Date/Time: Fri, 10 Jan 2025 13:48:16 +0000
[User Discussion] - strange behavior for dll
View Count: 663
[2016-09-11 14:10:12] |
cmb999 - Posts: 211 |
hello, 1) i save a chart with custom study that has an SCInputRef 2) close sierra chart 3) i replace the custom study dll with a new build while sierra is closed 4) i restart sierra with previously saved chart open by default 5) custom study loads but the Input value is set to -1 instead of default, and cannot be changed in F6. i have to remove study and re-apply a new instance |
[2016-09-11 20:18:29] |
This is going to be some problem that you are creating for reasons unknown that you have to figure out and resolve. From our perspective there is absolutely no way that we could duplicate this or have any idea what the problem is unless we were to analyze specifically what you are doing in detail and that is not within the scope of our support. Most of the Sierra Chart provided studies are provided as a DLL with Sierra Chart and almost every new release the DLL changes and yet existing study instance Inputs are not affected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-11 20:19:22
