ameritrade02.streamer.com:443 (106) | SSL connection established. | 2016-09-16 11:22:39 HD Request # 90 | Error downloading historical Intraday data for HPJ. The download timed out. | 2016-09-16 11:23:24 HD Request # 90 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for HPJ | 2016-09-16 11:23:24 HD Request # 90 | Receiving Intraday data for HPJ starting at 2016-09-16 11:04:44 | 2016-09-16 11:23:24 HD Request # 90 | Timestamp of first Intraday data file record written: 2016-09-16 11:04:44 | 2016-09-16 11:23:24 Added 6 Time and Sales records to Intraday data file for HPJ after download. | 2016-09-16 11:23:24 HD Request # 90 | Intraday download COMPLETE for HPJ. Completion time: 1m. Unique request ID: 89 | 2016-09-16 11:23:24 Removed historical data download ID 89 | 2016-09-16 11:23:24 Real-time Intraday chart data file updates started for HPJ | 2016-09-16 11:23:24 Opened cached Intraday file: C:\SierraChart\Data\HPJ.scid | 2016-09-16 11:23:24 Intraday chart data file opened for HPJ | 2016-09-16 11:23:24 HD Request # 91 | Downloading Intraday chart data for KEM to the file KEM.scid. Service: equities.us | 2016-09-16 11:23:24 HD Request # 91 | Download start Date-Time: 2016-09-16 10:48:00.000 | 2016-09-16 11:23:24 HD Request # 91 | Requesting historical Minute data for the current day. | 2016-09-16 11:23:24 HTTPS connection to ameritrade02.streamer.com:443 (106) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:23:48 HTTPS connection to ameritrade02.streamer.com:443 (106) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:23:48 HTTPS connection to ameritrade02.streamer.com:443 (106) | SSL has been shut down. | 2016-09-16 11:23:48 HTTPS connection to ameritrade02.streamer.com:443 (106) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:23:48 HTTPS connection to ameritrade02.streamer.com:443 (106) | Shutdown and closed. | 2016-09-16 11:23:48 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:23:48 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 61. | 2016-09-16 11:23:48 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:23:48 HTTPS connection to ameritrade02.streamer.com:443 (107) | Connected. | 2016-09-16 11:23:49 HTTPS connection to ameritrade02.streamer.com:443 (107) | Starting TLS 1.0 connection. | 2016-09-16 11:23:49 HTTPS connection to ameritrade02.streamer.com:443 (107) | SSL connection established. | 2016-09-16 11:23:49 HD Request # 91 | Error downloading historical Intraday data for KEM. The download timed out. | 2016-09-16 11:24:24 HD Request # 91 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for KEM | 2016-09-16 11:24:24 HD Request # 91 | Receiving Intraday data for KEM starting at 2016-09-16 10:55:54 | 2016-09-16 11:24:24 HD Request # 91 | Timestamp of first Intraday data file record written: 2016-09-16 10:55:54 | 2016-09-16 11:24:24 Added 13 Time and Sales records to Intraday data file for KEM after download. | 2016-09-16 11:24:24 HD Request # 91 | Intraday download COMPLETE for KEM. Completion time: 1m. Unique request ID: 90 | 2016-09-16 11:24:24 Removed historical data download ID 90 | 2016-09-16 11:24:24 Real-time Intraday chart data file updates started for KEM | 2016-09-16 11:24:24 Opened cached Intraday file: C:\SierraChart\Data\KEM.scid | 2016-09-16 11:24:24 Intraday chart data file opened for KEM | 2016-09-16 11:24:24 HD Request # 92 | Downloading Intraday chart data for NEOT to the file NEOT.scid. Service: equities.us | 2016-09-16 11:24:24 HD Request # 92 | Download start Date-Time: 2016-09-16 10:35:03.000 | 2016-09-16 11:24:24 HD Request # 92 | Requesting historical Minute data for the current day. | 2016-09-16 11:24:24 HTTPS connection to ameritrade02.streamer.com:443 (107) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:24:58 HTTPS connection to ameritrade02.streamer.com:443 (107) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:24:58 HTTPS connection to ameritrade02.streamer.com:443 (107) | SSL has been shut down. | 2016-09-16 11:24:58 HTTPS connection to ameritrade02.streamer.com:443 (107) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:24:58 HTTPS connection to ameritrade02.streamer.com:443 (107) | Shutdown and closed. | 2016-09-16 11:24:58 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:24:58 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 62. | 2016-09-16 11:24:58 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:24:58 HTTPS connection to ameritrade02.streamer.com:443 (109) | Connected. | 2016-09-16 11:24:58 HTTPS connection to ameritrade02.streamer.com:443 (109) | Starting TLS 1.0 connection. | 2016-09-16 11:24:58 HTTPS connection to ameritrade02.streamer.com:443 (109) | SSL connection established. | 2016-09-16 11:24:59 HD Request # 92 | Error downloading historical Intraday data for NEOT. The download timed out. | 2016-09-16 11:25:24 HD Request # 92 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NEOT | 2016-09-16 11:25:24 HD Request # 92 | Intraday download COMPLETE for NEOT. Completion time: 1m. Unique request ID: 91 | 2016-09-16 11:25:24 Removed historical data download ID 91 | 2016-09-16 11:25:24 Real-time Intraday chart data file updates started for NEOT | 2016-09-16 11:25:24 Opened cached Intraday file: C:\SierraChart\Data\NEOT.scid | 2016-09-16 11:25:24 Intraday chart data file opened for NEOT | 2016-09-16 11:25:24 HD Request # 93 | Downloading Intraday chart data for ORIG to the file ORIG.scid. Service: equities.us | 2016-09-16 11:25:24 HD Request # 93 | Download start Date-Time: 2016-09-16 10:33:52.000 | 2016-09-16 11:25:24 HD Request # 93 | Requesting historical Minute data for the current day. | 2016-09-16 11:25:24 HTTPS connection to ameritrade02.streamer.com:443 (109) | Error reading data. SSL error: 5. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2016-09-16 11:26:08 * HTTPS connection to ameritrade02.streamer.com:443 (109) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:26:08 HTTPS connection to ameritrade02.streamer.com:443 (109) | SSL has been shut down. | 2016-09-16 11:26:08 HTTPS connection to ameritrade02.streamer.com:443 (109) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:26:08 HTTPS connection to ameritrade02.streamer.com:443 (109) | Shutdown and closed. | 2016-09-16 11:26:08 TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 63. | 2016-09-16 11:26:08 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:26:08 HTTPS connection to ameritrade02.streamer.com:443 (110) | Connected. | 2016-09-16 11:26:09 HTTPS connection to ameritrade02.streamer.com:443 (110) | Starting TLS 1.0 connection. | 2016-09-16 11:26:09 HTTPS connection to ameritrade02.streamer.com:443 (110) | SSL connection established. | 2016-09-16 11:26:09 HD Request # 93 | Error downloading historical Intraday data for ORIG. The download timed out. | 2016-09-16 11:26:24 HD Request # 93 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ORIG | 2016-09-16 11:26:24 HD Request # 93 | Receiving Intraday data for ORIG starting at 2016-09-16 10:50:57 | 2016-09-16 11:26:24 HD Request # 93 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:57 | 2016-09-16 11:26:24 Added 106 Time and Sales records to Intraday data file for ORIG after download. | 2016-09-16 11:26:24 HD Request # 93 | Intraday download COMPLETE for ORIG. Completion time: 1m. Unique request ID: 92 | 2016-09-16 11:26:24 Removed historical data download ID 92 | 2016-09-16 11:26:24 Real-time Intraday chart data file updates started for ORIG | 2016-09-16 11:26:24 Opened cached Intraday file: C:\SierraChart\Data\ORIG.scid | 2016-09-16 11:26:24 Intraday chart data file opened for ORIG | 2016-09-16 11:26:24 HD Request # 94 | Downloading Intraday chart data for TDW to the file TDW.scid. Service: equities.us | 2016-09-16 11:26:24 HD Request # 94 | Download start Date-Time: 2016-09-16 10:35:14.000 | 2016-09-16 11:26:24 HD Request # 94 | Requesting historical Minute data for the current day. | 2016-09-16 11:26:24 HTTPS connection to ameritrade02.streamer.com:443 (110) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:27:18 HTTPS connection to ameritrade02.streamer.com:443 (110) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:27:18 HTTPS connection to ameritrade02.streamer.com:443 (110) | SSL has been shut down. | 2016-09-16 11:27:18 HTTPS connection to ameritrade02.streamer.com:443 (110) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:27:18 HTTPS connection to ameritrade02.streamer.com:443 (110) | Shutdown and closed. | 2016-09-16 11:27:18 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:27:18 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 65. | 2016-09-16 11:27:18 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:27:18 HTTPS connection to ameritrade02.streamer.com:443 (112) | Connected. | 2016-09-16 11:27:19 HTTPS connection to ameritrade02.streamer.com:443 (112) | Starting TLS 1.0 connection. | 2016-09-16 11:27:19 HTTPS connection to ameritrade02.streamer.com:443 (112) | SSL connection established. | 2016-09-16 11:27:19 HD Request # 94 | Error downloading historical Intraday data for TDW. The download timed out. | 2016-09-16 11:27:24 HD Request # 94 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TDW | 2016-09-16 11:27:24 HD Request # 94 | Receiving Intraday data for TDW starting at 2016-09-16 10:50:26 | 2016-09-16 11:27:24 HD Request # 94 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:26 | 2016-09-16 11:27:24 Added 608 Time and Sales records to Intraday data file for TDW after download. | 2016-09-16 11:27:24 HD Request # 94 | Intraday download COMPLETE for TDW. Completion time: 1m. Unique request ID: 93 | 2016-09-16 11:27:24 Removed historical data download ID 93 | 2016-09-16 11:27:24 Real-time Intraday chart data file updates started for TDW | 2016-09-16 11:27:24 Opened cached Intraday file: C:\SierraChart\Data\TDW.scid | 2016-09-16 11:27:24 Intraday chart data file opened for TDW | 2016-09-16 11:27:24 HD Request # 95 | Downloading Intraday chart data for TNXP to the file TNXP.scid. Service: equities.us | 2016-09-16 11:27:24 HD Request # 95 | Download start Date-Time: 2016-09-16 10:35:05.000 | 2016-09-16 11:27:24 HD Request # 95 | Requesting historical Minute data for the current day. | 2016-09-16 11:27:24 HTTPS connection to ameritrade02.streamer.com:443 (112) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:28:21 HTTPS connection to ameritrade02.streamer.com:443 (112) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:28:21 HTTPS connection to ameritrade02.streamer.com:443 (112) | SSL has been shut down. | 2016-09-16 11:28:21 HTTPS connection to ameritrade02.streamer.com:443 (112) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:28:21 HTTPS connection to ameritrade02.streamer.com:443 (112) | Shutdown and closed. | 2016-09-16 11:28:21 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:28:21 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 67. | 2016-09-16 11:28:21 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:28:21 HTTPS connection to ameritrade02.streamer.com:443 (114) | Connected. | 2016-09-16 11:28:21 HTTPS connection to ameritrade02.streamer.com:443 (114) | Starting TLS 1.0 connection. | 2016-09-16 11:28:21 HTTPS connection to ameritrade02.streamer.com:443 (114) | SSL connection established. | 2016-09-16 11:28:21 HD Request # 95 | Error downloading historical Intraday data for TNXP. The download timed out. | 2016-09-16 11:28:24 HD Request # 95 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TNXP | 2016-09-16 11:28:24 HD Request # 95 | Receiving Intraday data for TNXP starting at 2016-09-16 10:50:25 | 2016-09-16 11:28:24 HD Request # 95 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:25 | 2016-09-16 11:28:24 Added 231 Time and Sales records to Intraday data file for TNXP after download. | 2016-09-16 11:28:24 HD Request # 95 | Intraday download COMPLETE for TNXP. Completion time: 1m. Unique request ID: 94 | 2016-09-16 11:28:24 Removed historical data download ID 94 | 2016-09-16 11:28:24 Real-time Intraday chart data file updates started for TNXP | 2016-09-16 11:28:24 Opened cached Intraday file: C:\SierraChart\Data\TNXP.scid | 2016-09-16 11:28:24 Intraday chart data file opened for TNXP | 2016-09-16 11:28:24 HD Request # 96 | Downloading Intraday chart data for VTSI to the file VTSI.scid. Service: equities.us | 2016-09-16 11:28:24 HD Request # 96 | Download start Date-Time: 2016-09-16 10:12:32.000 | 2016-09-16 11:28:24 HD Request # 96 | Requesting historical Minute data for the current day. | 2016-09-16 11:28:24 HD Request # 96 | Error downloading historical Intraday data for VTSI. The download timed out. | 2016-09-16 11:29:24 HD Request # 96 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for VTSI | 2016-09-16 11:29:24 HD Request # 96 | Receiving Intraday data for VTSI starting at 2016-09-16 10:58:47 | 2016-09-16 11:29:24 HD Request # 96 | Timestamp of first Intraday data file record written: 2016-09-16 10:58:47 | 2016-09-16 11:29:24 Added 31 Time and Sales records to Intraday data file for VTSI after download. | 2016-09-16 11:29:24 HD Request # 96 | Intraday download COMPLETE for VTSI. Completion time: 1m. Unique request ID: 95 | 2016-09-16 11:29:24 Removed historical data download ID 95 | 2016-09-16 11:29:24 Real-time Intraday chart data file updates started for VTSI | 2016-09-16 11:29:24 Opened cached Intraday file: C:\SierraChart\Data\VTSI.scid | 2016-09-16 11:29:24 Intraday chart data file opened for VTSI | 2016-09-16 11:29:24 HD Request # 97 | Downloading Intraday chart data for ZX to the file ZX.scid. Service: equities.us | 2016-09-16 11:29:24 HD Request # 97 | Download start Date-Time: 2016-09-16 09:47:15.000 | 2016-09-16 11:29:24 HD Request # 97 | Requesting historical Minute data for the current day. | 2016-09-16 11:29:24 HTTPS connection to ameritrade02.streamer.com:443 (114) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:29:31 HTTPS connection to ameritrade02.streamer.com:443 (114) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:29:31 HTTPS connection to ameritrade02.streamer.com:443 (114) | SSL has been shut down. | 2016-09-16 11:29:31 HTTPS connection to ameritrade02.streamer.com:443 (114) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:29:31 HTTPS connection to ameritrade02.streamer.com:443 (114) | Shutdown and closed. | 2016-09-16 11:29:31 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:29:31 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 68. | 2016-09-16 11:29:31 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:29:31 HTTPS connection to ameritrade02.streamer.com:443 (115) | Connected. | 2016-09-16 11:29:31 HTTPS connection to ameritrade02.streamer.com:443 (115) | Starting TLS 1.0 connection. | 2016-09-16 11:29:31 HTTPS connection to ameritrade02.streamer.com:443 (115) | SSL connection established. | 2016-09-16 11:29:31 HD Request # 97 | Error downloading historical Intraday data for ZX. The download timed out. | 2016-09-16 11:30:24 HD Request # 97 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZX | 2016-09-16 11:30:24 HD Request # 97 | Receiving Intraday data for ZX starting at 2016-09-16 10:50:54 | 2016-09-16 11:30:24 HD Request # 97 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:54 | 2016-09-16 11:30:24 Added 15 Time and Sales records to Intraday data file for ZX after download. | 2016-09-16 11:30:24 HD Request # 97 | Intraday download COMPLETE for ZX. Completion time: 1m. Unique request ID: 96 | 2016-09-16 11:30:24 Removed historical data download ID 96 | 2016-09-16 11:30:24 Real-time Intraday chart data file updates started for ZX | 2016-09-16 11:30:24 Opened cached Intraday file: C:\SierraChart\Data\ZX.scid | 2016-09-16 11:30:24 Intraday chart data file opened for ZX | 2016-09-16 11:30:24 HD Request # 98 | Downloading Intraday chart data for MGT to the file MGT.scid. Service: equities.us | 2016-09-16 11:30:24 HD Request # 98 | Download start Date-Time: 2016-09-16 10:49:40.000 | 2016-09-16 11:30:24 HD Request # 98 | Requesting historical Minute data for the current day. | 2016-09-16 11:30:24 HTTPS connection to ameritrade02.streamer.com:443 (115) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:30:41 HTTPS connection to ameritrade02.streamer.com:443 (115) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:30:41 HTTPS connection to ameritrade02.streamer.com:443 (115) | SSL has been shut down. | 2016-09-16 11:30:41 HTTPS connection to ameritrade02.streamer.com:443 (115) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:30:41 HTTPS connection to ameritrade02.streamer.com:443 (115) | Shutdown and closed. | 2016-09-16 11:30:41 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:30:41 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 70. | 2016-09-16 11:30:41 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:30:41 HTTPS connection to ameritrade02.streamer.com:443 (117) | Connected. | 2016-09-16 11:30:41 HTTPS connection to ameritrade02.streamer.com:443 (117) | Starting TLS 1.0 connection. | 2016-09-16 11:30:41 HTTPS connection to ameritrade02.streamer.com:443 (117) | SSL connection established. | 2016-09-16 11:30:42 HD Request # 98 | Error downloading historical Intraday data for MGT. The download timed out. | 2016-09-16 11:31:24 HD Request # 98 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for MGT | 2016-09-16 11:31:24 HD Request # 98 | Receiving Intraday data for MGT starting at 2016-09-16 10:50:26 | 2016-09-16 11:31:24 HD Request # 98 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:26 | 2016-09-16 11:31:24 Added 305 Time and Sales records to Intraday data file for MGT after download. | 2016-09-16 11:31:24 HD Request # 98 | Intraday download COMPLETE for MGT. Completion time: 1m. Unique request ID: 97 | 2016-09-16 11:31:24 Removed historical data download ID 97 | 2016-09-16 11:31:24 Real-time Intraday chart data file updates started for MGT | 2016-09-16 11:31:24 Opened cached Intraday file: C:\SierraChart\Data\MGT.scid | 2016-09-16 11:31:24 Intraday chart data file opened for MGT | 2016-09-16 11:31:24 HD Request # 99 | Downloading Intraday chart data for FCX to the file FCX.scid. Service: equities.us | 2016-09-16 11:31:24 HD Request # 99 | Download start Date-Time: 2016-09-16 10:35:14.000 | 2016-09-16 11:31:24 HD Request # 99 | Requesting historical Minute data for the current day. | 2016-09-16 11:31:24 HTTPS connection to ameritrade02.streamer.com:443 (117) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:31:51 HTTPS connection to ameritrade02.streamer.com:443 (117) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:31:51 HTTPS connection to ameritrade02.streamer.com:443 (117) | SSL has been shut down. | 2016-09-16 11:31:51 HTTPS connection to ameritrade02.streamer.com:443 (117) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:31:51 HTTPS connection to ameritrade02.streamer.com:443 (117) | Shutdown and closed. | 2016-09-16 11:31:51 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:31:51 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 71. | 2016-09-16 11:31:51 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:31:51 HTTPS connection to ameritrade02.streamer.com:443 (118) | Connected. | 2016-09-16 11:31:51 HTTPS connection to ameritrade02.streamer.com:443 (118) | Starting TLS 1.0 connection. | 2016-09-16 11:31:51 HTTPS connection to ameritrade02.streamer.com:443 (118) | SSL connection established. | 2016-09-16 11:31:52 HD Request # 99 | Error downloading historical Intraday data for FCX. The download timed out. | 2016-09-16 11:32:24 HD Request # 99 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FCX | 2016-09-16 11:32:24 HD Request # 99 | Receiving Intraday data for FCX starting at 2016-09-16 11:03:29 | 2016-09-16 11:32:24 HD Request # 99 | Timestamp of first Intraday data file record written: 2016-09-16 11:03:29 | 2016-09-16 11:32:24 Added 6222 Time and Sales records to Intraday data file for FCX after download. | 2016-09-16 11:32:24 HD Request # 99 | Intraday download COMPLETE for FCX. Completion time: 1m. Unique request ID: 98 | 2016-09-16 11:32:24 Removed historical data download ID 98 | 2016-09-16 11:32:24 Real-time Intraday chart data file updates started for FCX | 2016-09-16 11:32:24 Opened cached Intraday file: C:\SierraChart\Data\FCX.scid | 2016-09-16 11:32:24 Intraday chart data file opened for FCX | 2016-09-16 11:32:24 HD Request # 100 | Downloading Intraday chart data for AMPE to the file AMPE.scid. Service: equities.us | 2016-09-16 11:32:24 HD Request # 100 | Download start Date-Time: 2016-09-16 10:32:47.000 | 2016-09-16 11:32:24 HD Request # 100 | Requesting historical Minute data for the current day. | 2016-09-16 11:32:24 HTTPS connection to ameritrade02.streamer.com:443 (118) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:33:01 HTTPS connection to ameritrade02.streamer.com:443 (118) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:33:01 HTTPS connection to ameritrade02.streamer.com:443 (118) | SSL has been shut down. | 2016-09-16 11:33:01 HTTPS connection to ameritrade02.streamer.com:443 (118) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:33:01 HTTPS connection to ameritrade02.streamer.com:443 (118) | Shutdown and closed. | 2016-09-16 11:33:01 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:33:01 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 72. | 2016-09-16 11:33:01 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:33:01 HTTPS connection to ameritrade02.streamer.com:443 (120) | Connected. | 2016-09-16 11:33:01 HTTPS connection to ameritrade02.streamer.com:443 (120) | Starting TLS 1.0 connection. | 2016-09-16 11:33:01 HTTPS connection to ameritrade02.streamer.com:443 (120) | SSL connection established. | 2016-09-16 11:33:02 HD Request # 100 | Error downloading historical Intraday data for AMPE. The download timed out. | 2016-09-16 11:33:24 HD Request # 100 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AMPE | 2016-09-16 11:33:24 HD Request # 100 | Receiving Intraday data for AMPE starting at 2016-09-16 10:52:13 | 2016-09-16 11:33:24 HD Request # 100 | Timestamp of first Intraday data file record written: 2016-09-16 10:52:13 | 2016-09-16 11:33:24 Added 39 Time and Sales records to Intraday data file for AMPE after download. | 2016-09-16 11:33:24 HD Request # 100 | Intraday download COMPLETE for AMPE. Completion time: 1m. Unique request ID: 99 | 2016-09-16 11:33:24 Removed historical data download ID 99 | 2016-09-16 11:33:24 Real-time Intraday chart data file updates started for AMPE | 2016-09-16 11:33:24 Opened cached Intraday file: C:\SierraChart\Data\AMPE.scid | 2016-09-16 11:33:24 Intraday chart data file opened for AMPE | 2016-09-16 11:33:24 HD Request # 101 | Downloading Intraday chart data for RPRX to the file RPRX.scid. Service: equities.us | 2016-09-16 11:33:24 HD Request # 101 | Download start Date-Time: 2016-09-16 10:34:50.000 | 2016-09-16 11:33:24 HD Request # 101 | Requesting historical Minute data for the current day. | 2016-09-16 11:33:24 HTTPS connection to ameritrade02.streamer.com:443 (120) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:34:11 HTTPS connection to ameritrade02.streamer.com:443 (120) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:34:11 HTTPS connection to ameritrade02.streamer.com:443 (120) | SSL has been shut down. | 2016-09-16 11:34:11 HTTPS connection to ameritrade02.streamer.com:443 (120) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:34:11 HTTPS connection to ameritrade02.streamer.com:443 (120) | Shutdown and closed. | 2016-09-16 11:34:11 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:34:11 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 74. | 2016-09-16 11:34:11 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:34:11 HTTPS connection to ameritrade02.streamer.com:443 (121) | Connected. | 2016-09-16 11:34:11 HTTPS connection to ameritrade02.streamer.com:443 (121) | Starting TLS 1.0 connection. | 2016-09-16 11:34:11 HTTPS connection to ameritrade02.streamer.com:443 (121) | SSL connection established. | 2016-09-16 11:34:11 HD Request # 101 | Error downloading historical Intraday data for RPRX. The download timed out. | 2016-09-16 11:34:24 HD Request # 101 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for RPRX | 2016-09-16 11:34:24 HD Request # 101 | Receiving Intraday data for RPRX starting at 2016-09-16 10:53:22 | 2016-09-16 11:34:24 HD Request # 101 | Timestamp of first Intraday data file record written: 2016-09-16 10:53:22 | 2016-09-16 11:34:24 Added 75 Time and Sales records to Intraday data file for RPRX after download. | 2016-09-16 11:34:24 HD Request # 101 | Intraday download COMPLETE for RPRX. Completion time: 1m. Unique request ID: 100 | 2016-09-16 11:34:24 Removed historical data download ID 100 | 2016-09-16 11:34:24 Real-time Intraday chart data file updates started for RPRX | 2016-09-16 11:34:24 Opened cached Intraday file: C:\SierraChart\Data\RPRX.scid | 2016-09-16 11:34:24 Intraday chart data file opened for RPRX | 2016-09-16 11:34:24 HD Request # 102 | Downloading Intraday chart data for STV to the file STV.scid. Service: equities.us | 2016-09-16 11:34:24 HD Request # 102 | Download start Date-Time: 2016-09-16 10:31:18.000 | 2016-09-16 11:34:24 HD Request # 102 | Requesting historical Minute data for the current day. | 2016-09-16 11:34:24 HTTPS connection to ameritrade02.streamer.com:443 (121) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:35:21 HTTPS connection to ameritrade02.streamer.com:443 (121) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:35:21 HTTPS connection to ameritrade02.streamer.com:443 (121) | SSL has been shut down. | 2016-09-16 11:35:21 HTTPS connection to ameritrade02.streamer.com:443 (121) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:35:21 HTTPS connection to ameritrade02.streamer.com:443 (121) | Shutdown and closed. | 2016-09-16 11:35:21 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:35:21 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 75. | 2016-09-16 11:35:21 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:35:21 HTTPS connection to ameritrade02.streamer.com:443 (123) | Connected. | 2016-09-16 11:35:21 HTTPS connection to ameritrade02.streamer.com:443 (123) | Starting TLS 1.0 connection. | 2016-09-16 11:35:21 HTTPS connection to ameritrade02.streamer.com:443 (123) | SSL connection established. | 2016-09-16 11:35:21 HD Request # 102 | Error downloading historical Intraday data for STV. The download timed out. | 2016-09-16 11:35:24 HD Request # 102 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for STV | 2016-09-16 11:35:24 HD Request # 102 | Receiving Intraday data for STV starting at 2016-09-16 11:19:28 | 2016-09-16 11:35:24 HD Request # 102 | Timestamp of first Intraday data file record written: 2016-09-16 11:19:28 | 2016-09-16 11:35:24 Added 17 Time and Sales records to Intraday data file for STV after download. | 2016-09-16 11:35:24 HD Request # 102 | Intraday download COMPLETE for STV. Completion time: 1m. Unique request ID: 101 | 2016-09-16 11:35:24 Removed historical data download ID 101 | 2016-09-16 11:35:24 Real-time Intraday chart data file updates started for STV | 2016-09-16 11:35:24 Opened cached Intraday file: C:\SierraChart\Data\STV.scid | 2016-09-16 11:35:24 Intraday chart data file opened for STV | 2016-09-16 11:35:24 HD Request # 103 | Downloading Intraday chart data for THLD to the file THLD.scid. Service: equities.us | 2016-09-16 11:35:24 HD Request # 103 | Download start Date-Time: 2016-09-16 10:30:41.000 | 2016-09-16 11:35:24 HD Request # 103 | Requesting historical Minute data for the current day. | 2016-09-16 11:35:24 HD Request # 103 | Error downloading historical Intraday data for THLD. The download timed out. | 2016-09-16 11:36:24 HD Request # 103 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for THLD | 2016-09-16 11:36:24 HD Request # 103 | Receiving Intraday data for THLD starting at 2016-09-16 10:50:42 | 2016-09-16 11:36:24 HD Request # 103 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:42 | 2016-09-16 11:36:24 Added 158 Time and Sales records to Intraday data file for THLD after download. | 2016-09-16 11:36:24 HD Request # 103 | Intraday download COMPLETE for THLD. Completion time: 1m. Unique request ID: 102 | 2016-09-16 11:36:24 Removed historical data download ID 102 | 2016-09-16 11:36:24 Real-time Intraday chart data file updates started for THLD | 2016-09-16 11:36:24 Opened cached Intraday file: C:\SierraChart\Data\THLD.scid | 2016-09-16 11:36:24 Intraday chart data file opened for THLD | 2016-09-16 11:36:24 HD Request # 104 | Downloading Intraday chart data for VRX to the file VRX.scid. Service: equities.us | 2016-09-16 11:36:24 HD Request # 104 | Download start Date-Time: 2016-09-16 10:35:14.000 | 2016-09-16 11:36:24 HD Request # 104 | Requesting historical Minute data for the current day. | 2016-09-16 11:36:24 HTTPS connection to ameritrade02.streamer.com:443 (123) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:36:31 HTTPS connection to ameritrade02.streamer.com:443 (123) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:36:31 HTTPS connection to ameritrade02.streamer.com:443 (123) | SSL has been shut down. | 2016-09-16 11:36:31 HTTPS connection to ameritrade02.streamer.com:443 (123) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:36:31 HTTPS connection to ameritrade02.streamer.com:443 (123) | Shutdown and closed. | 2016-09-16 11:36:31 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:36:31 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 76. | 2016-09-16 11:36:31 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:36:31 HTTPS connection to ameritrade02.streamer.com:443 (125) | Connected. | 2016-09-16 11:36:31 HTTPS connection to ameritrade02.streamer.com:443 (125) | Starting TLS 1.0 connection. | 2016-09-16 11:36:31 HTTPS connection to ameritrade02.streamer.com:443 (125) | SSL connection established. | 2016-09-16 11:36:31 HD Request # 104 | Error downloading historical Intraday data for VRX. The download timed out. | 2016-09-16 11:37:24 HD Request # 104 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for VRX | 2016-09-16 11:37:24 HD Request # 104 | Receiving Intraday data for VRX starting at 2016-09-16 10:50:35 | 2016-09-16 11:37:24 HD Request # 104 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:35 | 2016-09-16 11:37:24 Added 5156 Time and Sales records to Intraday data file for VRX after download. | 2016-09-16 11:37:24 HD Request # 104 | Intraday download COMPLETE for VRX. Completion time: 1m. Unique request ID: 103 | 2016-09-16 11:37:24 Removed historical data download ID 103 | 2016-09-16 11:37:24 Real-time Intraday chart data file updates started for VRX | 2016-09-16 11:37:24 Opened cached Intraday file: C:\SierraChart\Data\VRX.scid | 2016-09-16 11:37:24 Intraday chart data file opened for VRX | 2016-09-16 11:37:24 HD Request # 105 | Downloading Intraday chart data for VUZI to the file VUZI.scid. Service: equities.us | 2016-09-16 11:37:24 HD Request # 105 | Download start Date-Time: 2016-09-16 10:33:54.000 | 2016-09-16 11:37:24 HD Request # 105 | Requesting historical Minute data for the current day. | 2016-09-16 11:37:24 HTTPS connection to ameritrade02.streamer.com:443 (125) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:37:41 HTTPS connection to ameritrade02.streamer.com:443 (125) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:37:41 HTTPS connection to ameritrade02.streamer.com:443 (125) | SSL has been shut down. | 2016-09-16 11:37:41 HTTPS connection to ameritrade02.streamer.com:443 (125) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:37:41 HTTPS connection to ameritrade02.streamer.com:443 (125) | Shutdown and closed. | 2016-09-16 11:37:41 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:37:41 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 78. | 2016-09-16 11:37:41 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:37:41 HTTPS connection to ameritrade02.streamer.com:443 (126) | Connected. | 2016-09-16 11:37:41 HTTPS connection to ameritrade02.streamer.com:443 (126) | Starting TLS 1.0 connection. | 2016-09-16 11:37:41 HTTPS connection to ameritrade02.streamer.com:443 (126) | SSL connection established. | 2016-09-16 11:37:42 HD Request # 105 | Error downloading historical Intraday data for VUZI. The download timed out. | 2016-09-16 11:38:24 HD Request # 105 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for VUZI | 2016-09-16 11:38:24 HD Request # 105 | Receiving Intraday data for VUZI starting at 2016-09-16 10:57:27 | 2016-09-16 11:38:24 HD Request # 105 | Timestamp of first Intraday data file record written: 2016-09-16 10:57:27 | 2016-09-16 11:38:24 Added 30 Time and Sales records to Intraday data file for VUZI after download. | 2016-09-16 11:38:24 HD Request # 105 | Intraday download COMPLETE for VUZI. Completion time: 1m. Unique request ID: 104 | 2016-09-16 11:38:24 Removed historical data download ID 104 | 2016-09-16 11:38:24 Real-time Intraday chart data file updates started for VUZI | 2016-09-16 11:38:24 Opened cached Intraday file: C:\SierraChart\Data\VUZI.scid | 2016-09-16 11:38:24 Intraday chart data file opened for VUZI | 2016-09-16 11:38:24 HD Request # 106 | Downloading Intraday chart data for GRO to the file GRO.scid. Service: equities.us | 2016-09-16 11:38:24 HD Request # 106 | Download start Date-Time: 2016-09-15 16:02:00.000 | 2016-09-16 11:38:24 HD Request # 106 | Requesting 1 day of historical Minute data. | 2016-09-16 11:38:24 HD Request # 106 | Receiving Intraday data for GRO starting at 2016-09-15 09:30:00 | 2016-09-16 11:38:25 HD Request # 106 | Timestamp of first Intraday data file record written: 2016-09-15 16:02:00 | 2016-09-16 11:38:25 HD Request # 106 | Requesting historical Minute data for the current day. | 2016-09-16 11:38:25 HTTPS connection to ameritrade02.streamer.com:443 (126) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:38:51 HTTPS connection to ameritrade02.streamer.com:443 (126) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:38:51 HTTPS connection to ameritrade02.streamer.com:443 (126) | SSL has been shut down. | 2016-09-16 11:38:51 HTTPS connection to ameritrade02.streamer.com:443 (126) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:38:51 HTTPS connection to ameritrade02.streamer.com:443 (126) | Shutdown and closed. | 2016-09-16 11:38:51 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:38:51 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 79. | 2016-09-16 11:38:51 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:38:51 HTTPS connection to ameritrade02.streamer.com:443 (128) | Connected. | 2016-09-16 11:38:51 HTTPS connection to ameritrade02.streamer.com:443 (128) | Starting TLS 1.0 connection. | 2016-09-16 11:38:51 HTTPS connection to ameritrade02.streamer.com:443 (128) | SSL connection established. | 2016-09-16 11:38:52 HD Request # 106 | Error downloading historical Intraday data for GRO. The download timed out. | 2016-09-16 11:39:25 HD Request # 106 | Received 11 records from 2016-09-15 09:30:00 to 2016-09-15 16:02:00 (6.5 hours) and wrote 1 record for GRO | 2016-09-16 11:39:25 Added 10 Time and Sales records to Intraday data file for GRO after download. | 2016-09-16 11:39:25 HD Request # 106 | Intraday download COMPLETE for GRO. Completion time: 1m. Unique request ID: 105 | 2016-09-16 11:39:25 Removed historical data download ID 105 | 2016-09-16 11:39:25 Real-time Intraday chart data file updates started for GRO | 2016-09-16 11:39:25 Opened cached Intraday file: C:\SierraChart\Data\GRO.scid | 2016-09-16 11:39:25 Intraday chart data file opened for GRO | 2016-09-16 11:39:25 HD Request # 107 | Downloading Intraday chart data for RTRX to the file RTRX.scid. Service: equities.us | 2016-09-16 11:39:25 HD Request # 107 | Download start Date-Time: 2016-09-16 10:34:25.000 | 2016-09-16 11:39:25 HD Request # 107 | Requesting historical Minute data for the current day. | 2016-09-16 11:39:25 HTTPS connection to ameritrade02.streamer.com:443 (128) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:40:01 HTTPS connection to ameritrade02.streamer.com:443 (128) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:40:01 HTTPS connection to ameritrade02.streamer.com:443 (128) | SSL has been shut down. | 2016-09-16 11:40:01 HTTPS connection to ameritrade02.streamer.com:443 (128) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:40:01 HTTPS connection to ameritrade02.streamer.com:443 (128) | Shutdown and closed. | 2016-09-16 11:40:01 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:40:01 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 80. | 2016-09-16 11:40:01 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:40:01 HTTPS connection to ameritrade02.streamer.com:443 (129) | Connected. | 2016-09-16 11:40:01 HTTPS connection to ameritrade02.streamer.com:443 (129) | Starting TLS 1.0 connection. | 2016-09-16 11:40:01 HTTPS connection to ameritrade02.streamer.com:443 (129) | SSL connection established. | 2016-09-16 11:40:02 HD Request # 107 | Error downloading historical Intraday data for RTRX. The download timed out. | 2016-09-16 11:40:25 HD Request # 107 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for RTRX | 2016-09-16 11:40:25 HD Request # 107 | Receiving Intraday data for RTRX starting at 2016-09-16 10:50:33 | 2016-09-16 11:40:25 HD Request # 107 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:33 | 2016-09-16 11:40:25 Added 473 Time and Sales records to Intraday data file for RTRX after download. | 2016-09-16 11:40:25 HD Request # 107 | Intraday download COMPLETE for RTRX. Completion time: 1m. Unique request ID: 106 | 2016-09-16 11:40:25 Removed historical data download ID 106 | 2016-09-16 11:40:25 Real-time Intraday chart data file updates started for RTRX | 2016-09-16 11:40:25 Opened cached Intraday file: C:\SierraChart\Data\RTRX.scid | 2016-09-16 11:40:25 Intraday chart data file opened for RTRX | 2016-09-16 11:40:25 HD Request # 108 | Downloading Intraday chart data for ADVM to the file ADVM.scid. Service: equities.us | 2016-09-16 11:40:25 HD Request # 108 | Download start Date-Time: 2016-09-16 10:34:08.000 | 2016-09-16 11:40:25 HD Request # 108 | Requesting historical Minute data for the current day. | 2016-09-16 11:40:25 HTTPS connection to ameritrade02.streamer.com:443 (129) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:41:11 HTTPS connection to ameritrade02.streamer.com:443 (129) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:41:11 HTTPS connection to ameritrade02.streamer.com:443 (129) | SSL has been shut down. | 2016-09-16 11:41:11 HTTPS connection to ameritrade02.streamer.com:443 (129) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:41:11 HTTPS connection to ameritrade02.streamer.com:443 (129) | Shutdown and closed. | 2016-09-16 11:41:11 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:41:11 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 82. | 2016-09-16 11:41:11 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:41:11 HTTPS connection to ameritrade02.streamer.com:443 (131) | Connected. | 2016-09-16 11:41:11 HTTPS connection to ameritrade02.streamer.com:443 (131) | Starting TLS 1.0 connection. | 2016-09-16 11:41:11 HTTPS connection to ameritrade02.streamer.com:443 (131) | SSL connection established. | 2016-09-16 11:41:12 HD Request # 108 | Error downloading historical Intraday data for ADVM. The download timed out. | 2016-09-16 11:41:25 HD Request # 108 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ADVM | 2016-09-16 11:41:25 HD Request # 108 | Receiving Intraday data for ADVM starting at 2016-09-16 10:51:21 | 2016-09-16 11:41:25 HD Request # 108 | Timestamp of first Intraday data file record written: 2016-09-16 10:51:21 | 2016-09-16 11:41:25 Added 124 Time and Sales records to Intraday data file for ADVM after download. | 2016-09-16 11:41:25 HD Request # 108 | Intraday download COMPLETE for ADVM. Completion time: 1m. Unique request ID: 107 | 2016-09-16 11:41:25 Removed historical data download ID 107 | 2016-09-16 11:41:25 Real-time Intraday chart data file updates started for ADVM | 2016-09-16 11:41:25 Opened cached Intraday file: C:\SierraChart\Data\ADVM.scid | 2016-09-16 11:41:25 Intraday chart data file opened for ADVM | 2016-09-16 11:41:25 HD Request # 109 | Downloading Intraday chart data for CHMA to the file CHMA.scid. Service: equities.us | 2016-09-16 11:41:25 HD Request # 109 | Download start Date-Time: 2016-09-16 10:32:35.000 | 2016-09-16 11:41:25 HD Request # 109 | Requesting historical Minute data for the current day. | 2016-09-16 11:41:25 HTTPS connection to ameritrade02.streamer.com:443 (131) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:42:21 HTTPS connection to ameritrade02.streamer.com:443 (131) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:42:21 HTTPS connection to ameritrade02.streamer.com:443 (131) | SSL has been shut down. | 2016-09-16 11:42:21 HTTPS connection to ameritrade02.streamer.com:443 (131) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:42:21 HTTPS connection to ameritrade02.streamer.com:443 (131) | Shutdown and closed. | 2016-09-16 11:42:21 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:42:21 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 83. | 2016-09-16 11:42:21 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:42:21 HTTPS connection to ameritrade02.streamer.com:443 (133) | Connected. | 2016-09-16 11:42:21 HTTPS connection to ameritrade02.streamer.com:443 (133) | Starting TLS 1.0 connection. | 2016-09-16 11:42:21 HTTPS connection to ameritrade02.streamer.com:443 (133) | SSL connection established. | 2016-09-16 11:42:22 HD Request # 109 | Error downloading historical Intraday data for CHMA. The download timed out. | 2016-09-16 11:42:25 HD Request # 109 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CHMA | 2016-09-16 11:42:25 HD Request # 109 | Receiving Intraday data for CHMA starting at 2016-09-16 10:56:00 | 2016-09-16 11:42:25 HD Request # 109 | Timestamp of first Intraday data file record written: 2016-09-16 10:56:00 | 2016-09-16 11:42:25 Added 43 Time and Sales records to Intraday data file for CHMA after download. | 2016-09-16 11:42:25 HD Request # 109 | Intraday download COMPLETE for CHMA. Completion time: 1m. Unique request ID: 108 | 2016-09-16 11:42:25 Removed historical data download ID 108 | 2016-09-16 11:42:25 Real-time Intraday chart data file updates started for CHMA | 2016-09-16 11:42:25 Opened cached Intraday file: C:\SierraChart\Data\CHMA.scid | 2016-09-16 11:42:25 Intraday chart data file opened for CHMA | 2016-09-16 11:42:25 HD Request # 110 | Downloading Intraday chart data for CLF to the file CLF.scid. Service: equities.us | 2016-09-16 11:42:25 HD Request # 110 | Download start Date-Time: 2016-09-16 10:35:13.000 | 2016-09-16 11:42:25 HD Request # 110 | Requesting historical Minute data for the current day. | 2016-09-16 11:42:25 HD Request # 110 | Error downloading historical Intraday data for CLF. The download timed out. | 2016-09-16 11:43:25 HD Request # 110 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLF | 2016-09-16 11:43:25 HD Request # 110 | Receiving Intraday data for CLF starting at 2016-09-16 10:50:25 | 2016-09-16 11:43:25 HD Request # 110 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:25 | 2016-09-16 11:43:25 Added 2487 Time and Sales records to Intraday data file for CLF after download. | 2016-09-16 11:43:25 HD Request # 110 | Intraday download COMPLETE for CLF. Completion time: 1m. Unique request ID: 109 | 2016-09-16 11:43:25 Removed historical data download ID 109 | 2016-09-16 11:43:25 Real-time Intraday chart data file updates started for CLF | 2016-09-16 11:43:25 Opened cached Intraday file: C:\SierraChart\Data\CLF.scid | 2016-09-16 11:43:25 Intraday chart data file opened for CLF | 2016-09-16 11:43:25 HD Request # 111 | Downloading Intraday chart data for EVOK to the file EVOK.scid. Service: equities.us | 2016-09-16 11:43:25 HD Request # 111 | Download start Date-Time: 2016-09-16 10:33:03.000 | 2016-09-16 11:43:25 HD Request # 111 | Requesting historical Minute data for the current day. | 2016-09-16 11:43:25 HTTPS connection to ameritrade02.streamer.com:443 (133) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:43:31 HTTPS connection to ameritrade02.streamer.com:443 (133) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:43:31 HTTPS connection to ameritrade02.streamer.com:443 (133) | SSL has been shut down. | 2016-09-16 11:43:31 HTTPS connection to ameritrade02.streamer.com:443 (133) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:43:31 HTTPS connection to ameritrade02.streamer.com:443 (133) | Shutdown and closed. | 2016-09-16 11:43:31 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:43:31 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 84. | 2016-09-16 11:43:31 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:43:31 HTTPS connection to ameritrade02.streamer.com:443 (134) | Connected. | 2016-09-16 11:43:31 HTTPS connection to ameritrade02.streamer.com:443 (134) | Starting TLS 1.0 connection. | 2016-09-16 11:43:31 HTTPS connection to ameritrade02.streamer.com:443 (134) | SSL connection established. | 2016-09-16 11:43:32 HD Request # 111 | Error downloading historical Intraday data for EVOK. The download timed out. | 2016-09-16 11:44:25 HD Request # 111 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EVOK | 2016-09-16 11:44:25 HD Request # 111 | Receiving Intraday data for EVOK starting at 2016-09-16 10:51:19 | 2016-09-16 11:44:25 HD Request # 111 | Timestamp of first Intraday data file record written: 2016-09-16 10:51:19 | 2016-09-16 11:44:25 Added 75 Time and Sales records to Intraday data file for EVOK after download. | 2016-09-16 11:44:25 HD Request # 111 | Intraday download COMPLETE for EVOK. Completion time: 1m. Unique request ID: 110 | 2016-09-16 11:44:25 Removed historical data download ID 110 | 2016-09-16 11:44:25 Real-time Intraday chart data file updates started for EVOK | 2016-09-16 11:44:25 Opened cached Intraday file: C:\SierraChart\Data\EVOK.scid | 2016-09-16 11:44:25 Intraday chart data file opened for EVOK | 2016-09-16 11:44:25 HD Request # 112 | Downloading Intraday chart data for FNMA to the file FNMA.scid. Service: equities.us | 2016-09-16 11:44:25 HD Request # 112 | Download start Date-Time: 2016-09-16 10:35:18.000 | 2016-09-16 11:44:25 HD Request # 112 | Requesting historical Minute data for the current day. | 2016-09-16 11:44:25 HTTPS connection to ameritrade02.streamer.com:443 (134) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:44:41 HTTPS connection to ameritrade02.streamer.com:443 (134) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:44:41 HTTPS connection to ameritrade02.streamer.com:443 (134) | SSL has been shut down. | 2016-09-16 11:44:41 HTTPS connection to ameritrade02.streamer.com:443 (134) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:44:41 HTTPS connection to ameritrade02.streamer.com:443 (134) | Shutdown and closed. | 2016-09-16 11:44:41 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:44:41 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 86. | 2016-09-16 11:44:41 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:44:41 HTTPS connection to ameritrade02.streamer.com:443 (136) | Connected. | 2016-09-16 11:44:41 HTTPS connection to ameritrade02.streamer.com:443 (136) | Starting TLS 1.0 connection. | 2016-09-16 11:44:41 HTTPS connection to ameritrade02.streamer.com:443 (136) | SSL connection established. | 2016-09-16 11:44:42 HD Request # 112 | Error downloading historical Intraday data for FNMA. The download timed out. | 2016-09-16 11:45:25 HD Request # 112 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FNMA | 2016-09-16 11:45:25 HD Request # 112 | Receiving Intraday data for FNMA starting at 2016-09-16 10:52:37 | 2016-09-16 11:45:25 HD Request # 112 | Timestamp of first Intraday data file record written: 2016-09-16 10:52:37 | 2016-09-16 11:45:25 Added 173 Time and Sales records to Intraday data file for FNMA after download. | 2016-09-16 11:45:25 HD Request # 112 | Intraday download COMPLETE for FNMA. Completion time: 1m. Unique request ID: 111 | 2016-09-16 11:45:25 Removed historical data download ID 111 | 2016-09-16 11:45:25 Real-time Intraday chart data file updates started for FNMA | 2016-09-16 11:45:25 Opened cached Intraday file: C:\SierraChart\Data\FNMA.scid | 2016-09-16 11:45:25 Intraday chart data file opened for FNMA | 2016-09-16 11:45:25 HD Request # 113 | Downloading Intraday chart data for IMGN to the file IMGN.scid. Service: equities.us | 2016-09-16 11:45:25 HD Request # 113 | Download start Date-Time: 2016-09-16 10:35:12.000 | 2016-09-16 11:45:25 HD Request # 113 | Requesting historical Minute data for the current day. | 2016-09-16 11:45:25 HTTPS connection to ameritrade02.streamer.com:443 (136) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:45:51 HTTPS connection to ameritrade02.streamer.com:443 (136) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:45:51 HTTPS connection to ameritrade02.streamer.com:443 (136) | SSL has been shut down. | 2016-09-16 11:45:51 HTTPS connection to ameritrade02.streamer.com:443 (136) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:45:51 HTTPS connection to ameritrade02.streamer.com:443 (136) | Shutdown and closed. | 2016-09-16 11:45:51 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:45:51 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 87. | 2016-09-16 11:45:51 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:45:51 HTTPS connection to ameritrade02.streamer.com:443 (137) | Connected. | 2016-09-16 11:45:51 HTTPS connection to ameritrade02.streamer.com:443 (137) | Starting TLS 1.0 connection. | 2016-09-16 11:45:51 HTTPS connection to ameritrade02.streamer.com:443 (137) | SSL connection established. | 2016-09-16 11:45:52 HD Request # 113 | Error downloading historical Intraday data for IMGN. The download timed out. | 2016-09-16 11:46:25 HD Request # 113 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for IMGN | 2016-09-16 11:46:25 HD Request # 113 | Receiving Intraday data for IMGN starting at 2016-09-16 10:50:36 | 2016-09-16 11:46:25 HD Request # 113 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:36 | 2016-09-16 11:46:25 Added 647 Time and Sales records to Intraday data file for IMGN after download. | 2016-09-16 11:46:25 HD Request # 113 | Intraday download COMPLETE for IMGN. Completion time: 1m. Unique request ID: 112 | 2016-09-16 11:46:25 Removed historical data download ID 112 | 2016-09-16 11:46:25 Real-time Intraday chart data file updates started for IMGN | 2016-09-16 11:46:25 Opened cached Intraday file: C:\SierraChart\Data\IMGN.scid | 2016-09-16 11:46:25 Intraday chart data file opened for IMGN | 2016-09-16 11:46:25 HD Request # 114 | Downloading Intraday chart data for NRP to the file NRP.scid. Service: equities.us | 2016-09-16 11:46:25 HD Request # 114 | Download start Date-Time: 2016-09-16 10:48:10.000 | 2016-09-16 11:46:25 HD Request # 114 | Requesting historical Minute data for the current day. | 2016-09-16 11:46:25 HTTPS connection to ameritrade02.streamer.com:443 (137) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:47:01 HTTPS connection to ameritrade02.streamer.com:443 (137) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:47:01 HTTPS connection to ameritrade02.streamer.com:443 (137) | SSL has been shut down. | 2016-09-16 11:47:01 HTTPS connection to ameritrade02.streamer.com:443 (137) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:47:01 HTTPS connection to ameritrade02.streamer.com:443 (137) | Shutdown and closed. | 2016-09-16 11:47:01 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:47:01 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 88. | 2016-09-16 11:47:01 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:47:01 HTTPS connection to ameritrade02.streamer.com:443 (139) | Connected. | 2016-09-16 11:47:01 HTTPS connection to ameritrade02.streamer.com:443 (139) | Starting TLS 1.0 connection. | 2016-09-16 11:47:01 HTTPS connection to ameritrade02.streamer.com:443 (139) | SSL connection established. | 2016-09-16 11:47:02 HD Request # 114 | Error downloading historical Intraday data for NRP. The download timed out. | 2016-09-16 11:47:25 HD Request # 114 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NRP | 2016-09-16 11:47:25 HD Request # 114 | Receiving Intraday data for NRP starting at 2016-09-16 10:52:03 | 2016-09-16 11:47:25 HD Request # 114 | Timestamp of first Intraday data file record written: 2016-09-16 10:52:03 | 2016-09-16 11:47:25 Added 70 Time and Sales records to Intraday data file for NRP after download. | 2016-09-16 11:47:25 HD Request # 114 | Intraday download COMPLETE for NRP. Completion time: 1m. Unique request ID: 113 | 2016-09-16 11:47:25 Removed historical data download ID 113 | 2016-09-16 11:47:25 Real-time Intraday chart data file updates started for NRP | 2016-09-16 11:47:25 Opened cached Intraday file: C:\SierraChart\Data\NRP.scid | 2016-09-16 11:47:25 Intraday chart data file opened for NRP | 2016-09-16 11:47:25 HD Request # 115 | Downloading Intraday chart data for TRIL to the file TRIL.scid. Service: equities.us | 2016-09-16 11:47:25 HD Request # 115 | Download start Date-Time: 2016-09-16 10:33:31.000 | 2016-09-16 11:47:25 HD Request # 115 | Requesting historical Minute data for the current day. | 2016-09-16 11:47:25 HTTPS connection to ameritrade02.streamer.com:443 (139) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:48:11 HTTPS connection to ameritrade02.streamer.com:443 (139) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:48:11 HTTPS connection to ameritrade02.streamer.com:443 (139) | SSL has been shut down. | 2016-09-16 11:48:11 HTTPS connection to ameritrade02.streamer.com:443 (139) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:48:11 HTTPS connection to ameritrade02.streamer.com:443 (139) | Shutdown and closed. | 2016-09-16 11:48:11 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:48:11 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 91. | 2016-09-16 11:48:11 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:48:11 HTTPS connection to ameritrade02.streamer.com:443 (140) | Connected. | 2016-09-16 11:48:11 HTTPS connection to ameritrade02.streamer.com:443 (140) | Starting TLS 1.0 connection. | 2016-09-16 11:48:11 HTTPS connection to ameritrade02.streamer.com:443 (140) | SSL connection established. | 2016-09-16 11:48:12 HD Request # 115 | Error downloading historical Intraday data for TRIL. The download timed out. | 2016-09-16 11:48:25 HD Request # 115 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TRIL | 2016-09-16 11:48:25 HD Request # 115 | Receiving Intraday data for TRIL starting at 2016-09-16 10:51:48 | 2016-09-16 11:48:25 HD Request # 115 | Timestamp of first Intraday data file record written: 2016-09-16 10:51:48 | 2016-09-16 11:48:25 Added 50 Time and Sales records to Intraday data file for TRIL after download. | 2016-09-16 11:48:25 HD Request # 115 | Intraday download COMPLETE for TRIL. Completion time: 1m. Unique request ID: 114 | 2016-09-16 11:48:25 Removed historical data download ID 114 | 2016-09-16 11:48:25 Real-time Intraday chart data file updates started for TRIL | 2016-09-16 11:48:25 Opened cached Intraday file: C:\SierraChart\Data\TRIL.scid | 2016-09-16 11:48:25 Intraday chart data file opened for TRIL | 2016-09-16 11:48:25 HD Request # 116 | Downloading Intraday chart data for VSLR to the file VSLR.scid. Service: equities.us | 2016-09-16 11:48:25 HD Request # 116 | Download start Date-Time: 2016-09-16 10:35:00.000 | 2016-09-16 11:48:25 HD Request # 116 | Requesting historical Minute data for the current day. | 2016-09-16 11:48:25 HTTPS connection to ameritrade02.streamer.com:443 (140) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:49:18 HTTPS connection to ameritrade02.streamer.com:443 (140) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:49:18 HTTPS connection to ameritrade02.streamer.com:443 (140) | SSL has been shut down. | 2016-09-16 11:49:18 HTTPS connection to ameritrade02.streamer.com:443 (140) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:49:18 HTTPS connection to ameritrade02.streamer.com:443 (140) | Shutdown and closed. | 2016-09-16 11:49:18 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:49:18 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 92. | 2016-09-16 11:49:18 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:49:18 HTTPS connection to ameritrade02.streamer.com:443 (142) | Connected. | 2016-09-16 11:49:19 HTTPS connection to ameritrade02.streamer.com:443 (142) | Starting TLS 1.0 connection. | 2016-09-16 11:49:19 HTTPS connection to ameritrade02.streamer.com:443 (142) | SSL connection established. | 2016-09-16 11:49:19 HD Request # 116 | Error downloading historical Intraday data for VSLR. The download timed out. | 2016-09-16 11:49:25 HD Request # 116 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for VSLR | 2016-09-16 11:49:25 HD Request # 116 | Receiving Intraday data for VSLR starting at 2016-09-16 10:50:25 | 2016-09-16 11:49:25 HD Request # 116 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:25 | 2016-09-16 11:49:25 Added 198 Time and Sales records to Intraday data file for VSLR after download. | 2016-09-16 11:49:25 HD Request # 116 | Intraday download COMPLETE for VSLR. Completion time: 1m. Unique request ID: 115 | 2016-09-16 11:49:25 Removed historical data download ID 115 | 2016-09-16 11:49:25 Real-time Intraday chart data file updates started for VSLR | 2016-09-16 11:49:25 Opened cached Intraday file: C:\SierraChart\Data\VSLR.scid | 2016-09-16 11:49:25 Intraday chart data file opened for VSLR | 2016-09-16 11:49:25 HD Request # 117 | Downloading Intraday chart data for BXC to the file BXC.scid. Service: equities.us | 2016-09-16 11:49:25 HD Request # 117 | Download start Date-Time: 2016-09-16 10:06:40.000 | 2016-09-16 11:49:25 HD Request # 117 | Requesting historical Minute data for the current day. | 2016-09-16 11:49:25 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-09-16 11:50:20 HTTP connection to www.sierrachart.com:80 (144) | Connected. | 2016-09-16 11:50:20 Received Date-time from server. Delay adjusted UTC Date-time: 2016-09-16 15:50:07.680. Round-trip delay: 00:00:00.185 | 2016-09-16 11:50:20 Error setting the system Date-time. Windows error code 1314: A required privilege is not held by the client. | 2016-09-16 11:50:20 * HD Request # 117 | Error downloading historical Intraday data for BXC. The download timed out. | 2016-09-16 11:50:25 HD Request # 117 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for BXC | 2016-09-16 11:50:25 HD Request # 117 | Receiving Intraday data for BXC starting at 2016-09-16 11:06:01 | 2016-09-16 11:50:25 HD Request # 117 | Timestamp of first Intraday data file record written: 2016-09-16 11:06:01 | 2016-09-16 11:50:25 Added 4 Time and Sales records to Intraday data file for BXC after download. | 2016-09-16 11:50:25 HD Request # 117 | Intraday download COMPLETE for BXC. Completion time: 1m. Unique request ID: 116 | 2016-09-16 11:50:25 Removed historical data download ID 116 | 2016-09-16 11:50:25 Real-time Intraday chart data file updates started for BXC | 2016-09-16 11:50:25 Opened cached Intraday file: C:\SierraChart\Data\BXC.scid | 2016-09-16 11:50:25 Intraday chart data file opened for BXC | 2016-09-16 11:50:25 HD Request # 118 | Downloading Intraday chart data for NVAX to the file NVAX.scid. Service: equities.us | 2016-09-16 11:50:25 HD Request # 118 | Download start Date-Time: 2016-09-16 10:35:19.000 | 2016-09-16 11:50:25 HD Request # 118 | Requesting historical Minute data for the current day. | 2016-09-16 11:50:25 HTTP connection to www.sierrachart.com:80 (144) | Closed. No error. | 2016-09-16 11:50:25 HTTP connection to www.sierrachart.com:80 (144) | Shutdown and closed. | 2016-09-16 11:50:25 HTTPS connection to ameritrade02.streamer.com:443 (142) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:50:28 HTTPS connection to ameritrade02.streamer.com:443 (142) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:50:28 HTTPS connection to ameritrade02.streamer.com:443 (142) | SSL has been shut down. | 2016-09-16 11:50:28 HTTPS connection to ameritrade02.streamer.com:443 (142) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:50:28 HTTPS connection to ameritrade02.streamer.com:443 (142) | Shutdown and closed. | 2016-09-16 11:50:28 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:50:28 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 93. | 2016-09-16 11:50:28 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:50:28 HTTPS connection to ameritrade02.streamer.com:443 (145) | Connected. | 2016-09-16 11:50:29 HTTPS connection to ameritrade02.streamer.com:443 (145) | Starting TLS 1.0 connection. | 2016-09-16 11:50:29 HTTPS connection to ameritrade02.streamer.com:443 (145) | SSL connection established. | 2016-09-16 11:50:29 HD Request # 118 | Error downloading historical Intraday data for NVAX. The download timed out. | 2016-09-16 11:51:25 HD Request # 118 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NVAX | 2016-09-16 11:51:25 HD Request # 118 | Receiving Intraday data for NVAX starting at 2016-09-16 11:34:48 | 2016-09-16 11:51:25 HD Request # 118 | Timestamp of first Intraday data file record written: 2016-09-16 11:34:48 | 2016-09-16 11:51:25 Added 7285 Time and Sales records to Intraday data file for NVAX after download. | 2016-09-16 11:51:25 HD Request # 118 | Intraday download COMPLETE for NVAX. Completion time: 1m. Unique request ID: 117 | 2016-09-16 11:51:25 Removed historical data download ID 117 | 2016-09-16 11:51:25 Real-time Intraday chart data file updates started for NVAX | 2016-09-16 11:51:25 Opened cached Intraday file: C:\SierraChart\Data\NVAX.scid | 2016-09-16 11:51:25 Intraday chart data file opened for NVAX | 2016-09-16 11:51:25 HD Request # 119 | Downloading Intraday chart data for AFMD to the file AFMD.scid. Service: equities.us | 2016-09-16 11:51:25 HD Request # 119 | Download start Date-Time: 2016-09-16 10:41:38.000 | 2016-09-16 11:51:25 HD Request # 119 | Requesting historical Minute data for the current day. | 2016-09-16 11:51:25 HTTPS connection to ameritrade02.streamer.com:443 (145) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:51:38 HTTPS connection to ameritrade02.streamer.com:443 (145) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:51:38 HTTPS connection to ameritrade02.streamer.com:443 (145) | SSL has been shut down. | 2016-09-16 11:51:38 HTTPS connection to ameritrade02.streamer.com:443 (145) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:51:38 HTTPS connection to ameritrade02.streamer.com:443 (145) | Shutdown and closed. | 2016-09-16 11:51:38 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:51:38 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 95. | 2016-09-16 11:51:38 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:51:38 HTTPS connection to ameritrade02.streamer.com:443 (146) | Connected. | 2016-09-16 11:51:39 HTTPS connection to ameritrade02.streamer.com:443 (146) | Starting TLS 1.0 connection. | 2016-09-16 11:51:39 HTTPS connection to ameritrade02.streamer.com:443 (146) | SSL connection established. | 2016-09-16 11:51:39 HD Request # 119 | Error downloading historical Intraday data for AFMD. The download timed out. | 2016-09-16 11:52:25 HD Request # 119 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AFMD | 2016-09-16 11:52:25 HD Request # 119 | Receiving Intraday data for AFMD starting at 2016-09-16 10:52:08 | 2016-09-16 11:52:25 HD Request # 119 | Timestamp of first Intraday data file record written: 2016-09-16 10:52:08 | 2016-09-16 11:52:25 Added 30 Time and Sales records to Intraday data file for AFMD after download. | 2016-09-16 11:52:25 HD Request # 119 | Intraday download COMPLETE for AFMD. Completion time: 1m. Unique request ID: 118 | 2016-09-16 11:52:25 Removed historical data download ID 118 | 2016-09-16 11:52:25 Real-time Intraday chart data file updates started for AFMD | 2016-09-16 11:52:25 Opened cached Intraday file: C:\SierraChart\Data\AFMD.scid | 2016-09-16 11:52:25 Intraday chart data file opened for AFMD | 2016-09-16 11:52:25 HD Request # 120 | Downloading Intraday chart data for BCEI to the file BCEI.scid. Service: equities.us | 2016-09-16 11:52:25 HD Request # 120 | Download start Date-Time: 2016-09-16 10:34:23.000 | 2016-09-16 11:52:25 HD Request # 120 | Requesting historical Minute data for the current day. | 2016-09-16 11:52:25 HTTPS connection to ameritrade02.streamer.com:443 (146) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:52:48 HTTPS connection to ameritrade02.streamer.com:443 (146) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:52:48 HTTPS connection to ameritrade02.streamer.com:443 (146) | SSL has been shut down. | 2016-09-16 11:52:48 HTTPS connection to ameritrade02.streamer.com:443 (146) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:52:48 HTTPS connection to ameritrade02.streamer.com:443 (146) | Shutdown and closed. | 2016-09-16 11:52:48 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:52:48 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 96. | 2016-09-16 11:52:48 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:52:48 HTTPS connection to ameritrade02.streamer.com:443 (148) | Connected. | 2016-09-16 11:52:49 HTTPS connection to ameritrade02.streamer.com:443 (148) | Starting TLS 1.0 connection. | 2016-09-16 11:52:49 HTTPS connection to ameritrade02.streamer.com:443 (148) | SSL connection established. | 2016-09-16 11:52:49 HD Request # 120 | Error downloading historical Intraday data for BCEI. The download timed out. | 2016-09-16 11:53:25 HD Request # 120 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for BCEI | 2016-09-16 11:53:25 HD Request # 120 | Receiving Intraday data for BCEI starting at 2016-09-16 10:50:29 | 2016-09-16 11:53:25 HD Request # 120 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:29 | 2016-09-16 11:53:25 Added 172 Time and Sales records to Intraday data file for BCEI after download. | 2016-09-16 11:53:25 HD Request # 120 | Intraday download COMPLETE for BCEI. Completion time: 1m. Unique request ID: 119 | 2016-09-16 11:53:25 Removed historical data download ID 119 | 2016-09-16 11:53:25 Real-time Intraday chart data file updates started for BCEI | 2016-09-16 11:53:25 Opened cached Intraday file: C:\SierraChart\Data\BCEI.scid | 2016-09-16 11:53:25 Intraday chart data file opened for BCEI | 2016-09-16 11:53:25 HD Request # 121 | Downloading Intraday chart data for CXDC to the file CXDC.scid. Service: equities.us | 2016-09-16 11:53:25 HD Request # 121 | Download start Date-Time: 2016-09-16 10:44:13.000 | 2016-09-16 11:53:25 HD Request # 121 | Requesting historical Minute data for the current day. | 2016-09-16 11:53:25 HTTPS connection to ameritrade02.streamer.com:443 (148) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:53:58 HTTPS connection to ameritrade02.streamer.com:443 (148) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:53:58 HTTPS connection to ameritrade02.streamer.com:443 (148) | SSL has been shut down. | 2016-09-16 11:53:58 HTTPS connection to ameritrade02.streamer.com:443 (148) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:53:58 HTTPS connection to ameritrade02.streamer.com:443 (148) | Shutdown and closed. | 2016-09-16 11:53:58 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:53:58 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 97. | 2016-09-16 11:53:58 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:53:58 HTTPS connection to ameritrade02.streamer.com:443 (149) | Connected. | 2016-09-16 11:53:59 HTTPS connection to ameritrade02.streamer.com:443 (149) | Starting TLS 1.0 connection. | 2016-09-16 11:53:59 HTTPS connection to ameritrade02.streamer.com:443 (149) | SSL connection established. | 2016-09-16 11:53:59 HD Request # 121 | Error downloading historical Intraday data for CXDC. The download timed out. | 2016-09-16 11:54:25 HD Request # 121 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CXDC | 2016-09-16 11:54:25 HD Request # 121 | Receiving Intraday data for CXDC starting at 2016-09-16 11:14:57 | 2016-09-16 11:54:25 HD Request # 121 | Timestamp of first Intraday data file record written: 2016-09-16 11:14:57 | 2016-09-16 11:54:25 Added 5 Time and Sales records to Intraday data file for CXDC after download. | 2016-09-16 11:54:25 HD Request # 121 | Intraday download COMPLETE for CXDC. Completion time: 1m. Unique request ID: 120 | 2016-09-16 11:54:25 Removed historical data download ID 120 | 2016-09-16 11:54:25 Real-time Intraday chart data file updates started for CXDC | 2016-09-16 11:54:25 Opened cached Intraday file: C:\SierraChart\Data\CXDC.scid | 2016-09-16 11:54:25 Intraday chart data file opened for CXDC | 2016-09-16 11:54:25 HD Request # 122 | Downloading Intraday chart data for EXAS to the file EXAS.scid. Service: equities.us | 2016-09-16 11:54:25 HD Request # 122 | Download start Date-Time: 2016-09-16 10:35:16.000 | 2016-09-16 11:54:25 HD Request # 122 | Requesting historical Minute data for the current day. | 2016-09-16 11:54:25 HTTPS connection to ameritrade02.streamer.com:443 (149) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:55:08 HTTPS connection to ameritrade02.streamer.com:443 (149) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:55:08 HTTPS connection to ameritrade02.streamer.com:443 (149) | SSL has been shut down. | 2016-09-16 11:55:08 HTTPS connection to ameritrade02.streamer.com:443 (149) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:55:08 HTTPS connection to ameritrade02.streamer.com:443 (149) | Shutdown and closed. | 2016-09-16 11:55:08 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:55:08 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 99. | 2016-09-16 11:55:08 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:55:09 HTTPS connection to ameritrade02.streamer.com:443 (151) | Connected. | 2016-09-16 11:55:09 HTTPS connection to ameritrade02.streamer.com:443 (151) | Starting TLS 1.0 connection. | 2016-09-16 11:55:09 HTTPS connection to ameritrade02.streamer.com:443 (151) | SSL connection established. | 2016-09-16 11:55:09 HD Request # 122 | Error downloading historical Intraday data for EXAS. The download timed out. | 2016-09-16 11:55:25 HD Request # 122 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EXAS | 2016-09-16 11:55:25 HD Request # 122 | Receiving Intraday data for EXAS starting at 2016-09-16 10:50:26 | 2016-09-16 11:55:25 HD Request # 122 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:26 | 2016-09-16 11:55:25 Added 2521 Time and Sales records to Intraday data file for EXAS after download. | 2016-09-16 11:55:25 HD Request # 122 | Intraday download COMPLETE for EXAS. Completion time: 1m. Unique request ID: 121 | 2016-09-16 11:55:25 Removed historical data download ID 121 | 2016-09-16 11:55:25 Real-time Intraday chart data file updates started for EXAS | 2016-09-16 11:55:25 Opened cached Intraday file: C:\SierraChart\Data\EXAS.scid | 2016-09-16 11:55:25 Intraday chart data file opened for EXAS | 2016-09-16 11:55:25 HD Request # 123 | Downloading Intraday chart data for GRSH to the file GRSH.scid. Service: equities.us | 2016-09-16 11:55:25 HD Request # 123 | Download start Date-Time: 2016-09-16 10:35:08.000 | 2016-09-16 11:55:25 HD Request # 123 | Requesting historical Minute data for the current day. | 2016-09-16 11:55:25 HTTPS connection to ameritrade02.streamer.com:443 (151) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:56:18 HTTPS connection to ameritrade02.streamer.com:443 (151) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:56:18 HTTPS connection to ameritrade02.streamer.com:443 (151) | SSL has been shut down. | 2016-09-16 11:56:18 HTTPS connection to ameritrade02.streamer.com:443 (151) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:56:18 HTTPS connection to ameritrade02.streamer.com:443 (151) | Shutdown and closed. | 2016-09-16 11:56:18 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:56:18 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 100. | 2016-09-16 11:56:18 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:56:19 HTTPS connection to ameritrade02.streamer.com:443 (153) | Connected. | 2016-09-16 11:56:19 HTTPS connection to ameritrade02.streamer.com:443 (153) | Starting TLS 1.0 connection. | 2016-09-16 11:56:19 HTTPS connection to ameritrade02.streamer.com:443 (153) | SSL connection established. | 2016-09-16 11:56:19 HD Request # 123 | Error downloading historical Intraday data for GRSH. The download timed out. | 2016-09-16 11:56:25 HD Request # 123 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GRSH | 2016-09-16 11:56:25 HD Request # 123 | Receiving Intraday data for GRSH starting at 2016-09-16 10:54:13 | 2016-09-16 11:56:25 HD Request # 123 | Timestamp of first Intraday data file record written: 2016-09-16 10:54:13 | 2016-09-16 11:56:25 Added 396 Time and Sales records to Intraday data file for GRSH after download. | 2016-09-16 11:56:25 HD Request # 123 | Intraday download COMPLETE for GRSH. Completion time: 1m. Unique request ID: 122 | 2016-09-16 11:56:25 Removed historical data download ID 122 | 2016-09-16 11:56:25 Real-time Intraday chart data file updates started for GRSH | 2016-09-16 11:56:25 Opened cached Intraday file: C:\SierraChart\Data\GRSH.scid | 2016-09-16 11:56:25 Intraday chart data file opened for GRSH | 2016-09-16 11:56:25 HD Request # 124 | Downloading Intraday chart data for NK to the file NK.scid. Service: equities.us | 2016-09-16 11:56:25 HD Request # 124 | Download start Date-Time: 2016-09-16 10:28:53.000 | 2016-09-16 11:56:25 HD Request # 124 | Requesting historical Minute data for the current day. | 2016-09-16 11:56:25 HD Request # 124 | Error downloading historical Intraday data for NK. The download timed out. | 2016-09-16 11:57:25 HD Request # 124 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NK | 2016-09-16 11:57:25 HD Request # 124 | Receiving Intraday data for NK starting at 2016-09-16 10:50:29 | 2016-09-16 11:57:25 HD Request # 124 | Timestamp of first Intraday data file record written: 2016-09-16 10:50:29 | 2016-09-16 11:57:25 Added 165 Time and Sales records to Intraday data file for NK after download. | 2016-09-16 11:57:25 HD Request # 124 | Intraday download COMPLETE for NK. Completion time: 1m 1s. Unique request ID: 123 | 2016-09-16 11:57:25 Removed historical data download ID 123 | 2016-09-16 11:57:25 Real-time Intraday chart data file updates started for NK | 2016-09-16 11:57:25 Opened cached Intraday file: C:\SierraChart\Data\NK.scid | 2016-09-16 11:57:25 Intraday chart data file opened for NK | 2016-09-16 11:57:25 HD Request # 125 | Downloading Intraday chart data for PIRS to the file PIRS.scid. Service: equities.us | 2016-09-16 11:57:25 HD Request # 125 | Download start Date-Time: 2016-09-16 10:15:32.000 | 2016-09-16 11:57:25 HD Request # 125 | Requesting historical Minute data for the current day. | 2016-09-16 11:57:25 HTTPS connection to ameritrade02.streamer.com:443 (153) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:57:28 HTTPS connection to ameritrade02.streamer.com:443 (153) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:57:28 HTTPS connection to ameritrade02.streamer.com:443 (153) | SSL has been shut down. | 2016-09-16 11:57:28 HTTPS connection to ameritrade02.streamer.com:443 (153) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:57:28 HTTPS connection to ameritrade02.streamer.com:443 (153) | Shutdown and closed. | 2016-09-16 11:57:28 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:57:28 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 101. | 2016-09-16 11:57:28 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 11:57:29 HTTPS connection to ameritrade02.streamer.com:443 (154) | Connected. | 2016-09-16 11:57:29 HTTPS connection to ameritrade02.streamer.com:443 (154) | Starting TLS 1.0 connection. | 2016-09-16 11:57:29 HTTPS connection to ameritrade02.streamer.com:443 (154) | SSL connection established. | 2016-09-16 11:57:29 HD Request # 125 | Error downloading historical Intraday data for PIRS. The download timed out. | 2016-09-16 11:58:25 HD Request # 125 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for PIRS | 2016-09-16 11:58:25 HD Request # 125 | Receiving Intraday data for PIRS starting at 2016-09-16 10:52:17 | 2016-09-16 11:58:25 HD Request # 125 | Timestamp of first Intraday data file record written: 2016-09-16 10:52:17 | 2016-09-16 11:58:25 Added 57 Time and Sales records to Intraday data file for PIRS after download. | 2016-09-16 11:58:25 HD Request # 125 | Intraday download COMPLETE for PIRS. Completion time: 1m. Unique request ID: 124 | 2016-09-16 11:58:25 Removed historical data download ID 124 | 2016-09-16 11:58:25 Real-time Intraday chart data file updates started for PIRS | 2016-09-16 11:58:25 Opened cached Intraday file: C:\SierraChart\Data\PIRS.scid | 2016-09-16 11:58:25 Intraday chart data file opened for PIRS | 2016-09-16 11:58:25 HD Request # 126 | Downloading Intraday chart data for SDRL to the file SDRL.scid. Service: equities.us | 2016-09-16 11:58:25 HD Request # 126 | Download start Date-Time: 2016-09-16 10:35:09.000 | 2016-09-16 11:58:25 HD Request # 126 | Requesting historical Minute data for the current day. | 2016-09-16 11:58:25 HTTPS connection to ameritrade02.streamer.com:443 (154) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:58:39 HTTPS connection to ameritrade02.streamer.com:443 (154) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:58:39 HTTPS connection to ameritrade02.streamer.com:443 (154) | SSL has been shut down. | 2016-09-16 11:58:39 HTTPS connection to ameritrade02.streamer.com:443 (154) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:58:39 HTTPS connection to ameritrade02.streamer.com:443 (154) | Shutdown and closed. | 2016-09-16 11:58:39 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:58:39 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 103. | 2016-09-16 11:58:39 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:58:39 HTTPS connection to ameritrade02.streamer.com:443 (156) | Connected. | 2016-09-16 11:58:39 HTTPS connection to ameritrade02.streamer.com:443 (156) | Starting TLS 1.0 connection. | 2016-09-16 11:58:39 HTTPS connection to ameritrade02.streamer.com:443 (156) | SSL connection established. | 2016-09-16 11:58:39 HD Request # 126 | Error downloading historical Intraday data for SDRL. The download timed out. | 2016-09-16 11:59:25 HD Request # 126 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SDRL | 2016-09-16 11:59:25 HD Request # 126 | Receiving Intraday data for SDRL starting at 2016-09-16 10:51:15 | 2016-09-16 11:59:25 HD Request # 126 | Timestamp of first Intraday data file record written: 2016-09-16 10:51:15 | 2016-09-16 11:59:25 Added 1835 Time and Sales records to Intraday data file for SDRL after download. | 2016-09-16 11:59:25 HD Request # 126 | Intraday download COMPLETE for SDRL. Completion time: 1m. Unique request ID: 125 | 2016-09-16 11:59:25 Removed historical data download ID 125 | 2016-09-16 11:59:25 Real-time Intraday chart data file updates started for SDRL | 2016-09-16 11:59:25 Opened cached Intraday file: C:\SierraChart\Data\SDRL.scid | 2016-09-16 11:59:25 Intraday chart data file opened for SDRL | 2016-09-16 11:59:25 HD Request # 127 | Downloading Intraday chart data for SORL to the file SORL.scid. Service: equities.us | 2016-09-16 11:59:25 HD Request # 127 | Download start Date-Time: 2016-09-16 10:48:09.000 | 2016-09-16 11:59:25 HD Request # 127 | Requesting historical Minute data for the current day. | 2016-09-16 11:59:25 HTTPS connection to ameritrade02.streamer.com:443 (156) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:59:41 HTTPS connection to ameritrade02.streamer.com:443 (156) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:59:41 HTTPS connection to ameritrade02.streamer.com:443 (156) | SSL has been shut down. | 2016-09-16 11:59:41 HTTPS connection to ameritrade02.streamer.com:443 (156) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:59:41 HTTPS connection to ameritrade02.streamer.com:443 (156) | Shutdown and closed. | 2016-09-16 11:59:41 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:59:41 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 104. | 2016-09-16 11:59:41 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:59:41 HTTPS connection to ameritrade02.streamer.com:443 (157) | Connected. | 2016-09-16 11:59:41 HTTPS connection to ameritrade02.streamer.com:443 (157) | Starting TLS 1.0 connection. | 2016-09-16 11:59:41 HTTPS connection to ameritrade02.streamer.com:443 (157) | SSL connection established. | 2016-09-16 11:59:42 HD Request # 127 | Error downloading historical Intraday data for SORL. The download timed out. | 2016-09-16 12:00:25 HD Request # 127 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SORL | 2016-09-16 12:00:25 HD Request # 127 | Receiving Intraday data for SORL starting at 2016-09-16 10:53:47 | 2016-09-16 12:00:25 HD Request # 127 | Timestamp of first Intraday data file record written: 2016-09-16 10:53:47 | 2016-09-16 12:00:25 Added 179 Time and Sales records to Intraday data file for SORL after download. | 2016-09-16 12:00:25 HD Request # 127 | Intraday download COMPLETE for SORL. Completion time: 1m. Unique request ID: 126 | 2016-09-16 12:00:25 Removed historical data download ID 126 | 2016-09-16 12:00:25 Real-time Intraday chart data file updates started for SORL | 2016-09-16 12:00:25 Opened cached Intraday file: C:\SierraChart\Data\SORL.scid | 2016-09-16 12:00:25 Intraday chart data file opened for SORL | 2016-09-16 12:00:25 HTTPS connection to ameritrade02.streamer.com:443 (157) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 12:00:51 HTTPS connection to ameritrade02.streamer.com:443 (157) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 12:00:51 HTTPS connection to ameritrade02.streamer.com:443 (157) | SSL has been shut down. | 2016-09-16 12:00:51 HTTPS connection to ameritrade02.streamer.com:443 (157) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 12:00:51 HTTPS connection to ameritrade02.streamer.com:443 (157) | Shutdown and closed. | 2016-09-16 12:00:51 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 12:00:51 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 105. | 2016-09-16 12:00:51 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 12:00:51 HTTPS connection to ameritrade02.streamer.com:443 (159) | Connected. | 2016-09-16 12:00:51 HTTPS connection to ameritrade02.streamer.com:443 (159) | Starting TLS 1.0 connection. | 2016-09-16 12:00:51 HTTPS connection to ameritrade02.streamer.com:443 (159) | SSL connection established. | 2016-09-16 12:00:52 HTTPS connection to ameritrade02.streamer.com:443 (159) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 12:02:01 HTTPS connection to ameritrade02.streamer.com:443 (159) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 12:02:01 HTTPS connection to ameritrade02.streamer.com:443 (159) | SSL has been shut down. | 2016-09-16 12:02:01 HTTPS connection to ameritrade02.streamer.com:443 (159) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 12:02:01 HTTPS connection to ameritrade02.streamer.com:443 (159) | Shutdown and closed. | 2016-09-16 12:02:01 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 12:02:01 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 107. | 2016-09-16 12:02:01 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 12:02:01 HTTPS connection to ameritrade02.streamer.com:443 (160) | Connected. | 2016-09-16 12:02:02 HTTPS connection to ameritrade02.streamer.com:443 (160) | Starting TLS 1.0 connection. | 2016-09-16 12:02:02 HTTPS connection to ameritrade02.streamer.com:443 (160) | SSL connection established. | 2016-09-16 12:02:02 HTTPS connection to ameritrade02.streamer.com:443 (160) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 12:03:11 HTTPS connection to ameritrade02.streamer.com:443 (160) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 12:03:11 HTTPS connection to ameritrade02.streamer.com:443 (160) | SSL has been shut down. | 2016-09-16 12:03:11 HTTPS connection to ameritrade02.streamer.com:443 (160) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 12:03:11 HTTPS connection to ameritrade02.streamer.com:443 (160) | Shutdown and closed. | 2016-09-16 12:03:11 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 12:03:11 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 108. | 2016-09-16 12:03:11 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 12:03:11 HTTPS connection to ameritrade02.streamer.com:443 (162) | Connected. | 2016-09-16 12:03:12 HTTPS connection to ameritrade02.streamer.com:443 (162) | Starting TLS 1.0 connection. | 2016-09-16 12:03:12 HTTPS connection to ameritrade02.streamer.com:443 (162) | SSL connection established. | 2016-09-16 12:03:12 HTTPS connection to ameritrade02.streamer.com:443 (162) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 12:04:21 HTTPS connection to ameritrade02.streamer.com:443 (162) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 12:04:21 HTTPS connection to ameritrade02.streamer.com:443 (162) | SSL has been shut down. | 2016-09-16 12:04:21 HTTPS connection to ameritrade02.streamer.com:443 (162) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 12:04:21 HTTPS connection to ameritrade02.streamer.com:443 (162) | Shutdown and closed. | 2016-09-16 12:04:21 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 12:04:21 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 109. | 2016-09-16 12:04:21 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 12:04:21 HTTPS connection to ameritrade02.streamer.com:443 (164) | Connected. | 2016-09-16 12:04:22 HTTPS connection to ameritrade02.streamer.com:443 (164) | Starting TLS 1.0 connection. | 2016-09-16 12:04:22 HTTPS connection to ameritrade02.streamer.com:443 (164) | SSL connection established. | 2016-09-16 12:04:22 HTTPS connection to ameritrade02.streamer.com:443 (164) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 12:05:31 HTTPS connection to ameritrade02.streamer.com:443 (164) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 12:05:31 HTTPS connection to ameritrade02.streamer.com:443 (164) | SSL has been shut down. | 2016-09-16 12:05:31 HTTPS connection to ameritrade02.streamer.com:443 (164) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 12:05:31 HTTPS connection to ameritrade02.streamer.com:443 (164) | Shutdown and closed. | 2016-09-16 12:05:31 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 12:05:31 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 111. | 2016-09-16 12:05:31 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 12:05:31 HTTPS connection to ameritrade02.streamer.com:443 (165) | Connected. | 2016-09-16 12:05:32 HTTPS connection to ameritrade02.streamer.com:443 (165) | Starting TLS 1.0 connection. | 2016-09-16 12:05:32 HTTPS connection to ameritrade02.streamer.com:443 (165) | SSL connection established. | 2016-09-16 12:05:32 HTTPS connection to ameritrade02.streamer.com:443 (165) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 12:06:41 HTTPS connection to ameritrade02.streamer.com:443 (165) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 12:06:41 HTTPS connection to ameritrade02.streamer.com:443 (165) | SSL has been shut down. | 2016-09-16 12:06:41 HTTPS connection to ameritrade02.streamer.com:443 (165) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 12:06:41 HTTPS connection to ameritrade02.streamer.com:443 (165) | Shutdown and closed. | 2016-09-16 12:06:41 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 12:06:41 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 112. | 2016-09-16 12:06:41 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 12:06:41 HTTPS connection to ameritrade02.streamer.com:443 (167) | Connected. | 2016-09-16 12:06:42 HTTPS connection to ameritrade02.streamer.com:443 (167) | Starting TLS 1.0 connection. | 2016-09-16 12:06:42 HTTPS connection to ameritrade02.streamer.com:443 (167) | SSL connection established. | 2016-09-16 12:06:42 HTTPS connection to ameritrade02.streamer.com:443 (167) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 12:07:51 HTTPS connection to ameritrade02.streamer.com:443 (167) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 12:07:51 HTTPS connection to ameritrade02.streamer.com:443 (167) | SSL has been shut down. | 2016-09-16 12:07:51 HTTPS connection to ameritrade02.streamer.com:443 (167) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 12:07:51 HTTPS connection to ameritrade02.streamer.com:443 (167) | Shutdown and closed. | 2016-09-16 12:07:51 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 12:07:51 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 113. | 2016-09-16 12:07:51 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 12:07:51 HTTPS connection to ameritrade02.streamer.com:443 (168) | Connected. | 2016-09-16 12:07:52 HTTPS connection to ameritrade02.streamer.com:443 (168) | Starting TLS 1.0 connection. | 2016-09-16 12:07:52 HTTPS connection to ameritrade02.streamer.com:443 (168) | SSL connection established. | 2016-09-16 12:07:52 HTTPS connection to ameritrade02.streamer.com:443 (168) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 12:09:01 HTTPS connection to ameritrade02.streamer.com:443 (168) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 12:09:01 HTTPS connection to ameritrade02.streamer.com:443 (168) | SSL has been shut down. | 2016-09-16 12:09:01 HTTPS connection to ameritrade02.streamer.com:443 (168) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 12:09:01 HTTPS connection to ameritrade02.streamer.com:443 (168) | Shutdown and closed. | 2016-09-16 12:09:01 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 12:09:01 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 115. | 2016-09-16 12:09:01 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 12:09:02 HTTPS connection to ameritrade02.streamer.com:443 (170) | Connected. | 2016-09-16 12:09:02 HTTPS connection to ameritrade02.streamer.com:443 (170) | Starting TLS 1.0 connection. | 2016-09-16 12:09:02 HTTPS connection to ameritrade02.streamer.com:443 (170) | SSL connection established. | 2016-09-16 12:09:02 HTTPS connection to ameritrade02.streamer.com:443 (170) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 12:10:11 HTTPS connection to ameritrade02.streamer.com:443 (170) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 12:10:11 HTTPS connection to ameritrade02.streamer.com:443 (170) | SSL has been shut down. | 2016-09-16 12:10:11 HTTPS connection to ameritrade02.streamer.com:443 (170) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 12:10:11 HTTPS connection to ameritrade02.streamer.com:443 (170) | Shutdown and closed. | 2016-09-16 12:10:11 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 12:10:11 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 116. | 2016-09-16 12:10:11 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 12:10:11 HTTPS connection to ameritrade02.streamer.com:443 (171) | Connected. | 2016-09-16 12:10:12 HTTPS connection to ameritrade02.streamer.com:443 (171) | Starting TLS 1.0 connection. | 2016-09-16 12:10:12 HTTPS connection to ameritrade02.streamer.com:443 (171) | SSL connection established. | 2016-09-16 12:10:12 HTTPS connection to ameritrade02.streamer.com:443 (171) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 12:11:21 HTTPS connection to ameritrade02.streamer.com:443 (171) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 12:11:21 HTTPS connection to ameritrade02.streamer.com:443 (171) | SSL has been shut down. | 2016-09-16 12:11:21 HTTPS connection to ameritrade02.streamer.com:443 (171) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 12:11:21 HTTPS connection to ameritrade02.streamer.com:443 (171) | Shutdown and closed. | 2016-09-16 12:11:21 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 12:11:21 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 117. | 2016-09-16 12:11:21 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 12:11:21 HTTPS connection to ameritrade02.streamer.com:443 (173) | Connected. | 2016-09-16 12:11:22 HTTPS connection to ameritrade02.streamer.com:443 (173) | Starting TLS 1.0 connection. | 2016-09-16 12:11:22 HTTPS connection to ameritrade02.streamer.com:443 (173) | SSL connection established. | 2016-09-16 12:11:22 HTTPS connection to ameritrade02.streamer.com:443 (173) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 12:12:31 HTTPS connection to ameritrade02.streamer.com:443 (173) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 12:12:31 HTTPS connection to ameritrade02.streamer.com:443 (173) | SSL has been shut down. | 2016-09-16 12:12:31 HTTPS connection to ameritrade02.streamer.com:443 (173) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 12:12:31 HTTPS connection to ameritrade02.streamer.com:443 (173) | Shutdown and closed. | 2016-09-16 12:12:31 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 12:12:31 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 119. | 2016-09-16 12:12:31 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: FB | 2016-09-16 12:44:29 Intraday data recording state for symbol FB is set to download 'Pending'. | 2016-09-16 12:44:29 HD Request # 128 | Downloading Intraday chart data for FB to the file FB.scid. Service: equities.us | 2016-09-16 12:44:29 HD Request # 128 | Download start Date-Time: 2016-09-16 11:25:59.000 | 2016-09-16 12:44:29 HD Request # 128 | Disabling Intraday chart updating for symbol during historical data download. | 2016-09-16 12:44:29 HD Request # 128 | Using server: ds1.sierracharts.com port 10149 | 2016-09-16 12:44:29 Socket (0) | Resolved address ds1.sierracharts.com to IP 8.18.161.135. | 2016-09-16 12:44:29 Socket (192) | Connected. | 2016-09-16 12:44:29 HD Request # 128 | Sending historical data logon request message. | 2016-09-16 12:44:29 HD Request # 128 | Requesting Intraday data. Start Date-Time: 2016-09-16 11:25:59. Record interval: 1. Symbol: FB | 2016-09-16 12:44:29 HD Request # 128 | Decompressing data. | 2016-09-16 12:44:29 HD Request # 128 | Receiving Intraday data for FB starting at 2016-09-16 11:26:00 | 2016-09-16 12:44:29 HD Request # 128 | Truncating file to starting Date-Time of 2016-09-16 11:26:00 | 2016-09-16 12:44:29 HD Request # 128 | Timestamp of first Intraday data file record written: 2016-09-16 11:26:00 | 2016-09-16 12:44:29 Socket (192) | Shutdown and closed. | 2016-09-16 12:44:29 The network socket for historical data has been closed. | 2016-09-16 12:44:29 HD Request # 128 | Received 1613 records from 2016-09-16 11:26:00 to 2016-09-16 12:29:16 (63.3 minutes) and wrote 1613 records for FB | 2016-09-16 12:44:29 HD Request # 128 | Intraday download COMPLETE for FB. Completion time: 0s. Unique request ID: 127 | 2016-09-16 12:44:29 Removed historical data download ID 127 | 2016-09-16 12:44:29 Real-time Intraday chart data file updates started for FB | 2016-09-16 12:44:29 Opened cached Intraday file: C:\SierraChart\Data\FB.scid | 2016-09-16 12:44:29 Intraday chart data file opened for FB | 2016-09-16 12:44:29 HD Request # 128 | Enabling Intraday chart updating for symbol. | 2016-09-16 12:44:29 HD Request # 128 | Reloading Intraday charts for FB | 2016-09-16 12:44:29 Reloading all charts with filename: FB.scid | 2016-09-16 12:44:29 TD Ameritrade | Using primary service for historical data for FB | 2016-09-16 12:44:29 Intraday data recording state for symbol FB is set to download 'Pending'. | 2016-09-16 12:44:29 HD Request # 129 | Downloading Intraday chart data for FB to the file FB.scid. Service: equities.us | 2016-09-16 12:44:29 HD Request # 129 | Download start Date-Time: 2016-09-16 12:29:16.000 | 2016-09-16 12:44:29 HD Request # 129 | Requesting historical Minute data for the current day. | 2016-09-16 12:44:29 TD Ameritrade | Using primary service for historical data for FB | 2016-09-16 12:44:29 FB 1 Min #1 | Reloading chart. | 2016-09-16 12:44:29 TD Ameritrade | Using primary service for historical data for FB | 2016-09-16 12:44:29 FB 2 Min #63 | Reloading chart. | 2016-09-16 12:44:29 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.38. | 2016-09-16 12:44:29 HTTPS connection to ameritrade02.streamer.com:443 (193) | Connected. | 2016-09-16 12:44:29 HTTPS connection to ameritrade02.streamer.com:443 (193) | Starting TLS 1.0 connection. | 2016-09-16 12:44:29 HTTPS connection to ameritrade02.streamer.com:443 (193) | SSL connection established. | 2016-09-16 12:44:29 HD Request # 129 | Error downloading historical Intraday data for FB. The download timed out. | 2016-09-16 12:45:29 HD Request # 129 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for FB | 2016-09-16 12:45:29 HD Request # 129 | Receiving Intraday data for FB starting at 2016-09-16 12:29:17 | 2016-09-16 12:45:29 HD Request # 129 | Timestamp of first Intraday data file record written: 2016-09-16 12:29:17 | 2016-09-16 12:45:29 Added 1948 Time and Sales records to Intraday data file for FB after download. | 2016-09-16 12:45:29 HD Request # 129 | Intraday download COMPLETE for FB. Completion time: 1m 1s. Unique request ID: 128 | 2016-09-16 12:45:29 Removed historical data download ID 128 | 2016-09-16 12:45:29 Real-time Intraday chart data file updates started for FB | 2016-09-16 12:45:29 Opened cached Intraday file: C:\SierraChart\Data\FB.scid | 2016-09-16 12:45:29 Intraday chart data file opened for FB | 2016-09-16 12:45:29 HTTPS connection to ameritrade02.streamer.com:443 (193) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 12:45:39 HTTPS connection to ameritrade02.streamer.com:443 (193) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 12:45:39 HTTPS connection to ameritrade02.streamer.com:443 (193) | SSL has been shut down. | 2016-09-16 12:45:39 HTTPS connection to ameritrade02.streamer.com:443 (193) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 12:45:39 HTTPS connection to ameritrade02.streamer.com:443 (193) | Shutdown and closed. | 2016-09-16 12:45:39 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 12:45:39 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 135. | 2016-09-16 12:45:39 TD Ameritrade | Using primary service for historical data for NFLX | 2016-09-16 12:48:43 NFLX 1 Min #1 | Reloading chart. | 2016-09-16 12:48:43 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-09-16 12:50:20 HTTP connection to www.sierrachart.com:80 (197) | Connected. | 2016-09-16 12:50:20 Received Date-time from server. Delay adjusted UTC Date-time: 2016-09-16 16:50:07.714. Round-trip delay: 00:00:00.186 | 2016-09-16 12:50:20 Error setting the system Date-time. Windows error code 1314: A required privilege is not held by the client. | 2016-09-16 12:50:20 * HTTP connection to www.sierrachart.com:80 (197) | Closed. No error. | 2016-09-16 12:50:25 HTTP connection to www.sierrachart.com:80 (197) | Shutdown and closed. | 2016-09-16 12:50:25 |
[2016-09-19 17:56:58] |
These are some of the relevant messages: HTTPS connection to ameritrade02.streamer.com:443 (80) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (80) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (80) | SSL has been shut down. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (80) | SSL object has been freed. SSL state is now disconnected. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (80) | Shutdown and closed. | 2016-09-16 11:05:11 c_SimpleXMLDocument::ReadFromMemory error: expected < | 2016-09-16 11:05:11 * TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 38. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (0) | Resolved address ameritrade02.streamer.com to IP 216.105.251.37. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (82) | Connected. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (82) | Starting TLS 1.0 connection. | 2016-09-16 11:05:11 HTTPS connection to ameritrade02.streamer.com:443 (82) | SSL connection established. | 2016-09-16 11:05:11 HD Request # 72 | Error downloading historical Intraday data for DNAI. The download timed out. | 2016-09-16 11:05:24 This indicates a problem with the TD Ameritrade server and that is not something we can help with at all. For reliable market data, you need to use the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
