Date/Time: Fri, 10 Jan 2025 13:12:26 +0000
WHAT ARE THESE DRAWING NUMBERS USED FOR?
View Count: 902
[2016-09-10 16:14:33]
User60287 - Posts: 20
http://www.sierrachart.com/image.php?Image=1473524002137.png
In this image you can see each drawing element has been numbered.
These numbers appear if I errantly select more than one drawing item or if I push the delete button without selecting any drawing item.
Is there some way to use the numbers to select a drawing for edit purposes?
[2016-09-11 11:00:43]
This is documented here:
Chart Drawing Tools: Move Drawing - Left-Click Selection Method
And here:
Chart Drawing Tools: Erasing Chart Drawings
Date Time Of Last Edit: 2016-09-11 11:01:15
