Date/Time: Fri, 10 Jan 2025 12:20:02 +0000
New Instance Error
View Count: 710
[2016-09-12 11:17:31] |
infpz - Posts: 826 |
Getting this error when I select file > new instance: Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2016-09-12 06:15:55 * |
[2016-09-12 16:33:17] |
We have responded to TransAct about this.
