Date/Time: Fri, 10 Jan 2025 12:52:17 +0000
Is it possible to produce a TPO chart of a CL butterfly spread
View Count: 895
[2016-09-12 08:22:52] |
User158949 - Posts: 4 |
I have entered the symbol for the various calendar spreads and produced TPO charts - this is fine. I need to produce a TPO chart of a butterfly spread. I can create a candlestick chart by using the difference study and applying to 2 calendar spreads, this works fine. When I apply TPO chart to this, it doesnt plot correctly. Is it possible to do what I am trying? Thanks |
[2016-09-12 16:49:08] |
This kind of configuration will not work. Is this an exchange traded spread symbol? It sounds like it and if so if we know which specific one we can give you the symbol and you can create a TPO Profile Chart of it.
[2016-09-12 18:02:32] |
yes its a 12 month butterfly spread. which is CLZ6-CLZ7 - (CLZ7 - CLZ8) = CLZ6 - 2CLZ7 + CLZ8. thanks. |
[2016-09-12 20:34:58] |
Here is the symbol for this: CL:BF Z16-Z17-Z18.FUT_SPREAD.NYMEX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
