Date/Time: Fri, 10 Jan 2025 12:21:27 +0000
Clicking get spreads on CL future spread and nothing is happening
View Count: 801
[2016-09-11 11:42:45] |
User158949 - Posts: 4 |
Hi. I am trying to pull up a chart (delayed data) of crude oil CL exchange traded calender spreads. If I click FS - find symbol, then go to future spreads CME, click on CL then click on get spreads nothing happens. Can you help? Thanks |
[2016-09-11 21:35:02] |
As an update I am able to produce bar charts of exchange traded spreads by typing in the symbol manually. I still do not get a list of the spreads available when I click 'get spreads' in the find symbol box.
[2016-09-11 21:39:33] |
You need to use the Sierra Chart Exchange Data Feed for this: Sierra Chart Exchange Data Feed You do not have to activate any exchanges but you do have to pay for the data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
